microphone compatibility
met98
Post by met98 »
Hi
I'm evaluating different microphone audio adapters, I found one that has the 2 types of outputs (2-wire and 1).
i tried to buy this ORICO SKT3 which are good quality,
https://www.orico.me/product/orico-exte ... card-skt3/
i tested it but only audio works, no microphone.
You say it is possible to make it work?
it is the only one that has all 2 types of pin
I don't know what chip he has but on Monday I try to look at it
Re: microphone compatibility
met98
Post by met98 »
17-39-38-652| [wtc.exe] Failed to connect to 192.168.1.5:779.
17-39-50-061| [HTTP] WTware v.6.0.26 found at host [], mac DC:A6:32:DA:83:75.
17-39-50-105| [HTTP] '/wtware/Everyone\list.wtc' => 'C:\ProgramData\WTware\Everyone\list.wtc'.
17-39-50-112| [HTTP] '/wtware/Terminals\DC.A6.32.DA.83.75\config.wtc' => 'C:\ProgramData\WTware\Terminals\DC.A6.32.DA.83.75\config.wtc'.
17-39-50-113| [HTTP] '/wtware/Terminals\DC.A6.32.DA.83.75\wtware.lic' => 'C:\ProgramData\WTware\Terminals\DC.A6.32.DA.83.75\wtware.lic'.
17-40-40-952| [HTTP] '/wtware/Graphic\1920x1080\menu.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\menu.png'.
17-40-41-678| [HTTP] '/wtware/Graphic\1920x1080\popup.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\popup.png'.
17-40-41-685| [HTTP] '/wtware/Graphic\1920x1080\saver.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\saver.png'.
17-40-42-266| [HTTP] '/wtware/Graphic\1920x1080\wait.png' => 'C:\ProgramData\WTware\Graphic\1920x1080\wait.png'.
17-41-14-206| WTware 6.0.26/RPi supervisor.
17-41-14-206| [        KERNEL] [    0.000000] Booting Linux on physical CPU 0x0
17-41-14-206| [        KERNEL] [    0.000000] Linux version 5.4.75-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #19 SMP Fri Nov 27 09:59:20 UTC 2020
17-41-14-206| [        KERNEL] [    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
17-41-14-206| [        KERNEL] [    0.000000] CPU: div instructions available: patching division code
17-41-14-206| [        KERNEL] [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
17-41-14-206| [        KERNEL] [    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
17-41-14-206| [        KERNEL] [    0.000000] Memory policy: Data cache writealloc
17-41-14-206| [        KERNEL] [    0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
17-41-14-206| [        KERNEL] [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
17-41-14-206| [        KERNEL] [    0.000000] On node 0 totalpages: 1012736
17-41-14-206| [        KERNEL] [    0.000000]   DMA zone: 1920 pages used for memmap
17-41-14-206| [        KERNEL] [    0.000000]   DMA zone: 0 pages reserved
17-41-14-206| [        KERNEL] [    0.000000]   DMA zone: 196608 pages, LIFO batch:63
17-41-14-206| [        KERNEL] [    0.000000]   HighMem zone: 816128 pages, LIFO batch:63
17-41-14-206| [        KERNEL] [    0.000000] percpu: Embedded 15 pages/cpu s29324 r8192 d23924 u61440
17-41-14-206| [        KERNEL] [    0.000000] pcpu-alloc: s29324 r8192 d23924 u61440 alloc=15*4096
17-41-14-206| [        KERNEL] [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
17-41-14-206| [        KERNEL] [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1010816
17-41-14-206| [        KERNEL] [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:DA:83:75 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 quiet wtboot=mmc
17-41-14-206| [        KERNEL] [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
17-41-14-206| [        KERNEL] [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
17-41-14-206| [        KERNEL] [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
17-41-14-206| [        KERNEL] [    0.000000] software IO TLB: mapped [mem 0x244a0000-0x284a0000] (64MB)
17-41-14-206| [        KERNEL] [    0.000000] Memory: 3867784K/4050944K available (6144K kernel code, 167K rwdata, 808K rodata, 2048K init, 373K bss, 117624K reserved, 65536K cma-reserved, 3264512K highmem)
17-41-14-206| [        KERNEL] [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
17-41-14-206| [        KERNEL] [    0.000000] rcu: Hierarchical RCU implementation.
17-41-14-206| [        KERNEL] [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
17-41-14-206| [        KERNEL] [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
17-41-14-206| [        KERNEL] [    0.000000] GIC: Using split EOI/Deactivate mode
17-41-14-206| [        KERNEL] [    0.000000] random: get_random_bytes called from 0xc0a00b60 with crng_init=0
17-41-14-206| [        KERNEL] [    0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
17-41-14-206| [        KERNEL] [    0.000021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
17-41-14-206| [        KERNEL] [    0.000089] bcm2835: system timer (irq = 17)
17-41-14-206| [        KERNEL] [    0.000629] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
17-41-14-206| [        KERNEL] [    0.000643] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
17-41-14-206| [        KERNEL] [    0.000657] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
17-41-14-206| [        KERNEL] [    0.000669] Switching to timer-based delay loop, resolution 18ns
17-41-14-206| [        KERNEL] [    0.000830] Console: colour dummy device 80x30
17-41-14-206| [        KERNEL] [    0.000846] printk: console [tty0] enabled
17-41-14-206| [        KERNEL] [    0.000881] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
17-41-14-206| [        KERNEL] [    0.000893] pid_max: default: 32768 minimum: 301
17-41-14-206| [        KERNEL] [    0.001020] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
17-41-14-206| [        KERNEL] [    0.001036] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
17-41-14-206| [        KERNEL] [    0.001560] CPU: Testing write buffer coherency: ok
17-41-14-206| [        KERNEL] [    0.001820] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
17-41-14-206| [        KERNEL] [    0.002198] Setting up static identity map for 0x200000 - 0x20003c
17-41-14-206| [        KERNEL] [    0.002276] rcu: Hierarchical SRCU implementation.
17-41-14-206| [        KERNEL] [    0.002539] smp: Bringing up secondary CPUs ...
17-41-14-206| [        KERNEL] [    0.003119] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
17-41-14-206| [        KERNEL] [    0.003765] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
17-41-14-206| [        KERNEL] [    0.004390] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
17-41-14-206| [        KERNEL] [    0.004467] smp: Brought up 1 node, 4 CPUs
17-41-14-206| [        KERNEL] [    0.004476] SMP: Total of 4 processors activated (432.00 BogoMIPS).
17-41-14-206| [        KERNEL] [    0.004483] CPU: All CPU(s) started in HYP mode.
17-41-14-206| [        KERNEL] [    0.004488] CPU: Virtualization extensions available.
