Clone RDP onto 2 monitors RPI4
Hello!
I am working with a RPI4 and I am trying to get a RDP session to duplicate on to 2 monitors. Currently I can only get it to span across. Is there a way to do this?
Thanks!
Thanks!
Re: Clone RDP onto 2 monitors RPI4
Please try 6.2.42 wtware version.
In wtware terminal config file:
m2_display = cloneRe: Clone RDP onto 2 monitors RPI4
Thanks! Is the option in the GUI editor or do I have to change the version to "No Version".
On "Text" tab. I've just added this option, GUI editor doesn't know it yet.
Hello! I was wondering if this was added to the GUI yet.
Thanks!
Thanks!
Does it work from text config?
Goyo
I have tried with 6.2.58/RPi64 and it is not working. I get black screen in HDMI2.
Regards
Regards
Show me the log: https://wtware.com/logs.html
Goyo
Restore the original config.txt file to the SD card. If the wtware is installed on Windows, the original file for version 6.2.62 can be copied from:
"C:\Program Files (x86)\WTware\TFTPDROOT\6.2.62\pi2\localboot\config.txt"
- config.txt
- (1.65 KiB) Downloaded 152 times
