2-4K resolution possible?
Overmind
Post by Overmind »
we want to buy 2K or 4k monitors, but in the "Raspberry firmware config.txt" you can only set a maximum resolution of 1920x1200.
We currently need a resolution of 2560x1440 on only one display, the second display HDMI port is not used.
Later then a resolution of 3840 x 2160
We use Raspberry Pi 4 versions
Re: 2-4K resolution possible?
Please try:
https://forums.raspberrypi.com/viewtopic.php?t=280976
The following lines in /boot/config.txt worked to get a single 2560 x 1440 display working at 50hz:
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=88
hdmi_cvt=2560 1440 50 3 0 0
Or another solution:
https://forums.raspberrypi.com/viewtopi ... 0#p1492120
hdmi_group=2
hdmi_mode=87
max_framebuffer_width=2560
max_framebuffer_height=1440
hdmi_pixel_freq_limit=250000000
hdmi_cvt=2560 1440 56 5 0 0 1
hdmi_ignore_edid=0xa5000080
