Language problems in VNC, Terminal login and Chrome #swedish
antda
Post by antda »
I can´t get swedish language working with the following settings on v 6.2.42.
display=1920x1080
clienthostname=TESTAR_SWM
wtrc=on
language=sv, default
keyboard=sv
connection
server=xxxxxxxxxxxxxxxxxxxxx
connection
displayName=xxxxxxxxxxxxxxxxxxxx
server=VNC:172.21.179.210
user=anything:xxxxxxxxxxxxxxx
connection
application=chrome
keyboard_log=on
antda
Re: Language problems in VNC, Terminal login and Chrome #swedish
Post by antda »
This is an urgent request on 20 payed licenses. Please respond as soon as possible.
1. Where do you want to get swedish language? Show screen photo of interface you need.
2. Please find right keyboard layout for swedish language here: http://kbdlayout.info/
antda
Post by antda »
Thank you for the quick respons!
1. Can´t attach image but it´s in wtware terminal view and when connecting to VNC (vncclient_keyboard)
2. https://kbdlayout.info/kbdsw
keylog for åäö:
#å#
11-58-44-511| [ gm] [ 389.660334] [WTRC keyboard] Scan 0x1a => WT_KEY_SQR_BRACKET_L.
11-58-44-553| [ gm] [ 389.660541] Key WT_KEY_SQR_BRACKET_L (79) pressed.
11-58-44-620| [ gm] [ 389.769628] [WTRC keyboard] Scan 0x1a => WT_KEY_SQR_BRACKET_L.
11-58-44-661| [ gm] [ 389.769934] Key WT_KEY_SQR_BRACKET_L (79) released.
#ä#
11-58-44-871| [ gm] [ 390.020244] [WTRC keyboard] Scan 0x28 => WT_KEY_APOSTROPHE.
11-58-44-913| [ gm] [ 390.020363] Key WT_KEY_APOSTROPHE (99) pressed.
11-58-44-992| [ gm] [ 390.141210] [WTRC keyboard] Scan 0x28 => WT_KEY_APOSTROPHE.
11-58-45-034| [ gm] [ 390.141494] Key WT_KEY_APOSTROPHE (99) released.
#ö#
11-58-45-320| [ gm] [ 390.469513] [WTRC keyboard] Scan 0x27 => WT_KEY_SEMICOLON.
11-58-45-361| [ gm] [ 390.469675] Key WT_KEY_SEMICOLON (98) pressed.
11-58-45-454| [ gm] [ 390.604160] [WTRC keyboard] Scan 0x27 => WT_KEY_SEMICOLON.
11-58-45-497| [ gm] [ 390.604446] Key WT_KEY_SEMICOLON (98) released.
antda
Post by antda »
Looks right here, but doesnt work when i type user/password when i´m in the login screen in wtware.
/--- FILE "/etc/xorg.conf" -----------------------
| Section "InputDevice"
| Identifier "InpDev_event2"
| Driver "evdev"
| Option "Device" "/dev/input/event2"
| Option "SendCoreEvents" "on"
| Option "XkbLayout" "se,us"
| Option "XkbOptions" "grp:ctrl_shift_toggle"
| EndSection
| Identifier "InpDev_event3"
| Driver "evdev"
| Option "Device" "/dev/input/event3"
| EndSection
| Identifier "InpDev_event4"
| Driver "evdev"
| Option "Device" "/dev/input/event4"
| EndSection
| Identifier "InpDev_event5"
| Driver "evdev"
| Option "Device" "/dev/input/event5"
Also this when trying vnc (vncclient_keyboard=sv):
[ gm] [ 222.706354] Free ram before fork terminal client /sbin/vncclient (session 2): 7710876 Kb.
[ gm] [ 222.706567] Run '/sbin/vncclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 222.706619] Run /sbin/vncclient 2.
[ pfac] [ 222.706859] Ok, PID 822.
[ vncclient 822] [ 222.715234] VNC Client, WTware 6.2.42/RPi64, pipe 2, pid 822.
[ vncclient 822] [ 222.715529] Use /usr/lib/ui32.so.
[ gm] [ 222.716614] Incorrect "vncclient_keyboard" parameter value.
[ vncclient 822] [ 222.716764] vncclient-main.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ vncclient 822] [ 222.716872] Oops, something went wrong.
[ vncclient 822] [ 222.716968] Caught signal SIGPIPE.
[ gm] [ 223.093124] Session is over. Final message: Incorrect "vncclient_keyboard" parameter value.
[ pfac] [ 223.093378] Process pid 822 terminated, status 00000009.
antda wrote: Tue Oct 29, 2024 3:35 pm Looks right here, but doesnt work when i type user/password when i´m in the login screen in wtware.
Does login screen in wtware looks like attached image with wtware interface?
Or windows interface: Image
antda
Post by antda »
wtware interface
Please try this build:
http://wtware.com/testing/202410292109/ ... .43.en.zip
In config:
language=sv,default
Show me full log if it won't work: http://wtware.com/logs.html
antda
Post by antda »
Yes it works!
Can you do the same for vncclient_keyboard? >>>
[ gm] [ 18.651156] [WTRC] Connection from 172.21.170.243.
[ gm] [ 18.689507] [WTRC] Control password accepted.
[ gm] [ 18.690807] [WTRC] Zoom 75%, 2 bytes per pixel.
[ gm] [ 20.465144] Free ram before fork terminal client /sbin/vncclient (session 1): 7900424 Kb.
[ pfac] [ 20.465346] Run /sbin/vncclient 1.
[ gm] [ 20.465402] Run '/sbin/vncclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 20.465882] Ok, PID 800.
[ vncclient 800] [ 20.491241] VNC Client, WTware 6.2.43/RPi64, pipe 1, pid 800.
[ vncclient 800] [ 20.491414] Use /usr/lib/ui32.so.
[ gm] [ 20.491886] Incorrect "vncclient_keyboard" parameter value.
[ vncclient 800] [ 20.491923] vncclient-main.cpp ( 52): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ vncclient 800] [ 20.491982] Oops, something went wrong.
[ vncclient 800] [ 20.492070] Caught signal SIGPIPE.
[ gm] [ 21.096430] Session is over. Final message: Incorrect "vncclient_keyboard" parameter value.
[ pfac] [ 21.096677] Process pid 800 terminated, status 00000009.
antda
Post by antda »
Do you need any more information regarding the VNC language?
We only have English and Russian in vncclient_keyboard= option now. Why do you think you need vncclient_keyboard=? What exactly goes wrong?
antda
Post by antda »
-When i connect to client by vnc (server side is tightvnc and ultravnc, tried both) i cannot type åäö etc.
-When i connect with regular vnc client through my laptop everything works.
This customer only wants to connect with VNC unfortunately. RDP is not an option, although i tried it and it works fine.
antda
Post by antda »
I have also tried Tigervnc on server-side without better results.
http://wtware.com/testing/202411042106/ ... .43.en.zip
In terminal config:
vncclient_keyboard=sv,default
antda
Post by antda »
Thank you, it works.
Fast and flawless support, very impressive. Keep up the good work! :wink:
