Deactivation of the "mDNS" service port 5353 (WTwareClient)?
Overmind
Post by Overmind »
Is there a way to switch off the "mDNS" service in WTware clients, port 5353 is blocked in our system, this only causes an unnecessary flood of packets in the firewall and at the same time puts a strain on the network?
with kind regards
Overmind
Re: Deactivation of the "mDNS" service port 5353 (WTwareClient)?
I'm surprised that wtware uses mdns. Show me what your firewall reports. Also show me wtware terminal log with the same IP as in reported mdns packets: http://wtware.com/logs.html
Guest
Post by Guest »
WTware v.6.2.12/RPi
wtwDCAXXXXXXXXX
XXXXX\user
WTware 6.2.12/RPi supervisor.
[ KERNEL] [ 0.000000] Linux version 5.15.92-v7l (aka@c26) (arm-linux-gnueabihf-gcc (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #105 SMP Thu Dec 21 22:04:14 +04 2023
[ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
[ KERNEL] [ 0.000000] random: crng init done
[ KERNEL] [ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
[ KERNEL] [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ KERNEL] [ 0.000000] Zone ranges:
[ KERNEL] [ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ KERNEL] [ 0.000000] Normal empty
[ KERNEL] [ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ KERNEL] [ 0.000000] Movable zone start for each node
[ KERNEL] [ 0.000000] Early memory node ranges
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000039ffffff]
[ KERNEL] [ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ KERNEL] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu s13772 r8192 d23092 u45056
[ KERNEL] [ 0.000000] pcpu-alloc: s13772 r8192 d23092 u45056 alloc=11*4096
[ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 498176
[ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=xx:xx:xx:xx:xx:xx vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 hide_setup quiet wtboot=mmc
[ KERNEL] [ 0.000000] Unknown kernel command line parameters "hide_setup wtboot=mmc", will be passed to user space.
[ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ KERNEL] [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ KERNEL] [ 0.000000] software IO TLB: mapped [mem 0x0000000025c00000-0x0000000029c00000] (64MB)
[ KERNEL] [ 0.000000] Memory: 1839104K/1998848K available (6144K kernel code, 598K rwdata, 860K rodata, 2048K init, 374K bss, 94208K reserved, 65536K cma-reserved, 1212416K highmem)
[ KERNEL] [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ KERNEL] [ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ KERNEL] [ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ KERNEL] [ 0.000017] Switching to timer-based delay loop, resolution 18ns
[ KERNEL] [ 0.000273] Console: colour dummy device 80x30
[ KERNEL] [ 0.000318] printk: console [tty0] enabled
[ KERNEL] [ 0.000359] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ KERNEL] [ 0.000377] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000537] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ KERNEL] [ 0.000558] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ KERNEL] [ 0.001109] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.001151] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ KERNEL] [ 0.001348] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ KERNEL] [ 0.001820] Setting up static identity map for 0x200000 - 0x20003c
[ KERNEL] [ 0.001903] rcu: Hierarchical SRCU implementation.
[ KERNEL] [ 0.002205] smp: Bringing up secondary CPUs ...
[ KERNEL] [ 0.002732] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ KERNEL] [ 0.003349] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ KERNEL] [ 0.003926] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ KERNEL] [ 0.004014] smp: Brought up 1 node, 4 CPUs
[ KERNEL] [ 0.004030] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ KERNEL] [ 0.004041] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.004047] CPU: Virtualization extensions available.