17-41-14-206| [        KERNEL] [    0.004869] devtmpfs: initialized
17-41-14-206| [        KERNEL] [    0.013569] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
17-41-14-206| [        KERNEL] [    0.013850] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
17-41-14-206| [        KERNEL] [    0.013867] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
17-41-14-206| [        KERNEL] [    0.015343] pinctrl core: initialized pinctrl subsystem
17-41-14-206| [        KERNEL] [    0.016252] NET: Registered protocol family 16
17-41-14-206| [        KERNEL] [    0.018204] DMA: preallocated 1024 KiB pool for atomic coherent allocations
17-41-14-206| [        KERNEL] [    0.020110] Serial: AMBA PL011 UART driver
17-41-14-206| [        KERNEL] [    0.022000] bcm2835-mbox fe00b880.mailbox: mailbox enabled
17-41-14-206| [        KERNEL] [    0.040636] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start
17-41-14-206| [        KERNEL] [    0.050632] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094
17-41-14-206| [        KERNEL] [    0.096378] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
17-41-14-206| [        KERNEL] [    0.099361] vgaarb: loaded
17-41-14-206| [        KERNEL] [    0.099848] usbcore: registered new interface driver usbfs
17-41-14-206| [        KERNEL] [    0.099934] usbcore: registered new interface driver hub
17-41-14-206| [        KERNEL] [    0.100004] usbcore: registered new device driver usb
17-41-14-206| [        KERNEL] [    0.101537] clocksource: Switched to clocksource arch_sys_counter
17-41-14-206| [        KERNEL] [    0.111931] thermal_sys: Registered thermal governor 'step_wise'
17-41-14-206| [        KERNEL] [    0.112297] NET: Registered protocol family 2
17-41-14-206| [        KERNEL] [    0.112713] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
17-41-14-206| [        KERNEL] [    0.112737] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
17-41-14-206| [        KERNEL] [    0.112786] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
17-41-14-206| [        KERNEL] [    0.112848] TCP: Hash tables configured (established 8192 bind 8192)
17-41-14-206| [        KERNEL] [    0.112950] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
17-41-14-206| [        KERNEL] [    0.112978] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
17-41-14-206| [        KERNEL] [    0.113108] NET: Registered protocol family 1
17-41-14-206| [        KERNEL] [    0.113137] PCI: CLS 0 bytes, default 64
17-41-14-206| [        KERNEL] [    0.823558] Initialise system trusted keyrings
17-41-14-206| [        KERNEL] [    0.823687] workingset: timestamp_bits=30 max_order=20 bucket_order=0
17-41-14-206| [        KERNEL] [    0.867816] Key type asymmetric registered
17-41-14-206| [        KERNEL] [    0.867825] Asymmetric key parser 'x509' registered
17-41-14-206| [        KERNEL] [    0.867888] bounce: pool size: 64 pages
17-41-14-206| [        KERNEL] [    0.867951] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
17-41-14-206| [        KERNEL] [    0.870173] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
17-41-14-206| [        KERNEL] [    0.870188] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
17-41-14-206| [        KERNEL] [    0.870219] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
17-41-14-206| [        KERNEL] [    0.870248] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
17-41-14-206| [        KERNEL] [    0.923629] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
17-41-14-206| [        KERNEL] [    0.923845] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
17-41-14-206| [        KERNEL] [    0.923859] pci_bus 0000:00: root bus resource [bus 00-ff]
17-41-14-206| [        KERNEL] [    0.923873] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
17-41-14-206| [        KERNEL] [    0.923908] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
17-41-14-206| [        KERNEL] [    0.924011] pci 0000:00:00.0: PME# supported from D0 D3hot
17-41-14-206| [        KERNEL] [    0.926753] PCI: bus0: Fast back to back transfers disabled
17-41-14-206| [        KERNEL] [    0.926924] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
17-41-14-206| [        KERNEL] [    0.927030] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
17-41-14-206| [        KERNEL] [    0.927308] pci 0000:01:00.0: PME# supported from D0 D3cold
17-41-14-206| [        KERNEL] [    0.930039] PCI: bus1: Fast back to back transfers disabled
17-41-14-206| [        KERNEL] [    0.930077] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
17-41-14-206| [        KERNEL] [    0.930093] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
17-41-14-206| [        KERNEL] [    0.930153] pci 0000:00:00.0: PCI bridge to [bus 01]
17-41-14-206| [        KERNEL] [    0.930164] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
17-41-14-206| [        KERNEL] [    0.930327] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
17-41-14-206| [        KERNEL] [    0.930473] pcieport 0000:00:00.0: PME: Signaling with IRQ 53
17-41-14-206| [        KERNEL] [    0.930717] pcieport 0000:00:00.0: AER: enabled with IRQ 53
17-41-14-206| [        KERNEL] [    0.930987] pci 0000:01:00.0: enabling device (0140 -> 0142)
17-41-14-206| [        KERNEL] [    0.931483] bcm2708_fb soc:fb: FB found 1 display(s)
17-41-14-206| [        KERNEL] [    0.974449] Console: switching to colour frame buffer device 240x67
17-41-14-206| [        KERNEL] [    0.984956] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
17-41-14-206| [        KERNEL] [    0.988575] iproc-rng200 fe104000.rng: hwrng registered
17-41-14-206| [        KERNEL] [    0.988739] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
17-41-14-206| [        KERNEL] [    0.989248] vc-sm: Videocore shared memory driver
17-41-14-206| [        KERNEL] [    0.991451] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
17-41-14-206| [        KERNEL] [    0.992421] zram: Added device: zram0
17-41-14-206| [        KERNEL] [    0.994329] libphy: Fixed MDIO Bus: probed
17-41-14-206| [        KERNEL] [    0.994657] xhci_hcd 0000:01:00.0: xHCI Host Controller
17-41-14-206| [        KERNEL] [    0.994697] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
17-41-14-206| [        KERNEL] [    1.035263] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
17-41-14-206| [        KERNEL] [    1.035775] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
17-41-14-206| [        KERNEL] [    1.035786] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
17-41-14-206| [        KERNEL] [    1.035796] usb usb1: Product: xHCI Host Controller
17-41-14-206| [        KERNEL] [    1.035805] usb usb1: Manufacturer: Linux 5.4.75-v7l xhci-hcd
17-41-14-206| [        KERNEL] [    1.035813] usb usb1: SerialNumber: 0000:01:00.0
17-41-14-206| [        KERNEL] [    1.036282] hub 1-0:1.0: USB hub found
17-41-14-206| [        KERNEL] [    1.036347] hub 1-0:1.0: 1 port detected
