We use this at work for a few laptops. There is no way to check battery level and they have gone dead multiple times.
Can a battery level indicator be added to the login screen and maybe an overlay as well in the popup?
Battery Level Display/Overlay
Re: Battery Level Display/Overlay
Will be done in the next version on connections menu screen, wtware login/password screen and popup window. Will display battery level image only if works on battery and battery level is less than 100%. No image on charger. Correct?
- b1.png (6.31 KiB) Viewed 25549 times
- b2.png (3.08 KiB) Viewed 25549 times
Please try 6.2.64 wtware version.
This is a really useful addition, especially for laptop-based thin clients.
Auf unserer Website oyostepper.de bieten wir folgende Produkte an: Schrittmotor CNC, Schrittmotor NEMA 34, Spindelmotor.