[ KERNEL] [ 0.004499] devtmpfs: initialized
[ KERNEL] [ 0.015121] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ KERNEL] [ 0.015265] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.015286] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ KERNEL] [ 0.016826] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.017399] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ KERNEL] [ 0.019367] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.020436] thermal_sys: Registered thermal governor 'step_wise'
[ KERNEL] [ 0.020916] Serial: AMBA PL011 UART driver
[ KERNEL] [ 0.025902] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.039942] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-18T12:28:01, variant start
[ KERNEL] [ 0.049952] raspberrypi-firmware soc:firmware: Firmware hash is 658f02cc8edcb68a568273f05d2b6ceede181e15
[ KERNEL] [ 0.089272] cryptd: max_cpu_qlen set to 1000
[ KERNEL] [ 0.091371] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ KERNEL] [ 0.093623] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.093672] usbcore: registered new interface driver hub
[ KERNEL] [ 0.093718] usbcore: registered new device driver usb
[ KERNEL] [ 0.094521] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.101658] NET: Registered PF_INET protocol family
[ KERNEL] [ 0.101842] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ KERNEL] [ 0.102902] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ KERNEL] [ 0.102928] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ KERNEL] [ 0.102945] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ KERNEL] [ 0.103001] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ KERNEL] [ 0.103069] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.103167] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ KERNEL] [ 0.103195] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ KERNEL] [ 0.103315] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ KERNEL] [ 0.103342] PCI: CLS 0 bytes, default 64
[ KERNEL] [ 0.107353] Initialise system trusted keyrings
[ KERNEL] [ 0.107484] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[ KERNEL] [ 0.217616] Key type asymmetric registered
[ KERNEL] [ 0.217635] Asymmetric key parser 'x509' registered
[ KERNEL] [ 0.217774] bounce: pool size: 64 pages
[ KERNEL] [ 0.221770] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ KERNEL] [ 0.221803] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ KERNEL] [ 0.221848] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ KERNEL] [ 0.221891] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[ KERNEL] [ 0.286610] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ KERNEL] [ 0.286875] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ KERNEL] [ 0.286888] pci_bus 0000:00: root bus resource [bus 00-ff]
[ KERNEL] [ 0.286904] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ KERNEL] [ 0.286956] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ KERNEL] [ 0.287049] pci 0000:00:00.0: PME# supported from D0 D3hot
[ KERNEL] [ 0.290118] PCI: bus0: Fast back to back transfers disabled
[ KERNEL] [ 0.290133] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ KERNEL] [ 0.290359] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ KERNEL] [ 0.290452] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ KERNEL] [ 0.290720] pci 0000:01:00.0: PME# supported from D0 D3cold
[ KERNEL] [ 0.293790] PCI: bus1: Fast back to back transfers disabled
[ KERNEL] [ 0.293803] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ KERNEL] [ 0.293836] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 0.293855] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ KERNEL] [ 0.293919] pci 0000:00:00.0: PCI bridge to [bus 01]
[ KERNEL] [ 0.293933] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ KERNEL] [ 0.294132] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 0.294288] pcieport 0000:00:00.0: PME: Signaling with IRQ 57
[ KERNEL] [ 0.295083] bcm2708_fb soc:fb: FB found 2 display(s)
[ KERNEL] [ 0.334183] Console: switching to colour frame buffer device 240x67
[ KERNEL] [ 0.344976] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
[ KERNEL] [ 0.377036] bcm2708_fb soc:fb: Registered framebuffer for display 1, size 1920x1080
[ KERNEL] [ 0.383742] iproc-rng200 fe104000.rng: hwrng registered
[ KERNEL] [ 0.383906] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ KERNEL] [ 0.384654] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ KERNEL] [ 0.386060] zram: Added device: zram0