17-41-14-206| [        KERNEL] [    1.036861] xhci_hcd 0000:01:00.0: xHCI Host Controller
17-41-14-206| [        KERNEL] [    1.036888] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
17-41-14-206| [        KERNEL] [    1.036907] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
17-41-14-206| [        KERNEL] [    1.037179] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
17-41-14-206| [        KERNEL] [    1.037198] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
17-41-14-206| [        KERNEL] [    1.037215] usb usb2: Product: xHCI Host Controller
17-41-14-206| [        KERNEL] [    1.037225] usb usb2: Manufacturer: Linux 5.4.75-v7l xhci-hcd
17-41-14-206| [        KERNEL] [    1.037233] usb usb2: SerialNumber: 0000:01:00.0
17-41-14-206| [        KERNEL] [    1.037709] hub 2-0:1.0: USB hub found
17-41-14-206| [        KERNEL] [    1.037753] hub 2-0:1.0: 4 ports detected
17-41-14-206| [        KERNEL] [    1.038668] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
17-41-14-206| [        KERNEL] [    1.038774] dwc_otg: FIQ enabled
17-41-14-206| [        KERNEL] [    1.038783] dwc_otg: NAK holdoff enabled
17-41-14-206| [        KERNEL] [    1.038789] dwc_otg: FIQ split-transaction FSM enabled
17-41-14-206| [        KERNEL] [    1.038798] Module dwc_common_port init
17-41-14-206| [        KERNEL] [    1.043362] usbcore: registered new interface driver usbtouchscreen
17-41-14-206| [        KERNEL] [    1.044833] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
17-41-14-206| [        KERNEL] [    1.046077] sdhci: Secure Digital Host Controller Interface driver
17-41-14-206| [        KERNEL] [    1.046086] sdhci: Copyright(c) Pierre Ossman
17-41-14-206| [        KERNEL] [    1.046431] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
17-41-14-206| [        KERNEL] [    1.046664] sdhci-pltfm: SDHCI platform and OF driver helper
17-41-14-206| [        KERNEL] [    1.047359] hidraw: raw HID events driver (C) Jiri Kosina
17-41-14-206| [        KERNEL] [    1.048217] usbcore: registered new interface driver usbhid
17-41-14-206| [        KERNEL] [    1.048227] usbhid: USB HID core driver
17-41-14-206| [        KERNEL] [    1.050079] vchiq: vchiq_init_state: slot_zero = (ptrval)
17-41-14-206| [        KERNEL] [    1.060605] [vc_sm_connected_init]: start
17-41-14-206| [        KERNEL] [    1.066763] [vc_sm_connected_init]: end - returning 0
17-41-14-206| [        KERNEL] [    1.067350] NET: Registered protocol family 17
17-41-14-206| [        KERNEL] [    1.067458] Registering SWP/SWPB emulation handler
17-41-14-206| [        KERNEL] [    1.067532] Loading compiled-in X.509 certificates
17-41-14-206| [        KERNEL] [    1.068358] uart-pl011 fe201000.serial: cts_event_workaround enabled
17-41-14-206| [        KERNEL] [    1.068391] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
17-41-14-206| [        KERNEL] [    1.073649] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
17-41-14-206| [        KERNEL] [    1.073914] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
17-41-14-206| [        KERNEL] [    1.073918] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
17-41-14-206| [        KERNEL] [    1.122228] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
17-41-14-206| [        KERNEL] [    1.123730] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-41-14-206| [        KERNEL] [    1.125226] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-41-14-206| [        KERNEL] [    1.128015] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
17-41-14-206| [        KERNEL] [    1.129510] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
17-41-14-206| [        KERNEL] [    1.138437] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
17-41-14-206| [        KERNEL] [    1.138568] of_cfs_init
17-41-14-206| [        KERNEL] [    1.138672] of_cfs_init: OK
17-41-14-206| [        KERNEL] [    1.141384] Freeing unused kernel memory: 2048K
17-41-14-206| [        KERNEL] [    1.166397] random: fast init done
17-41-14-206| [        KERNEL] [    1.191785] Run /init as init process
17-41-14-206| [        KERNEL] [    1.193685] mmc1: new high speed SDIO card at address 0001
17-41-14-206| [        KERNEL] [    1.211465] mmc0: new ultra high speed SDR25 SDHC card at address b368
17-41-14-206| [        KERNEL] [    1.211922] mmcblk0: mmc0:b368 CBADS 30.0 GiB
17-41-14-206| [        KERNEL] [    1.212878]  mmcblk0: p1
17-41-14-206| [        KERNEL] [    1.401558] usb 1-1: new high-speed USB device number 2 using xhci_hcd
17-41-14-206| [          pfac] [    1.506731] Run /sbin/initrd.
17-41-14-206| [          pfac] [    1.506963] Ok, PID 793.
17-41-14-206| [        initrd] [    1.511281] WTware 6.0.26/RPi shell.
17-41-14-206| [        initrd] [    1.511759] Load font 'ter-c32b.psf', console 120x33.
17-41-14-206| [        initrd] [    1.533293] HDD/MMC/SD boot.
17-41-14-206| [        initrd] [    1.533519] No device '/dev/fb1'.
17-41-14-206| [        KERNEL] [    1.584146] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
17-41-14-206| [        KERNEL] [    1.584159] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
17-41-14-206| [        KERNEL] [    1.584169] usb 1-1: Product: USB2.0 Hub
17-41-14-206| [        KERNEL] [    1.585797] hub 1-1:1.0: USB hub found
17-41-14-206| [        KERNEL] [    1.586110] hub 1-1:1.0: 4 ports detected
17-41-14-206| [        initrd] [    1.596458] Success: /dev/mmcblk0p1 mounted to /bootmedia.
17-41-14-206| /--- FILE "/bootmedia/config.txt" -----------------------
17-41-14-206| | # For more options and information see:
17-41-14-206| | #
17-41-14-206| | # https://www.raspberrypi.org/documentation/configuration/config-txt/README.md
17-41-14-206| | #
17-41-14-206| | # Some settings may impact device functionality. See link above for details.
17-41-14-206| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
17-41-14-206| | #hdmi_safe=1
17-41-14-206| | # Uncomment this if your display has a black border of unused pixels visible
17-41-14-206| | # and your display can output without overscan.
17-41-14-206| | disable_overscan=1
17-41-14-206| | # Uncomment if hdmi display is not detected and composite is being output.
17-41-14-206| | #hdmi_force_hotplug=1
17-41-14-206| | # Uncomment to force a specific HDMI mode (this will force VGA).
17-41-14-206| | #hdmi_group=1
17-41-14-206| | #hdmi_mode=1
17-41-14-206| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
17-41-14-206| | #hdmi_drive=2
17-41-14-206| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
17-41-14-206| | # no display.
17-41-14-206| | #config_hdmi_boost=4
17-41-14-206| | # Uncomment to overclock the arm. 700 MHz is the default.
17-41-14-206| | #arm_freq=800
17-41-14-206| | disable_splash=1
17-41-14-206| | framebuffer_depth=32
17-41-14-206| | # Uncomment for 16-bit color.
17-41-14-206| | #framebuffer_depth=16
17-41-14-206| | # Enable onboard audio (HDMI or jack).
