Zebra Printer
Fabio
Zebra Printer
Post by Fabio »
Good day,
we would be very interested in buying 50 licenses. Unfortunately we only have one problem.
We tried to integrate our zebra printer with the free version. Unfortunately that was unsuccessful. Could you help us?
With best regards,
Fabio
Re: Zebra Printer
Fabio
Re: Zebra Printer
Post by Fabio »
07-54-32-835| WTware 6.0.30/RPi supervisor.
07-54-32-835| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
07-54-32-835| [ KERNEL] [ 0.000000] Linux version 5.4.83-v7l (aka@c22) (gcc version 8.3.0 (Debian 8.3.0-2)) #9 SMP Sat Jan 16 18:49:14 UTC 2021
07-54-32-835| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
07-54-32-835| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
07-54-32-835| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
07-54-32-835| [ KERNEL] [ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
07-54-32-835| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
07-54-32-835| [ KERNEL] [ 0.000000] Reserved memory: created CMA memory pool at 0x000000002ac00000, size 64 MiB
07-54-32-835| [ KERNEL] [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
07-54-32-835| [ KERNEL] [ 0.000000] On node 0 totalpages: 1012736
07-54-32-835| [ KERNEL] [ 0.000000] DMA zone: 1920 pages used for memmap
07-54-32-835| [ KERNEL] [ 0.000000] DMA zone: 0 pages reserved
07-54-32-835| [ KERNEL] [ 0.000000] DMA zone: 196608 pages, LIFO batch:63
07-54-32-835| [ KERNEL] [ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
07-54-32-835| [ KERNEL] [ 0.000000] percpu: Embedded 15 pages/cpu s29324 r8192 d23924 u61440
07-54-32-835| [ KERNEL] [ 0.000000] pcpu-alloc: s29324 r8192 d23924 u61440 alloc=15*4096
07-54-32-835| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
07-54-32-835| [ KERNEL] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010816
07-54-32-835| [ KERNEL] [ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 smsc95xx.macaddr=DC:A6:32:7E:D4:E6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 no_setup dwc_otg.lpm_enable=0 quiet wtboot=mmc
07-54-32-835| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
07-54-32-835| [ KERNEL] [ 0.000000] software IO TLB: mapped [mem 0x244a0000-0x284a0000] (64MB)
07-54-32-835| [ KERNEL] [ 0.000000] Memory: 3867788K/4050944K available (6144K kernel code, 161K rwdata, 812K rodata, 2048K init, 375K bss, 117620K reserved, 65536K cma-reserved, 3264512K highmem)
07-54-32-835| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
07-54-32-835| [ KERNEL] [ 0.000000] rcu: Hierarchical RCU implementation.
07-54-32-835| [ KERNEL] [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
07-54-32-835| [ KERNEL] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
07-54-32-835| [ KERNEL] [ 0.000000] GIC: Using split EOI/Deactivate mode
07-54-32-835| [ KERNEL] [ 0.000000] random: get_random_bytes called from 0xc0a00b60 with crng_init=0
07-54-32-835| [ KERNEL] [ 0.000007] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
07-54-32-835| [ KERNEL] [ 0.000021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
07-54-32-835| [ KERNEL] [ 0.000087] bcm2835: system timer (irq = 17)
07-54-32-835| [ KERNEL] [ 0.000624] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
07-54-32-835| [ KERNEL] [ 0.000639] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
07-54-32-835| [ KERNEL] [ 0.000654] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
07-54-32-835| [ KERNEL] [ 0.000665] Switching to timer-based delay loop, resolution 18ns
07-54-32-835| [ KERNEL] [ 0.000825] Console: colour dummy device 80x30
07-54-32-835| [ KERNEL] [ 0.000843] printk: console [tty0] enabled
07-54-32-835| [ KERNEL] [ 0.000878] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
07-54-32-835| [ KERNEL] [ 0.000890] pid_max: default: 32768 minimum: 301
07-54-32-835| [ KERNEL] [ 0.001017] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.001032] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.001556] CPU: Testing write buffer coherency: ok
07-54-32-835| [ KERNEL] [ 0.001817] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
07-54-32-835| [ KERNEL] [ 0.002192] Setting up static identity map for 0x200000 - 0x20003c
07-54-32-835| [ KERNEL] [ 0.002269] rcu: Hierarchical SRCU implementation.
07-54-32-835| [ KERNEL] [ 0.002528] smp: Bringing up secondary CPUs ...
07-54-32-835| [ KERNEL] [ 0.003103] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
07-54-32-835| [ KERNEL] [ 0.003750] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
07-54-32-835| [ KERNEL] [ 0.004373] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
07-54-32-835| [ KERNEL] [ 0.004449] smp: Brought up 1 node, 4 CPUs
07-54-32-835| [ KERNEL] [ 0.004458] SMP: Total of 4 processors activated (432.00 BogoMIPS).