[ KERNEL] [ 0.389883] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ KERNEL] [ 0.390016] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 0.390047] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ KERNEL] [ 0.442940] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[ KERNEL] [ 0.443366] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ KERNEL] [ 0.443391] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ KERNEL] [ 0.443411] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ KERNEL] [ 0.443608] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ KERNEL] [ 0.443624] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 0.443636] usb usb1: Product: xHCI Host Controller
[ KERNEL] [ 0.443647] usb usb1: Manufacturer: Linux 5.15.92-v7l xhci-hcd
[ KERNEL] [ 0.443658] usb usb1: SerialNumber: 0000:01:00.0
[ KERNEL] [ 0.444232] hub 1-0:1.0: USB hub found
[ KERNEL] [ 0.444286] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 0.444925] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ KERNEL] [ 0.444942] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 0.444955] usb usb2: Product: xHCI Host Controller
[ KERNEL] [ 0.444966] usb usb2: Manufacturer: Linux 5.15.92-v7l xhci-hcd
[ KERNEL] [ 0.444977] usb usb2: SerialNumber: 0000:01:00.0
[ KERNEL] [ 0.445448] hub 2-0:1.0: USB hub found
[ KERNEL] [ 0.445486] hub 2-0:1.0: 4 ports detected
[ KERNEL] [ 0.446601] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 0.446717] dwc_otg: FIQ enabled
[ KERNEL] [ 0.446726] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 0.446733] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 0.446744] Module dwc_common_port init
[ KERNEL] [ 0.446873] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[ KERNEL] [ 0.446884] SPI driver ads7846 has no spi_device_id for ti,ads7843
[ KERNEL] [ 0.446892] SPI driver ads7846 has no spi_device_id for ti,ads7845
[ KERNEL] [ 0.446900] SPI driver ads7846 has no spi_device_id for ti,ads7873
[ KERNEL] [ 0.447005] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 0.449228] sdhci: Secure Digital Host Controller Interface driver
[ KERNEL] [ 0.449244] sdhci: Copyright(c) Pierre Ossman
[ KERNEL] [ 0.449459] sdhci-pltfm: SDHCI platform and OF driver helper
[ KERNEL] [ 0.449693] hid: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 0.450660] usbcore: registered new interface driver usbhid
[ KERNEL] [ 0.450675] usbhid: USB HID core driver
[ KERNEL] [ 0.453692] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ KERNEL] [ 0.453707] [vc_sm_connected_init]: start
[ KERNEL] [ 0.459732] [vc_sm_connected_init]: installed successfully
[ KERNEL] [ 0.459923] NET: Registered PF_PACKET protocol family
[ KERNEL] [ 0.459950] Key type dns_resolver registered
[ KERNEL] [ 0.459991] Registering SWP/SWPB emulation handler
[ KERNEL] [ 0.648212] Loading compiled-in X.509 certificates
[ KERNEL] [ 0.650188] uart-pl011 fe201000.serial: there is not valid maps for state default
[ KERNEL] [ 0.650313] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ KERNEL] [ 0.650398] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 32, base_baud = 0) is a PL011 rev2
[ KERNEL] [ 0.660197] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ KERNEL] [ 0.660384] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ KERNEL] [ 0.660837] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ KERNEL] [ 0.660845] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ KERNEL] [ 0.684774] of_cfs_init
[ KERNEL] [ 0.684881] of_cfs_init: OK
[ KERNEL] [ 0.721627] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ KERNEL] [ 0.733921] Freeing unused kernel image (initmem) memory: 2048K
[ KERNEL] [ 0.744539] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ KERNEL] [ 0.765373] mmc0: new high speed SDHC card at address 0001
[ KERNEL] [ 0.766125] mmcblk0: mmc0:0001 00000 7.45 GiB
[ KERNEL] [ 0.768520] mmcblk0: p1
[ KERNEL] [ 0.768828] mmcblk0: mmc0:0001 00000 7.45 GiB
[ KERNEL] [ 0.787225] Run /init as init process
[ KERNEL] [ 0.787243] with arguments:
[ KERNEL] [ 0.787249] /init
[ KERNEL] [ 0.787255] hide_setup
[ KERNEL] [ 0.787261] with environment:
[ KERNEL] [ 0.787267] HOME=/
[ KERNEL] [ 0.787273] TERM=linux
[ KERNEL] [ 0.787279] wtboot=mmc
[ KERNEL] [ 0.795243] mmc1: new high speed SDIO card at address 0001
[ hotplug] [ 0.917969] Block device 254:0. No action.
[ KERNEL] [ 0.936941] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ KERNEL] [ 0.936961] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ KERNEL] [ 0.936970] usb 1-1: Product: USB2.0 Hub
[ KERNEL] [ 0.939166] hub 1-1:1.0: USB hub found
[ KERNEL] [ 0.939568] hub 1-1:1.0: 4 ports detected
[ hotplug] [ 1.067350] Block device 179:1. No action.
[ hotplug] [ 1.067528] Block device 179:0. No action.
[ pfac] [ 1.099641] Run /sbin/initrd.
[ pfac] [ 1.099759] Ok, PID 371.
[ initrd] [ 1.103332] WTware 6.2.12/RPi shell.
[ initrd] [ 1.103734] Load font 'ter-c32b.psf', console 120x33.
[ initrd] [ 1.121078] HDD/MMC/SD boot.