17-41-14-206| | dtparam=audio=on
17-41-14-206| | # Removes the warning overlay.
17-41-14-206| | #avoid_warnings=1
17-41-14-206| | # Additionally allows turbo when low-voltage is present.
17-41-14-206| | #avoid_warnings=2
17-41-14-206| | [pi4]
17-41-14-206| | max_framebuffers=2
17-41-14-206| | [all]
17-41-14-206| | # Uncomment these two lines to set display resolution:
17-41-14-206| | #hdmi_group=2
17-41-14-206| | #hdmi_mode=58
17-41-14-206| | #
17-41-14-206| | # Specify correct value in hdmi_mode= line from the list of valid values:
17-41-14-206| | # 800x600:   hdmi_mode=9
17-41-14-206| | # 1024x768:  hdmi_mode=16
17-41-14-206| | # 1280x1024: hdmi_mode=35
17-41-14-206| | # 1360x768:  hdmi_mode=39
17-41-14-206| | # 1400x1050: hdmi_mode=42
17-41-14-206| | # 1440x900:  hdmi_mode=47
17-41-14-206| | # 1600x1200: hdmi_mode=51
17-41-14-206| | # 1680x1050: hdmi_mode=58
17-41-14-206| | # 1366x768:  hdmi_mode=81
17-41-14-206| | # 1920x1080: hdmi_mode=82
17-41-14-206| | # 1920x1200: hdmi_mode=69
17-41-14-206| | #
17-41-14-206| | # Find more resolutions in manual:
17-41-14-206| | # https://www.raspberrypi.org/documentation/configuration/config-txt/video.md
17-41-14-206| | #
17-41-14-206| | # Uncomment six lines with such syntax and right hdmi_mode= values for
17-41-14-206| | # dual displays on Raspberry Pi 4:
17-41-14-206| | #
17-41-14-206| | #[HDMI:0]
17-41-14-206| | # hdmi_group=2
17-41-14-206| | # hdmi_mode=42
17-41-14-206| | #[HDMI:1]
17-41-14-206| | # hdmi_mode=58
17-41-14-206| \----------------------------------------------------
17-41-14-206| [        KERNEL] [    1.911575] usb 1-1.2: new low-speed USB device number 3 using xhci_hcd
17-41-14-206| [        KERNEL] [    2.081267] usb 1-1.2: New USB device found, idVendor=03f0, idProduct=034a, bcdDevice= 1.21
17-41-14-206| [        KERNEL] [    2.081279] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
17-41-14-206| [        KERNEL] [    2.081288] usb 1-1.2: Product: HP Elite USB Keyboard
17-41-14-206| [        KERNEL] [    2.081297] usb 1-1.2: Manufacturer: Chicony
17-41-14-206| [        KERNEL] [    2.104111] input: Chicony HP Elite USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:03F0:034A.0001/input/input0
17-41-14-206| [        KERNEL] [    2.172241] hid-generic 0003:03F0:034A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-0000:01:00.0-1.2/input0
17-41-14-206| [        KERNEL] [    2.186940] input: Chicony HP Elite USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:03F0:034A.0002/input/input1
17-41-14-206| [        KERNEL] [    2.261926] input: Chicony HP Elite USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:03F0:034A.0002/input/input2
17-41-14-206| [        KERNEL] [    2.262220] hid-generic 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-0000:01:00.0-1.2/input1
17-41-14-206| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
17-41-14-206| | clientIP = *
17-41-14-206| | config = http
17-41-14-206| | tftpIP = 172.16.2.73
17-41-14-206| | tftpPrefix = /wtware/
17-41-14-206| | setupPassword = 8ac0fa26aeae79a1084fbf75a8caf048
17-41-14-206| [        initrd] [    2.311898] Do not cache package files.
17-41-14-206| [        initrd] [    2.312012] WTpassword present: 8ac0fa26aeae79a1084fbf75a8caf048.
17-41-14-206| [        initrd] [    2.312063] Unpack /bootmedia/packages/pi2-lib.
17-41-14-206| [        KERNEL] [    2.361564] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
17-41-14-206| [        KERNEL] [    2.506309] usb 1-1.4: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00
17-41-14-206| [        KERNEL] [    2.506315] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
17-41-14-206| [        KERNEL] [    2.506319] usb 1-1.4: Product: USB Audio Device
17-41-14-206| [        KERNEL] [    2.506323] usb 1-1.4: Manufacturer: GeneralPlus
17-41-14-206| [        KERNEL] [    2.513892] input: GeneralPlus USB Audio Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.3/0003:1B3F:2008.0003/input/input3
17-41-14-206| [        KERNEL] [    2.581720] hid-generic 0003:1B3F:2008.0003: input,hidraw2: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:01:00.0-1.4/input3
17-41-14-206| [        initrd] [    2.962462] USB: 2109:3431 VIA Labs, Inc. Hub.
17-41-14-206| [        initrd] [    2.962517] USB: 1b3f:2008 Generalplus Technology Inc..
17-41-14-206| [        initrd] [    2.962550] USB: 03f0:034a HP, Inc Elite Keyboard.
17-41-14-206| [        initrd] [    4.327447] Load Ethernet drivers.
17-41-14-206| [        initrd] [    4.327549] modprobe genet.
17-41-14-206| [        KERNEL] [    4.336173] bcmgenet fd580000.ethernet: failed to get enet clock
17-41-14-206| [        KERNEL] [    4.336181] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
17-41-14-206| [        KERNEL] [    4.336186] bcmgenet fd580000.ethernet: failed to get enet-wol clock
17-41-14-206| [        KERNEL] [    4.336190] bcmgenet fd580000.ethernet: failed to get enet-eee clock
17-41-14-206| [        KERNEL] [    4.336204] bcmgenet: Skipping UMAC reset
17-41-14-206| [        KERNEL] [    4.361571] libphy: bcmgenet MII bus: probed
17-41-14-206| [        KERNEL] [    4.451623] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
17-41-14-206| [        KERNEL] [    4.453236] bcmgenet: Skipping UMAC reset
17-41-14-206| [        KERNEL] [    4.455257] bcmgenet fd580000.ethernet: configuring instance for external RGMII
17-41-14-206| [        KERNEL] [    4.455988] bcmgenet fd580000.ethernet eth0: Link is Down
17-41-14-206| [        KERNEL] [    9.671648] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
17-41-14-206| [        initrd] [    9.762336] Download configs from HTTP 172.16.2.73 port 789 prefix '/wtware/'.
17-41-14-206| [        initrd] [    9.762443] WTpassword present: 8ac0fa26aeae79a1084fbf75a8caf048.
17-41-14-206| [        initrd] [   10.960133] dhcp: 349 bytes from 192.168.1.254.
17-41-14-206| [        initrd] [   10.960239] 00000000:000001490000000000110000C0A801FEC0A80105004300440149000002010601  ...I................C.D.I......
