USB AND CDROM DOESN'T WORK TOGETHER
gerwin
Post by gerwin »
Dear Sir / Madam,
Thank you for this great software. After trying for days to get a working image with thinstation i discovered this package and i love it.
I'm testing it to use it in our company but i discovered a problem.
When i put both USB and CDROM options on in the config file, only CDROM wil work. The client doesn't discover the USB stick anymore.
When i disable CDROM in config file the USB stick is recogniced and can by used.
Do you have a solution for this problem, because whe want to use CDROM and USB stick both on the same client.
With dear regards,
Gerwin van den Brink
The Netherlands
Re: USB AND CDROM DOESN'T WORK TOGETHER
Please, create and send us to support@wtware.com terminal log-file: http://wtware.com/docs/config.html#syslog
Create log for the newest WTware version, download it from: http://wtware.com/download.html
Insert usb stick, wait for a minute and save the log.