[ initrd] [ 1.230394] Success: /dev/mmcblk0p1 mounted to /bootmedia.
| # https://www.raspberrypi.org/documentati ... config-txt
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| gpu_mem=96
| disable_splash=1
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
| [pi4]
| # Enable second display by default
| max_framebuffers=2
| # Run as fast as firmware / board allows
| arm_boost=1
| [all]
| #hdmi_group=2
| #hdmi_mode=58
| # 800x600: hdmi_mode=9
| # 1024x768: hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768: hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900: hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768: hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| # https://www.raspberrypi.org/documentati ... eo-options
| [HDMI:0]
| hdmi_group=2
| hdmi_mode=82
| [HDMI:1]
| hdmi_group=2
| hdmi_mode=82
[ KERNEL] [ 1.284542] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
[ KERNEL] [ 1.422751] usb 1-1.1: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.04
[ KERNEL] [ 1.422773] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 1.422787] usb 1-1.1: Product: Dell USB Entry Keyboard
[ KERNEL] [ 1.422799] usb 1-1.1: Manufacturer: DELL
[ KERNEL] [ 1.433404] input: DELL Dell USB Entry Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:413C:2107.0001/input/input0
[ KERNEL] [ 1.495405] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:01:00.0-1.1/input0
[ KERNEL] [ 1.614546] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
| wifi_country = DE
| clientIP = xxx.xxx.xxx.29
| netmask = 255.255.255.0
| routerIP = xxx.xxx.xxx.100
| nameserverIP = xxx.xxx.xxx.41
| config = network
| tftpIP = xxx.xxx.xxx.195
| setupPassword = xxxxxxxxxxxxxxxxxxxxx
[ initrd] [ 1.744230] Do not cache package files.
[ initrd] [ 1.744351] WTpassword present: xxxxxxxxxxxxxxxxxxxxx.
[ initrd] [ 1.744446] Unpack /bootmedia/packages/pi2-lib.
[ KERNEL] [ 1.753050] usb 1-1.4: New USB device found, idVendor=413c, idProduct=301a, bcdDevice= 1.00
[ KERNEL] [ 1.753077] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 1.753091] usb 1-1.4: Product: Dell MS116 USB Optical Mouse
[ KERNEL] [ 1.753104] usb 1-1.4: Manufacturer: PixArt
[ KERNEL] [ 1.763357] input: PixArt Dell MS116 USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:413C:301A.0002/input/input1
[ KERNEL] [ 1.763700] hid-generic 0003:413C:301A.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt Dell MS116 USB Optical Mouse] on usb-0000:01:00.0-1.4/input0
[ initrd] [ 2.003962] /usr/lib/arm-linux-gnueabihf/libarmmem-v7l.so already exists. Do not overwrite.
[ initrd] [ 2.460693] USB: 413c:2107 Dell Computer Corp. KB212-B Quiet Key Keyboard.
[ initrd] [ 2.460760] USB: 2109:3431 VIA Labs, Inc. Hub.
[ initrd] [ 2.460798] USB: 413c:301a Dell Computer Corp. Dell MS116 Optical Mouse.
[ initrd] [ 3.758570] Load Ethernet drivers.
[ initrd] [ 3.758683] modprobe genet.
[ KERNEL] [ 3.771299] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ KERNEL] [ 3.884700] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ initrd] [ 3.887284] WTpassword present: xxxxxxxxxxxxxxxxxxxxx.
[ KERNEL] [ 3.890484] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ initrd] [ 3.887615] [ARP] Ping xxx.xxx.xxx.100.
[ KERNEL] [ 3.892735] bcmgenet fd580000.ethernet eth0: Link is Down
[ KERNEL] [ 8.084724] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ initrd] [ 8.092210] [ARP] MAC: 00:22:4D:69:0D:77
[ initrd] [ 8.131361] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ initrd] [ 8.131490] [TFTP] Download config file Everyone/source.wtc from xxx.xxx.xxx.195.
[ pfac] [ 8.132036] Run /sbin/httpd.
[ pfac] [ 8.132185] Ok, PID 420.
[ initrd] [ 8.138631] [TFTP] WTware TFTP v.6.2.20.
[ initrd] [ 8.141488] [TFTP] Download config file Everyone/list.wtc from xxx.xxx.xxx.195.
[ httpd] [ 8.141846] Internal HTTP Server, WTware 6.2.12/RPi
[ initrd] [ 8.143107] [TFTP] Download config file Terminals/xx.xx.xx.xx.xx.xx/config.wtc from xxx.xxx.xxx.195.