17-41-14-206| [        initrd] [   10.960325] 00000020:67458B6B0000000000000000C0A80105AC100266C0A801FEDCA632DA83750000  gE.k..............f......2..u..
17-41-14-206| [        initrd] [   10.960409] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.960491] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.960572] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.960653] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.960735] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.960815] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.960897] 00000100:0000000000000000638253633501020104FFFFFF003A040000A8C03B04000127  ........c.Sc5........:.....;...'
17-41-14-206| [        initrd] [   10.960978] 00000120:503304000151803604AC1002660304C0A801FE0610AC100258AC100259AC1002  P3...Q.6...f.........X..Y..
17-41-14-206| [        initrd] [   10.961058] dhcp: 349 bytes from 192.168.1.16.
17-41-14-206| [        initrd] [   10.961136] 00000000:000001490000000000110000C0A80110C0A80105004300440149000002010601  ...I...............C.D.I......
17-41-14-206| [        initrd] [   10.961217] 00000020:67458B6B0000000000000000C0A80105AC100266C0A80110DCA632DA83750000  gE.k..............f.....2..u..
17-41-14-206| [        initrd] [   10.961298] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.961398] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.961480] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.961561] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.961642] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.961722] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   10.961802] 00000100:0000000000000000638253633501020104FFFFFF003A040000A8C03B04000127  ........c.Sc5........:.....;...'
17-41-14-206| [        initrd] [   10.961883] 00000120:503304000151803604AC1002660304C0A801FE0610AC100258AC100259AC1002  P3...Q.6...f.........X..Y..
17-41-14-206| [        initrd] [   10.961965] Discard second offer for 192.168.1.5.
17-41-14-206| [        initrd] [   12.130173] dhcp: 349 bytes from 192.168.1.254.
17-41-14-206| [        initrd] [   12.130273] 00000000:000001490000000000110000C0A801FEC0A80105004300440149000002010601  ...I................C.D.I......
17-41-14-206| [        initrd] [   12.130358] 00000020:67458B6B0000000000000000C0A8010500000000C0A801FEDCA632DA83750000  gE.k......................2..u..
17-41-14-206| [        initrd] [   12.130440] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   12.130520] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   12.130601] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   12.130681] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   12.130762] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   12.130843] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
17-41-14-206| [        initrd] [   12.130923] 00000100:0000000000000000638253633501053A040000A8C03B04000127503304000151  ........c.Sc5..:.....;...'P3...Q
17-41-14-206| [        initrd] [   12.131003] 00000120:803604AC1002660104FFFFFF000304C0A801FE0610AC100258AC100259AC1002  .6...f...............X..Y..
17-41-14-206| [        initrd] [   12.170089] [DHCP] DHCP server address 172.162.2.102.
17-41-14-206| [        initrd] [   12.170177] [DHCP] IP 192.168.1.5 mask 255.255.255.0.
17-41-14-206| [        initrd] [   12.170257] [DHCP] Default gateway 192.168.1.254.
17-41-14-206| [        initrd] [   12.170337] [DHCP] DNS 172.161.2.188.
17-41-14-206| [        initrd] [   12.170418] [DHCP] DNS 172.161.2.189.
17-41-14-206| [        initrd] [   12.170498] [DHCP] DNS 172.161.2.132.
17-41-14-206| [        initrd] [   12.170576] [DHCP] DNS 192.168.1.49.
17-41-14-206| [        initrd] [   12.170655] [DHCP] NTP 193.71.14.22.
17-41-14-206| [        initrd] [   12.170735] [DHCP] Domain eris.local.
17-41-14-206| [        initrd] [   12.170813] [DHCP] HTTP IP 172.16.2.73 already specified.
17-41-14-206| WTC listener is active.
17-41-14-206| WTC broadcast listener is active.
17-41-14-206| Send broadcast WTCU discover.
17-41-14-206| [          pfac] [   12.172215] Run /sbin/httpd.
17-41-14-206| [        initrd] [   12.172284] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
17-41-14-206| [          pfac] [   12.172418] Ok, PID 853.
17-41-14-206| [        initrd] [   12.172481] [HTTP] Download config file /wtware/Everyone/list.wtc from 172.16.2.73.
17-41-14-206| [        initrd] [   12.178805] [HTTP] Download config file /wtware/Terminals/DC.A6.32.DA.83.75/config.wtc from 172.16.2.73.
17-41-14-206| [        initrd] [   12.180270] [HTTP] Download config file /wtware/Terminals/DC.A6.32.DA.83.75/wtware.lic from 172.16.2.73.
17-41-14-206| [         httpd] [   12.181415] Internal HTTP Server, WTware 6.0.26/RPi
17-41-14-206| [        initrd] [   12.181528] [HTTP] File not found.
17-41-14-206| /--- FILE "/tmp/config.wtc" -----------------------
17-41-14-206| | sound=on, hw:2:0
17-41-14-206| | template RDS_Raspberry
17-41-14-206| | connection
17-41-14-206| [        initrd] [   12.182103] [HTTP] Download config file /wtware/Everyone/all.wtc from 172.16.2.73.
17-41-14-206| /--- FILE "/tmp/all.wtc" -----------------------
17-41-14-206| | [BOM]
17-41-14-206| | server=srvrds99.eris.local
17-41-14-206| | keyboard=it
17-41-14-206| | domain=eris.local
17-41-14-206| | microphone=on
17-41-14-206| | language=it,default
17-41-14-206| | loadbalanceinfo=tsv://MS Terminal Services Plugin.1.RDS_eris
17-41-14-206| | vnc=on
17-41-14-206| | vnc_password=ErViGrSp
17-41-14-206| | clienthostname=TRM*IP1
17-41-14-206| | display=1280x1024
17-41-14-206| | skin=1280x1024
17-41-14-206| Skip 'CLID'.
17-41-14-206| | sleep=5,poweroff
17-41-14-206| [        initrd] [   12.183668] [HTTP] Download config file /wtware/Everyone/wtware.lic from 172.116.2.73.
17-41-14-206| [        initrd] [   12.185898] [HTTP] Download config file /wtware/Templates/RDS_Raspberry.wtc from 172.116.2.73.
17-41-14-206| /--- FILE "/tmp/tmp.wtc" -----------------------
17-41-14-206| | server=srvrds99.local
17-41-14-206| | sound=on, hw:1:0
17-41-14-206| | display=1920x1080
17-41-14-206| | sleep=60,poweroff
17-41-14-206| | skin=1920x1080
17-41-14-206| | turnoffmenu=poweroff
17-41-14-206| [        initrd] [   12.188714] Remount /bootmedia for writing.
17-41-14-206| [        initrd] [   12.191682] Remount /bootmedia as read-only.
17-41-14-206| /--- FILE "/etc/config.compiled" -----------------------
17-41-14-206| [        initrd] [   12.232157] Hostname: "TRM-5".