07-54-32-835| [ KERNEL] [ 0.004464] CPU: All CPU(s) started in HYP mode.
07-54-32-835| [ KERNEL] [ 0.004470] CPU: Virtualization extensions available.
07-54-32-835| [ KERNEL] [ 0.004863] devtmpfs: initialized
07-54-32-835| [ KERNEL] [ 0.013679] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
07-54-32-835| [ KERNEL] [ 0.013959] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
07-54-32-835| [ KERNEL] [ 0.013976] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.015359] pinctrl core: initialized pinctrl subsystem
07-54-32-835| [ KERNEL] [ 0.016261] NET: Registered protocol family 16
07-54-32-835| [ KERNEL] [ 0.018228] DMA: preallocated 1024 KiB pool for atomic coherent allocations
07-54-32-835| [ KERNEL] [ 0.020143] Serial: AMBA PL011 UART driver
07-54-32-835| [ KERNEL] [ 0.022027] bcm2835-mbox fe00b880.mailbox: mailbox enabled
07-54-32-835| [ KERNEL] [ 0.040634] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-08-19 17:38, variant start
07-54-32-835| [ KERNEL] [ 0.050628] raspberrypi-firmware soc:firmware: Firmware hash is e90cba19a98a0d1f2ef086b9cafcbca00778f094
07-54-32-835| [ KERNEL] [ 0.096170] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
07-54-32-835| [ KERNEL] [ 0.099160] vgaarb: loaded
07-54-32-835| [ KERNEL] [ 0.099649] usbcore: registered new interface driver usbfs
07-54-32-835| [ KERNEL] [ 0.099734] usbcore: registered new interface driver hub
07-54-32-835| [ KERNEL] [ 0.099804] usbcore: registered new device driver usb
07-54-32-835| [ KERNEL] [ 0.101346] clocksource: Switched to clocksource arch_sys_counter
07-54-32-835| [ KERNEL] [ 0.111642] thermal_sys: Registered thermal governor 'step_wise'
07-54-32-835| [ KERNEL] [ 0.112003] NET: Registered protocol family 2
07-54-32-835| [ KERNEL] [ 0.112422] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.112446] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.112495] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.112557] TCP: Hash tables configured (established 8192 bind 8192)
07-54-32-835| [ KERNEL] [ 0.112658] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.112687] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
07-54-32-835| [ KERNEL] [ 0.112814] NET: Registered protocol family 1
07-54-32-835| [ KERNEL] [ 0.112841] PCI: CLS 0 bytes, default 64
07-54-32-835| [ KERNEL] [ 0.824397] Initialise system trusted keyrings
07-54-32-835| [ KERNEL] [ 0.824526] workingset: timestamp_bits=30 max_order=20 bucket_order=0
07-54-32-835| [ KERNEL] [ 0.867116] Key type asymmetric registered
07-54-32-835| [ KERNEL] [ 0.867125] Asymmetric key parser 'x509' registered
07-54-32-835| [ KERNEL] [ 0.867189] bounce: pool size: 64 pages
07-54-32-835| [ KERNEL] [ 0.867245] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
07-54-32-835| [ KERNEL] [ 0.869433] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
07-54-32-835| [ KERNEL] [ 0.869449] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
07-54-32-835| [ KERNEL] [ 0.869477] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
07-54-32-835| [ KERNEL] [ 0.869507] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
07-54-32-835| [ KERNEL] [ 0.923459] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
07-54-32-835| [ KERNEL] [ 0.923683] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
07-54-32-835| [ KERNEL] [ 0.923696] pci_bus 0000:00: root bus resource [bus 00-ff]
07-54-32-835| [ KERNEL] [ 0.923710] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
07-54-32-835| [ KERNEL] [ 0.923745] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
07-54-32-835| [ KERNEL] [ 0.923850] pci 0000:00:00.0: PME# supported from D0 D3hot
07-54-32-835| [ KERNEL] [ 0.926572] PCI: bus0: Fast back to back transfers disabled
07-54-32-835| [ KERNEL] [ 0.926748] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
07-54-32-835| [ KERNEL] [ 0.926857] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
07-54-32-835| [ KERNEL] [ 0.927133] pci 0000:01:00.0: PME# supported from D0 D3cold
07-54-32-835| [ KERNEL] [ 0.929855] PCI: bus1: Fast back to back transfers disabled