[ initrd] [ 8.144976] [TFTP] Download config file Terminals/xx.xx.xx.xx.xx.xx/wtware.lic from xxx.xxx.xxx.195.
| rdpcompression=off
| skin=sample16
| menu_colors=808080,ff0000
| clipboard=on
| extra=myresolv.zip,usb.zip
| sound=remote
| connection MST
| connection All
[ initrd] [ 8.146874] [TFTP] Download config file Everyone/all.wtc from xxx.xxx.xxx.195.
| server=xxx.xxx.xxx.195
| keyboard=de
| language=de,default
| ntp=xxx.xxx.xxx.41
| timezone=W. Europe Standard Time
| graphic=a
| screenswitch=Win-Ctrl-N
| extra=myresolv.zip
| skin=sample16
| domain=xxxxxx
| bpp=16
| wtrc=xxx.xxx.xxx.187; xxx.xxx.xxx.21; xxx.xxx.xxx.214; xxx.xxx.xxx.34; xxx.xxx.xxx.132; reject after timeout
| wtrc_password=xxxxxxxxxxxxxxxxxxxxx
[ initrd] [ 8.150123] [TFTP] Download config file Connections/MST.wtc from xxx.xxx.xxx.195.
/--- FILE "/tmp/tmp.wtc" -----------------------
| server=xxx.xxx.xxx.205
| displayName=W10_MST
| domain=xxxxxx.mg
| graphic=a
| keyboard=de
| user=xxxxxx\mst
[ initrd] [ 8.153269] [TFTP] Download config file Connections/All.wtc from xxx.xxx.xxx.195.
| server=--new--
| displayName=VM Name eingeben z.B. w10_abc
| graphic=a
| keyboard=de
| domain=xxxxxx
[ initrd] [ 8.156204] Remount /bootmedia for writing.
[ initrd] [ 8.161624] Remount /bootmedia as read-only.
| keyboard=de
| language=de,default
| ntp=xxx.xxx.xxx.41
| graphic=a
| skin=sample16
| domain=xxxxxx
| bpp=16
| rdpcompression=off
| clipboard=on
| sound=remote
| connection MST
| displayName=W10_MST
| domain=xxxxxx.mg
| graphic=a
| keyboard=de
| user=xxxxxx\mst
| connection All
| server=--new--
| graphic=a
| keyboard=de
| domain=xxxxxx
| license_xx:xx:xx:xx:xx:xx_full = \
[ initrd] [ 8.184199] Hostname: "wtwDCAXXXXXXXXX".
[ initrd] [ 8.184317] Run '/bin/sh /tmp/ntpdate', log '/tmp/ntp.out', env '', pid ''.
[ pfac] [ 8.184657] Run /bin/sh /tmp/ntpdate.
Start LLDP.
[ pfac] [ 8.185547] Ok, PID 421.
[ initrd] [ 8.185621] [TFTP] Download config file Graphic/sample16/menu.png from xxx.xxx.xxx.195.
[ NTP] [ 8.191849] ntpd: sending query to xxx.xxx.xxx.41
[ NTP] [ 8.193047] ntpd: reply from xxx.xxx.xxx.41: offset:+8185196.104172 delay:0.000853 status:0x1c strat:2 refid:0x15119582 rootdelay:0.031250 reach:0x01
[ initrd] [ 8.828077] [TFTP] Download config file Graphic/sample16/popup.png from xxx.xxx.xxx.195.
[ initrd] [ 8.833037] [TFTP] Download config file Graphic/sample16/saver.png from xxx.xxx.xxx.195.
[ initrd] [ 9.375050] [TFTP] Download config file Graphic/sample16/wait.png from xxx.xxx.xxx.195.
[ initrd] [ 9.935473] [TFTP] Download config file Graphic/sample16/branding.txt from xxx.xxx.xxx.195.
[ initrd] [ 9.936195] [TFTP] Error code 1: File not found..
[ httpd] [ 9.940799] Reread settings.
[ httpd] [ 9.941054] Everyone can control terminal by HTTP.
[ initrd] [ 10.053635] Unpack /bootmedia/packages/pi2-f.
[ NTP] [ 10.195284] ntpd: sending query to xxx.xxx.xxx.41
[ NTP] [ 10.196185] ntpd: reply from xxx.xxx.xxx.41: offset:+8185196.115382 delay:0.000744 status:0x1c strat:2 refid:0x15119582 rootdelay:0.031250 reach:0x03
[ NTP] [ 10.196326] ntpd: setting time to 2024-03-24 17:40:05.514539 (offset +8185196.115382s)
[ pfac] [ 10.196960] Process pid 421 terminated, status 00000000.