17-41-14-206| [        initrd] [   12.510304] Run '/bin/sh /tmp/ntpdate', log '/tmp/ntp.out', env '', pid ''.
17-41-14-206| [          pfac] [   12.510415] Run /bin/sh /tmp/ntpdate.
17-41-14-206| Everyone can control terminal by RSH.
17-41-14-206| RSH: listener is active.
17-41-14-206| [          pfac] [   12.511661] Ok, PID 854.
17-41-14-206| [         httpd] [   12.515472] Reread settings.
17-41-14-206| [         httpd] [   12.515656] Everyone can control terminal by HTTP.
17-41-14-206| [           NTP] [   12.517768] ntpd: sending query to 193.204.114.232
17-41-14-206| [        initrd] [   12.537291] Unpack /bootmedia/packages/pi2-f.
17-41-14-206| [        KERNEL] [   12.707102] random: crng init done
17-41-14-206| [            gm] [   12.711090] WTware 6.0.26/RPi session manager.
17-41-14-206| [            gm] [   12.711792] Ignore event3: GeneralPlus USB Audio Device.
17-41-14-206| [            gm] [   12.711832] Keys found. Add event3: GeneralPlus USB Audio Device.
17-41-14-206| [            gm] [   12.711867] EV_REL flag found. Add event2: Chicony HP Elite USB Keyboard Consumer Control.
17-41-14-206| [            gm] [   12.711904] Ignore event1: Chicony HP Elite USB Keyboard System Control.
17-41-14-206| [            gm] [   12.711941] Keys found. Add event1: Chicony HP Elite USB Keyboard System Control.
17-41-14-206| [            gm] [   12.711980] Ignore event0: Chicony HP Elite USB Keyboard.
17-41-14-206| [            gm] [   12.712016] Keys found. Add event0: Chicony HP Elite USB Keyboard.
17-41-14-206| [            gm] [   12.712053] Display mode: 1920x1080, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
17-41-14-206| [           NTP] [   22.518264] Alarm clock
17-41-14-206| [           NTP] [   22.521804] hwclock: can't open '/dev/misc/rtc': No such file or directory
17-41-14-206| [          pfac] [   22.522625] Process pid 854 terminated, status 00000000.
17-41-14-206| [            gm] [   62.764267] [ERROR] Lookup for DNS failed, errors 0 -2.
17-41-14-206| [            gm] [   62.764401] [ERROR] Failed to resolve cl.wtware.com in DNS.
17-41-14-206| [            gm] [   62.764512] [ERROR] DNS is not configured properly.
17-41-14-206| [            gm] [   62.764616] [ERROR] Concurrent licenses cannot be applied.
17-41-14-206| [            gm] [   63.062451] Framebuffer device found.
17-41-14-206| [            gm] [   63.062495] LINELENBYTES 7680
17-41-14-206| [            gm] [   63.062530] VLEN 8294400
17-41-14-206| [            gm] [   63.063597] Use /lib/ui32.so.
17-41-14-206| [            gm] [   63.063820] [HTTP] Download config file /wtware/Graphic/1920x1080/menu.png from 172.16.2.73.
17-41-14-206| [            gm] [   63.790104] [HTTP] Download config file /wtware/Graphic/1920x1080/popup.png from 172.16.2.73.
17-41-14-206| [            gm] [   63.796563] [HTTP] Download config file /wtware/Graphic/1920x1080/saver.png from 172.16.2.73.
17-41-14-206| [            gm] [   64.379351] [HTTP] Download config file /wtware/Graphic/1920x1080/wait.png from 172.16.2.73.
17-41-14-206| [            gm] [   65.267742] Use '/tmp/wait.png'.
17-41-14-206| [            gm] [   65.278825] Unpack /bootmedia/packages/pi2-alsa.
17-41-14-206| [            gm] [   65.427341] modprobe snd-bcm2835.
17-41-14-206| [        KERNEL] [   65.435086] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
17-41-14-206| [        KERNEL] [   65.436510] bcm2835_audio bcm2835_audio: card created with 4 channels
17-41-14-206| [            gm] [   65.436201] modprobe snd-usb-audio.
17-41-14-206| [        KERNEL] [   65.437348] bcm2835_audio bcm2835_audio: card created with 4 channels
17-41-14-206| [        KERNEL] [   65.500233] usbcore: registered new interface driver snd-usb-audio
17-41-14-206| /--- FILE "/proc/asound/devices" -----------------------
17-41-14-206| |   0: [ 0]   : control
17-41-14-206| |  16: [ 0- 0]: digital audio playback
17-41-14-206| |  32: [ 1]   : control
17-41-14-206| |  33:        : timer
17-41-14-206| |  48: [ 1- 0]: digital audio playback
17-41-14-206| |  64: [ 2]   : control
17-41-14-206| |  80: [ 2- 0]: digital audio playback
17-41-14-206| |  88: [ 2- 0]: digital audio capture
17-41-14-206| [            gm] [   66.500054] /dev/snd//controlC2 character device.
17-41-14-206| [            gm] [   66.500164] /dev/snd//pcmC2D0c character device.
17-41-14-206| [            gm] [   66.500262] /dev/snd//pcmC2D0p character device.
17-41-14-206| [            gm] [   66.500350] /dev/snd//controlC1 character device.
17-41-14-206| [            gm] [   66.500435] /dev/snd//pcmC1D0p character device.
17-41-14-206| [            gm] [   66.500520] /dev/snd//controlC0 character device.
17-41-14-206| [            gm] [   66.500604] /dev/snd//pcmC0D0p character device.
17-41-14-206| [            gm] [   66.500688] /dev/snd//timer character device.
17-41-14-206| [            gm] [   66.500773] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
17-41-14-206| [          pfac] [   66.501218] Run /sbin/rdpsnd sndvol 100 100 50.
17-41-14-206| [          pfac] [   66.501346] Ok, PID 884.
17-41-14-206| [        sndvol] [   66.507418] [ALSA] Sound cards found: 3.
17-41-14-206| [        sndvol] [   66.510487] Card 'b1'/'bcm2835 HDMI 1'.
17-41-14-206| [        sndvol] [   66.510600] Mixer name: 'Broadcom Mixer'.
17-41-14-206| [        sndvol] [   66.510692] Components: ''.
17-41-14-206| [        sndvol] [   66.510784] Controls: 2.
17-41-14-206| [        sndvol] [   66.510876] ALSA: control 'HDMI Playback Volume'.
17-41-14-206| [        sndvol] [   66.510969] ALSA: control 'HDMI Playback Switch'.
17-41-14-206| [        sndvol] [   66.511061] Card 'Headphones'/'bcm2835 Headphones'.
17-41-14-206| [        sndvol] [   66.511155] Mixer name: 'Broadcom Mixer'.
17-41-14-206| [        sndvol] [   66.511247] Components: ''.
17-41-14-206| [        sndvol] [   66.511339] Controls: 2.
