Serial port redirection
carlosevp
Post by carlosevp »
Hello.
I have redirected COM1 port, and some programs work.
But other programs, that use advanced configuration (lixe XON, parity) doesnt work and i have only seem parameters to change RTS or DTR, but not the other... also, the "mode" command doesnt seen to work very well on Win 2008.
Any ideas?
Thanks,
Carlos
Re: Serial port redirection
Best idea is do NOT redirect serial for advanced programs and advanced hardware. Serial redirection work well for barcode scanners and printers with simple protocols.
If you really want to use this program:
1. Check program with port redirection in mstsc.exe. If it does not work, then serial redirection in RDP is not good enough for it.
2. Send us wtware log. We'll read it, fix something, upload debugging wtware build. You'll download it, test it again, send us log. We'll read it, fix something, upload debugging wtware build... And so un until we fix problem. It may take several weeks.