[ gm] [ 10.321892] WTware 6.2.12/RPi session manager.
[ KERNEL] [ 10.327670] input: Remote Control Keyboard as /devices/virtual/input/input2
[ gm] [ 10.333498] [EVDEV] Keys found. Add event2: Remote Control Keyboard.
[ gm] [ 10.333550] [EVDEV] EV_REL flag found. Add event1: PixArt Dell MS116 USB Optical Mouse.
[ gm] [ 10.333617] [EVDEV] Keys found. Add event0: DELL Dell USB Entry Keyboard.
[ gm] [ 10.333664] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 10.333712] M2 mode: 1920x1080, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 10.762659] Framebuffer device found.
[ gm] [ 10.762716] LINELENBYTES 7680
[ gm] [ 10.762758] VLEN 8294400
[ gm] [ 10.762798] Second framebuffer device found.
[ gm] [ 10.762839] LINELENBYTES 7680
[ gm] [ 10.762879] VLEN 8294400
[ gm] [ 10.763877] Use /usr/lib/ui32.so.
[ gm] [ 10.894537] Use '/tmp/wait.png'.
[ gm] [ 11.017124] [TFTP] Download config file Everyone/myresolv.zip from xxx.xxx.xxx.195.
[ gm] [ 11.023372] [unzip] Unpack '/tmp/extra-myresolv.zip' to '/'.
[ gm] [ 11.023677] [unzip] Unpack '/runme', 261 bytes.
[ gm] [ 11.025380] Run '/bin/sh /runme2unix', log '/tmp/extra.out', env '', pid ''.
[ pfac] [ 11.025935] Run /bin/sh /runme2unix.
[ gm] [ 11.026005] [TFTP] Download config file Everyone/usb.zip from xxx.xxx.xxx.195.
[ pfac] [ 11.026133] Ok, PID 426.
[EXTRA] close kotopipe (n = 0, errno 2).
[ pfac] [ 11.030376] Process pid 426 terminated, status 00000000.
[ gm] [ 11.237561] [unzip] Unpack '/tmp/extra-usb.zip' to '/'.
[ gm] [ 11.237833] [unzip] Unpack '/runme', 46 bytes.
[ gm] [ 11.246261] [unzip] Unpack '/vhusbdarm', 375436 bytes.
[ gm] [ 11.248355] Run '/bin/sh /runme2unix', log '/tmp/extra.out', env '', pid ''.
[ pfac] [ 11.248511] Run /bin/sh /runme2unix.
[ pfac] [ 11.248623] Ok, PID 427.
[ SYSLOG] [ 11.316473] 6 vhusbdarm[429]: >>> Starting VirtualHere USB Server v4.6.2 (Built: Dec 14 2023, 10:45:50)<<<
[ SYSLOG] [ 11.316637] 6 vhusbdarm[429]: Using configuration /config.ini
[ pfac] [ 11.317413] Process pid 427 terminated, status 00000000.
[ SYSLOG] [ 11.380768] 6 vhusbdarm[430]: Server licensed to=unlicensed max_devices=1
[ SYSLOG] [ 11.381045] 6 vhusbdarm[430]: Using large URB's
[ SYSLOG] [ 11.382470] 6 vhusbdarm[430]: Listening on all network interfaces at TCP port 7575
[ SYSLOG] [ 11.384148] 6 vhusbdarm[430]: Found Low speed device [413c:2107] "DELL, Dell USB Entry Keyboard" at address 111
[ SYSLOG] [ 11.385433] 6 vhusbdarm[430]: Found Low speed device [413c:301a] "PixArt, Dell MS116 USB Optical Mouse" at address 114
[ gm] [ 11.397344] Use '/tmp/menu.png'.
[ gm] [ 11.409489] Nobody can control terminal by VNC.
[ gm] [ 11.409574] xxx.xxx.xxx.187 can control terminal by WTRC.
[ gm] [ 11.409617] xxx.xxx.xxx.21 can control terminal by WTRC.
[ gm] [ 11.409657] xxx.xxx.xxx.214 can control terminal by WTRC.
[ gm] [ 11.409697] xxx.xxx.xxx.34 can control terminal by WTRC.
[ gm] [ 11.409737] xxx.xxx.xxx.132 can control terminal by WTRC.
[ gm] [ 11.414859] [WTRC] Password protected remote control.