07-54-32-835| [ KERNEL] [ 0.929894] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
07-54-32-835| [ KERNEL] [ 0.929910] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
07-54-32-835| [ KERNEL] [ 0.929970] pci 0000:00:00.0: PCI bridge to [bus 01]
07-54-32-835| [ KERNEL] [ 0.929982] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
07-54-32-835| [ KERNEL] [ 0.930145] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
07-54-32-835| [ KERNEL] [ 0.930294] pcieport 0000:00:00.0: PME: Signaling with IRQ 53
07-54-32-835| [ KERNEL] [ 0.930550] pcieport 0000:00:00.0: AER: enabled with IRQ 53
07-54-32-835| [ KERNEL] [ 0.930836] pci 0000:01:00.0: enabling device (0140 -> 0142)
07-54-32-835| [ KERNEL] [ 0.931362] bcm2708_fb soc:fb: FB found 1 display(s)
07-54-32-835| [ KERNEL] [ 0.956199] Console: switching to colour frame buffer device 240x67
07-54-32-835| [ KERNEL] [ 0.962305] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1920x1080
07-54-32-835| [ KERNEL] [ 0.965841] iproc-rng200 fe104000.rng: hwrng registered
07-54-32-835| [ KERNEL] [ 0.966003] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
07-54-32-835| [ KERNEL] [ 0.966434] vc-sm: Videocore shared memory driver
07-54-32-835| [ KERNEL] [ 0.966809] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
07-54-32-835| [ KERNEL] [ 0.967583] zram: Added device: zram0
07-54-32-835| [ KERNEL] [ 0.969280] libphy: Fixed MDIO Bus: probed
07-54-32-835| [ KERNEL] [ 0.969637] xhci_hcd 0000:01:00.0: xHCI Host Controller
07-54-32-835| [ KERNEL] [ 0.969675] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
07-54-32-835| [ KERNEL] [ 0.975174] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000003000000890
07-54-32-835| [ KERNEL] [ 0.975674] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
07-54-32-835| [ KERNEL] [ 0.975687] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
07-54-32-835| [ KERNEL] [ 0.975696] usb usb1: Product: xHCI Host Controller
07-54-32-835| [ KERNEL] [ 0.975705] usb usb1: Manufacturer: Linux 5.4.83-v7l xhci-hcd
07-54-32-835| [ KERNEL] [ 0.975713] usb usb1: SerialNumber: 0000:01:00.0
07-54-32-835| [ KERNEL] [ 0.976191] hub 1-0:1.0: USB hub found
07-54-32-835| [ KERNEL] [ 0.976272] hub 1-0:1.0: 1 port detected
07-54-32-835| [ KERNEL] [ 0.976698] xhci_hcd 0000:01:00.0: xHCI Host Controller
07-54-32-835| [ KERNEL] [ 0.976717] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
07-54-32-835| [ KERNEL] [ 0.976734] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
07-54-32-835| [ KERNEL] [ 0.977038] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
07-54-32-835| [ KERNEL] [ 0.977052] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
07-54-32-835| [ KERNEL] [ 0.977065] usb usb2: Product: xHCI Host Controller
07-54-32-835| [ KERNEL] [ 0.977074] usb usb2: Manufacturer: Linux 5.4.83-v7l xhci-hcd
07-54-32-835| [ KERNEL] [ 0.977082] usb usb2: SerialNumber: 0000:01:00.0
07-54-32-835| [ KERNEL] [ 0.977557] hub 2-0:1.0: USB hub found
07-54-32-835| [ KERNEL] [ 0.977615] hub 2-0:1.0: 4 ports detected
07-54-32-835| [ KERNEL] [ 0.978583] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
07-54-32-835| [ KERNEL] [ 0.978685] dwc_otg: FIQ enabled
07-54-32-835| [ KERNEL] [ 0.978691] dwc_otg: NAK holdoff enabled
07-54-32-835| [ KERNEL] [ 0.978697] dwc_otg: FIQ split-transaction FSM enabled
07-54-32-835| [ KERNEL] [ 0.978705] Module dwc_common_port init
07-54-32-835| [ KERNEL] [ 0.983628] usbcore: registered new interface driver usbtouchscreen
07-54-32-835| [ KERNEL] [ 0.985144] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
07-54-32-835| [ KERNEL] [ 0.986348] sdhci: Secure Digital Host Controller Interface driver
07-54-32-835| [ KERNEL] [ 0.986356] sdhci: Copyright(c) Pierre Ossman
07-54-32-835| [ KERNEL] [ 0.986691] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
07-54-32-835| [ KERNEL] [ 0.986927] sdhci-pltfm: SDHCI platform and OF driver helper
07-54-32-835| [ KERNEL] [ 0.987685] hidraw: raw HID events driver (C) Jiri Kosina
07-54-32-835| [ KERNEL] [ 0.988569] usbcore: registered new interface driver usbhid
