twice login
smurfjesse
twice login
Post by smurfjesse »
Hello aka,
our session broker is working now thank god.
but we stumbled on another problem if we want to login.
we also use dns round robin to switch between terminal servers. the problem is if the user has an existing session open and tries to login again it has 50 % chance its sends you to the correct server and then you only have to login once. but if the the dns first send you to the other service you have to put your credentials in a second time cause the session broker sends you to the correct server.
microsoft says its a problem of the rdp protocol you use. do you know anything of this and is it possible to solve
regards,
jesse
Re: twice login
2008 server? Look at ask_password option http://wtware.com/docs5/config.html#ask_password
smurfjesse
Re: twice login
yeah its a 2008 server.
i put it in the config file but it didnt help.
you are sure this is working?
Re: twice login
Yes, we are sure.
Did it ask password in wtware screen for the first time?
Did you uncheck this checkbox on all terminal servers?
smurfjesse
Re: twice login
yes i have it unchecked.
but wtware did not ask me to fill in a password.
it just go directly to login screen of the terminal. tested on 5.0.2 and 5.1.1 (or something like that:))
Re: twice login
1. please install and run one of new versions - 5.0.7 or 5.1.14
2. specify ask_password=on in configuration file
3. then go directly to login screen, save and send me log
smurfjesse
Re: twice login
sendend you an email with the log
regards,
jesse