[ gm] [ 11.418211] [WTRC] Listener at TCP port 789.
[ KERNEL] [ 31.204553] cam-dummy-reg: disabling
[ SYSLOG] [ 32.513179] 7 vhusbdarm[430]: xxx.xxx.xxx.2 connected as connection 1 (Standard TCP)
[ gm] [48673.233231] Free ram before fork terminal client /sbin/rdpclient (session 1): 1837236 Kb.
[ gm] [48673.233328] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [48673.233616] Run /sbin/rdpclient 1.
[ pfac] [48673.233678] Ok, PID 937.
[ rdpclient 937] [48673.239687] RDP Terminal Client, WTware 6.2.12/RPi, pipe 1, pid 937.
[ rdpclient 937] [48673.239909] Use /usr/lib/ui32.so.
[ rdpclient 937] [48673.241286] Make RDP session with xxx.xxx.xxx.205, port 3389.
[ rdpclient 937] [48673.241552] Username: "mst".
[ rdpclient 937] [48673.241726] No password.
[ rdpclient 937] [48673.241873] No PIN.
[ rdpclient 937] [48673.241982] Domain: "xxxxxx".
[ rdpclient 937] [48673.242100] No shell.
[ rdpclient 937] [48673.242191] No directory.
[ rdpclient 937] [48673.242280] Window: 1920x1080@32.
[ rdpclient 937] [48673.242381] Second monitor: [1920:0..3839:1079].
[ rdpclient 937] [48673.242467] PFlags 0x0000002E.
[ rdpclient 937] [48673.242543] Keyboard 00000407:00000000.
[ rdpclient 937] [48673.242625] My hostname "wtwDCAXXXXXXXXX".
[ rdpclient 937] [48673.242717] TCP: connecting to xxx.xxx.xxx.205:3389 (default timeouts).
[ rdpclient 937] [48673.246573] [TCP] Connection with xxx.xxx.xxx.205 established.
[ rdpclient 937] [48673.246863] [TCP] Turn keepalive on.
[ rdpclient 937] [48673.248554] Free ram after buffers allocation: 1836108 KB.
[ rdpclient 937] [48673.272027] Reconnect with TLS/SSL enabled.
[ rdpclient 937] [48673.272158] TCP: reconnecting to xxx.xxx.xxx.205:3389.
[ rdpclient 937] [48673.273517] [TCP] Connection with xxx.xxx.xxx.205 established.
[ rdpclient 937] [48673.273590] [TCP] Turn keepalive on.
[ rdpclient 937] [48673.296714] Server supports GFX Pipeline.
[ rdpclient 937] [48673.296885] TLS.
[ rdpclient 937] [48673.297033] SSL/TLS.
[ rdpclient 937] [48673.316584] TLSv1.2.
[ rdpclient 937] [48673.323145] RDP 10.8 server.
[ rdpclient 937] [48673.340442] Timezone '(UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna'.
[ rdpclient 937] [48673.340537] Enable font smoothing and Desktop Composition.
[ rdpclient 937] [48673.500634] Microsoft License: STATUS_VALID_CLIENT.
[ rdpclient 937] [48673.815739] Advertice h264 AVC444.
[ rdpclient 937] [48673.820813] GFX decoder thread.
[ rdpclient 937] [48673.825028] Graphics output buffer 3840x1080, 2 monitors.
[ rdpclient 937] [48673.825215] Monitor 0: 0.0-1919.1079 primary.
[ rdpclient 937] [48673.825375] Monitor 1: 1920.0-3839.1079.
[ rdpclient 937] [48675.657671] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
[ rdpclient 937] [48675.842148] Run 4 tile threads.
[ rdpclient 937] [48683.230029] errorInfo 0x00000000.
[ rdpclient 937] [48686.123240] SessionId 0x00000003: xxxxxx\mst.
[ rdpclient 937] [48732.117896] [ClearCodec debug] Short cursor has gone over the edge.
[ rdpclient 937] [48732.513008] [ClearCodec debug] SHORT_VBAR_CACHE_HIT with zero height.
and here is the Firewall log https://ibb.co/j554X09 here you can see well that the WTware Pi's makes a request every second, here in yellow the WTware Pi to the log
May be, it's vhusbdarm ? I saw bonjour and avahi words in Virtalhere, and 5353 port is a bonjour/avahi port too. Try to comment out "extra=" line. Will requests repeat?