17-41-14-206| [        sndvol] [   66.511429] ALSA: control 'Headphone Playback Volume'.
17-41-14-206| [        sndvol] [   66.511519] ALSA: control 'Headphone Playback Switch'.
17-41-14-206| [        sndvol] [   66.511609] Card 'Device'/'GeneralPlus USB Audio Device at usb-0000:01:00.0-1.4, full speed'.
17-41-14-206| [        sndvol] [   66.511703] Mixer name: 'USB Mixer'.
17-41-14-206| [        sndvol] [   66.511794] Components: 'USB1b3f:2008'.
17-41-14-206| [        sndvol] [   66.511885] Controls: 10.
17-41-14-206| [        sndvol] [   66.511975] ALSA: control 'Playback Channel Map'.
17-41-14-206| [        sndvol] [   66.512065] ALSA: control 'Capture Channel Map'.
17-41-14-206| [        sndvol] [   66.512155] ALSA: control 'Mic Playback Switch'.
17-41-14-206| [        sndvol] [   66.512808] ALSA: control 'Mic Playback Volume'.
17-41-14-206| [        sndvol] [   66.512904] ALSA: control 'Speaker Playback Switch'.
17-41-14-206| [        sndvol] [   66.513517] ALSA: control 'Speaker Playback Volume'.
17-41-14-206| [        sndvol] [   66.515764] ALSA: control 'Mic Capture Switch'.
17-41-14-206| [        sndvol] [   66.516524] ALSA: control 'Mic Capture Volume'.
17-41-14-206| [        sndvol] [   66.517262] ALSA: control 'Auto Gain Control'.
17-41-14-206| [        sndvol] [   66.518763] ALSA: control 'Keep Interface'.
17-41-14-206| [          pfac] [   66.520442] Process pid 884 terminated, status 00000000.
17-41-14-206| [            gm] [   66.600429] Run sound daemon.
17-41-14-206| [          pfac] [   66.601179] Run /sbin/rdpsnd 1 0 100 card=2,device=0,hw.
17-41-14-206| [            gm] [   66.601248] Run '/sbin/rdpsnd 1 0 100 card=2,device=0,hw', log '', env '', pid ''.
17-41-14-206| [          pfac] [   66.601341] Ok, PID 885.
17-41-14-206| [            gm] [   66.601393] Run microphone daemon.
17-41-14-206| [          pfac] [   66.601493] Run /sbin/rdpaudin 0 100 card=2,device=0.
17-41-14-206| [            gm] [   66.601555] Run '/sbin/rdpaudin 0 100 card=2,device=0', log '', env '', pid ''.
17-41-14-206| [          pfac] [   66.601659] Ok, PID 886.
17-41-14-206| [        rdpsnd] [   66.606439] RDP Sound Redirector, WTware 6.0.26/RPi.
17-41-14-206| [      rdpaudin] [   66.607460] RDP Microphone Redirector, WTware 6.0.26/RPi.
17-41-14-206| [      rdpaudin] [   66.611175] Card 'Device'/'GeneralPlus USB Audio Device at usb-0000:01:00.0-1.4, full speed'.
17-41-14-206| [      rdpaudin] [   66.611355] Mixer name: 'USB Mixer'.
17-41-14-206| [      rdpaudin] [   66.611496] Components: 'USB1b3f:2008'.
17-41-14-206| [      rdpaudin] [   66.611648] Controls: 10.
17-41-14-206| [      rdpaudin] [   66.611834] ALSA: control 'Playback Channel Map'.
17-41-14-206| [      rdpaudin] [   66.612001] ALSA: control 'Capture Channel Map'.
17-41-14-206| [      rdpaudin] [   66.612148] ALSA: control 'Mic Playback Switch'.
17-41-14-206| [      rdpaudin] [   66.612343] ALSA: control 'Mic Playback Volume'.
17-41-14-206| [      rdpaudin] [   66.612488] ALSA: control 'Speaker Playback Switch'.
17-41-14-206| [      rdpaudin] [   66.612631] ALSA: control 'Speaker Playback Volume'.
17-41-14-206| [      rdpaudin] [   66.612771] ALSA: control 'Mic Capture Switch'.
17-41-14-206| [      rdpaudin] [   66.612945] ALSA: control 'Mic Capture Volume'.
17-41-14-206| [      rdpaudin] [   66.613104] ALSA: control 'Auto Gain Control'.
17-41-14-206| [      rdpaudin] [   66.613256] ALSA: control 'Keep Interface'.
17-41-14-206| [            gm] [   66.622513] Run '/sbin/resolver 0x1aa3798 dns [srvrds99.eris.local]', log '', env '', pid ''.
17-41-14-206| [            gm] [   66.622646] Everyone can control terminal by VNC.
17-41-14-206| [            gm] [   66.622736] [VNC] Listener at port 5900.
17-41-14-206| [            gm] [   66.622825] Nobody can control terminal by WTRC.
17-41-14-206| [          pfac] [   66.623561] Run /sbin/resolver 0x1aa3798 dns [srvrds99.eris.local].
17-41-14-206| [          pfac] [   66.623799] Ok, PID 887.
17-41-14-206| [            gm] [   66.629490] srvrds99.eris.local => 172.16.2.104.
17-41-14-206| [          pfac] [   66.629748] Process pid 887 terminated, status 00000000.
17-41-14-206| [            gm] [   66.636362] Free ram before fork terminal client /sbin/rdpclient (session 1): 3876524 Kb.
17-41-14-206| [          pfac] [   66.636423] Run /sbin/rdpclient 1.
17-41-14-206| [            gm] [   66.636441] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
17-41-14-206| [          pfac] [   66.636557] Ok, PID 888.
17-41-14-206| [ rdpclient 888] [   66.641682] RDP Terminal Client, WTware 6.0.26/RPi, pipe 1, pid 888.
17-41-14-206| [ rdpclient 888] [   66.642007] Use /lib/ui32.so.
17-41-14-206| [ rdpclient 888] [   66.642806] Redirect sound.
17-41-14-206| [ rdpclient 888] [   66.643136] Make RDP session with 172.16.2.104, port 3389.
17-41-14-206| [ rdpclient 888] [   66.643237]  No username.
17-41-14-206| [ rdpclient 888] [   66.643287]  No password.
17-41-14-206| [ rdpclient 888] [   66.643330]  No PIN.
17-41-14-206| [ rdpclient 888] [   66.643370]  Domain: "eris.local".
17-41-14-206| [ rdpclient 888] [   66.643413]  No shell.
17-41-14-206| [ rdpclient 888] [   66.643453]  No directory.
17-41-14-206| [ rdpclient 888] [   66.643494]  Window: 1856x1080@24.
17-41-14-206| [ rdpclient 888] [   66.643537]  PFlags 0x0000002F.
17-41-14-206| [ rdpclient 888] [   66.643576]  Keyboard 00000410:00000000.
