USB Token on thinclient?
bidgol
Post by bidgol »
hi
i connect USB TOKEN direct to thin client usb and no work!
help
tnx
Re: USB Token on thinclient?
What is USB TOKEN?
Please, create and send us to support@wtware.com terminal log-file: http://wtware.com/docs/config.html#syslog
And make sure it is terminal log, not TFTP log.
Several USB tokens are already supported. Look at smartcard= option in configurator. Send us terminal log file after token attached so that we can find suitable driver for it.