17-41-14-206| [ rdpclient 888] [   66.643616]  My hostname "TRM-5".
17-41-14-206| [ rdpclient 888] [   66.643659] TCP: connecting to 172.16.2.104:3389.
17-41-14-206| [ rdpclient 888] [   66.643927] TCP: connection with 172.16.2.104:3389 established.
17-41-14-206| [ rdpclient 888] [   66.644030] Turn keepalive on.
17-41-14-206| [ rdpclient 888] [   66.645144] Free ram after buffers allocation: 3876020 KB.
17-41-14-206| [ rdpclient 888] [   66.645345] Use Balance Info 48 bytes: 'tsv://MS Terminal Services Plugin.1.RDS_eris'.
17-41-14-206| [            gm] [   66.806125] Use '/tmp/menu.png'.
17-41-14-214| Connection from wtc.exe at 172.16.2.73.
17-44-14-285| [ rdpclient 888] [  276.336009] Use Balance Info 48 bytes: 'tsv://MS Terminal Services Plugin.1.RDS_eris'.
17-44-14-285| [ rdpclient 888] [  276.341805] Server supports GFX Pipeline.
17-44-14-292| [ rdpclient 888] [  276.341854] NLA.
17-44-14-293| [ rdpclient 888] [  276.341890] SSL/TLS.
17-44-14-323| [ rdpclient 888] [  276.422084] Enable font smoothing and Desktop Composition.
17-44-14-397| [ rdpclient 888] [  276.512192] TS_STATUS_FINDING_DESTINATION
17-44-14-447| [ rdpclient 888] [  276.538452] TS_STATUS_LOADING_DESTINATION
17-44-14-454| [ rdpclient 888] [  276.538886] TS_STATUS_REDIRECTING_TO_DESTINATION
17-44-14-499| [ rdpclient 888] [  276.572787] TS_STATUS_BRINGING_SESSION_ONLINE
17-44-14-506| [ rdpclient 888] [  276.574210] TS_STATUS_VM_LOADING
17-44-14-549| [ rdpclient 888] [  276.615018] Server Redirection flags 0x00000b0d.
17-44-14-556| [ rdpclient 888] [  276.615057]  Server 172.16.2.98.
17-44-14-557| [ rdpclient 888] [  276.615085]  User "ced".
17-44-14-563| [ rdpclient 888] [  276.615113]  Domain "eris".
17-44-14-564| [ rdpclient 888] [  276.615141] Send Disconnect Provider Ultimatum.
17-44-18-715| [            gm] [  280.830881] TSClient (sessionId 1, pid 888) gracefully end.
17-44-18-724| [            gm] [  280.831113] Free ram before fork terminal client /sbin/rdpclient (session 2): 3870488 Kb.
17-44-18-725| [            gm] [  280.831145] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
17-44-18-732| [          pfac] [  280.831173] Run /sbin/rdpclient 2.
17-44-18-732| [          pfac] [  280.831323] Ok, PID 889.
17-44-18-738| [        rdpsnd] [  280.831643] Link lost.
17-44-18-739| [          pfac] [  280.831710] Process pid 888 terminated, status 00000009.
17-44-18-745| [ rdpclient 889] [  280.836497] RDP Terminal Client, WTware 6.0.26/RPi, pipe 2, pid 889.
17-44-18-746| [ rdpclient 889] [  280.836825] Use /lib/ui32.so.
17-44-18-754| [ rdpclient 889] [  280.837185] Redirect sound.
17-44-18-764| [ rdpclient 889] [  280.837281] Make RDP session with 172.16.2.98, port 3389.
17-44-18-764| [ rdpclient 889] [  280.837316]  Username: "ced".
17-44-18-770| [ rdpclient 889] [  280.837347]  Password: present.
17-44-18-771| [ rdpclient 889] [  280.837375]  No PIN.
17-44-18-777| [ rdpclient 889] [  280.837403]  Domain: "eris".
17-44-18-778| [ rdpclient 889] [  280.837431]  No shell.
17-44-18-787| [ rdpclient 889] [  280.837458]  No directory.
17-44-18-796| [ rdpclient 889] [  280.837486]  Window: 1856x1080@24.
17-44-18-797| [ rdpclient 889] [  280.837513]  PFlags 0x0000002F.
17-44-18-805| [ rdpclient 889] [  280.837541]  Keyboard 00000410:00000000.
17-44-18-805| [ rdpclient 889] [  280.837568]  My hostname "TRM-5".
17-44-18-814| [ rdpclient 889] [  280.837596] TCP: connecting to 172.16.2.98:3389.
17-44-18-821| [ rdpclient 889] [  280.837822] TCP: connection with 172.16.2.98:3389 established.
17-44-18-822| [ rdpclient 889] [  280.837852] Turn keepalive on.
17-44-18-828| [ rdpclient 889] [  280.838365] Free ram after buffers allocation: 3870472 KB.
17-44-18-829| [ rdpclient 889] [  280.838401] Empty Balance Info.
17-44-18-836| [ rdpclient 889] [  280.850474] Server supports GFX Pipeline.
17-44-18-837| [ rdpclient 889] [  280.850505] Redirected Session ID 0x00000000.
17-44-18-844| [ rdpclient 889] [  280.852845] Process RDP server certificate.
17-44-18-852| [ rdpclient 889] [  280.852892] RDP5 encryption (X.509).
17-44-18-853| [ rdpclient 889] [  280.854812] Enable font smoothing and Desktop Composition.
17-44-19-387| [ rdpclient 889] [  281.502633] GFX codec.
17-44-19-437| [ rdpclient 889] [  281.545865] Graphics output buffer 1856x1080, 1 monitors.
17-44-19-444| [ rdpclient 889] [  281.545916] Monitor 0: 0.0-1855.1079 primary.
I see no errors in log. Is audio recording enabled on your server? When connecting with mstsc.exe from windows machine to the same RDP server with the same user account, can you record audio from microphone?
met98
Post by met98 »
I run tests with our server with 3 different devices
1 notebook - full compatibility with integrated sound / mic card
2 t510 thin clients - I tested wtware with our hp thin clients and everything works apart from the dual monitor (I expected it, particular video card), integrated sound / mic card
3 raspberry 4 - with the audio adapter I can hear the audio in all 2 outputs but the microphone cannot record.
Wtware is very stable and light as software, very good
WTware writes several lines to log when RDP server accesses microphone for the first time. I don't see attempts to record sound in this log. Config file is correct and driver detected hardware. But no request to microphone from server.
Did you save this log after you tried to use microphone?
Did different device record sound on SAME server (virtual machine 172.16.2.98 in this log)
with the SAME user ("ced" in this log)?
met98
Post by met98 »
now work
with the new windows server 2019 updates, the "microphone privacy" function must be activated for each new user. Previously it was activated automatically
Thank you