07-54-32-835| [ KERNEL] [ 0.988575] usbhid: USB HID core driver
07-54-32-835| [ KERNEL] [ 0.990420] vchiq: vchiq_init_state: slot_zero = (ptrval)
07-54-32-835| [ KERNEL] [ 0.996052] [vc_sm_connected_init]: start
07-54-32-835| [ KERNEL] [ 1.009768] [vc_sm_connected_init]: end - returning 0
07-54-32-835| [ KERNEL] [ 1.010364] NET: Registered protocol family 17
07-54-32-835| [ KERNEL] [ 1.010490] Registering SWP/SWPB emulation handler
07-54-32-835| [ KERNEL] [ 1.010583] Loading compiled-in X.509 certificates
07-54-32-835| [ KERNEL] [ 1.011424] uart-pl011 fe201000.serial: cts_event_workaround enabled
07-54-32-835| [ KERNEL] [ 1.011460] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
07-54-32-835| [ KERNEL] [ 1.015218] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
07-54-32-835| [ KERNEL] [ 1.015488] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
07-54-32-835| [ KERNEL] [ 1.015492] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
07-54-32-835| [ KERNEL] [ 1.065880] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
07-54-32-835| [ KERNEL] [ 1.067377] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
07-54-32-835| [ KERNEL] [ 1.068872] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
07-54-32-835| [ KERNEL] [ 1.071565] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
07-54-32-835| [ KERNEL] [ 1.073061] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
07-54-32-835| [ KERNEL] [ 1.081361] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
07-54-32-835| [ KERNEL] [ 1.081512] of_cfs_init
07-54-32-835| [ KERNEL] [ 1.081605] of_cfs_init: OK
07-54-32-835| [ KERNEL] [ 1.083723] Freeing unused kernel memory: 2048K
07-54-32-835| [ KERNEL] [ 1.109532] random: fast init done
07-54-32-835| [ KERNEL] [ 1.135710] mmc1: new high speed SDIO card at address 0001
07-54-32-835| [ KERNEL] [ 1.161512] Run /init as init process
07-54-32-835| [ KERNEL] [ 1.184104] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
07-54-32-835| [ KERNEL] [ 1.184453] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
07-54-32-835| [ KERNEL] [ 1.186078] mmcblk0: p1
07-54-32-835| [ KERNEL] [ 1.341392] usb 1-1: new high-speed USB device number 2 using xhci_hcd
07-54-32-835| [ pfac] [ 1.468675] Run /sbin/initrd.
07-54-32-835| [ pfac] [ 1.468852] Ok, PID 794.
07-54-32-835| [ initrd] [ 1.472950] WTware 6.0.30/RPi shell.
07-54-32-835| [ initrd] [ 1.473299] Load font 'ter-c32b.psf', console 120x33.
07-54-32-835| [ initrd] [ 1.489638] HDD/MMC/SD boot.
07-54-32-835| [ initrd] [ 1.489752] No device '/dev/fb1'.
07-54-32-835| [ KERNEL] [ 1.524026] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
07-54-32-835| [ KERNEL] [ 1.524037] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
07-54-32-835| [ KERNEL] [ 1.524046] usb 1-1: Product: USB2.0 Hub
07-54-32-835| [ KERNEL] [ 1.525497] hub 1-1:1.0: USB hub found
07-54-32-835| [ KERNEL] [ 1.525765] hub 1-1:1.0: 4 ports detected
07-54-32-835| [ initrd] [ 1.550274] Success: /dev/mmcblk0p1 mounted to /bootmedia.
07-54-32-835| /--- FILE "/bootmedia/config.txt" -----------------------
07-54-32-835| | # For more options and information see:
07-54-32-835| | #
07-54-32-835| | # https://www.raspberrypi.org/documentati ... /README.md
07-54-32-835| | #
07-54-32-835| | # Some settings may impact device functionality. See link above for details.
07-54-32-835| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
07-54-32-835| | #hdmi_safe=1
07-54-32-835| | # Uncomment this if your display has a black border of unused pixels visible
07-54-32-835| | # and your display can output without overscan.
07-54-32-835| | disable_overscan=1
07-54-32-835| | # Uncomment if hdmi display is not detected and composite is being output.
07-54-32-835| | #hdmi_force_hotplug=1
07-54-32-835| | # Uncomment to force a specific HDMI mode (this will force VGA).
07-54-32-835| | #hdmi_group=1
07-54-32-835| | #hdmi_mode=1
07-54-32-835| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
07-54-32-835| | #hdmi_drive=2
07-54-32-835| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
07-54-32-835| | # no display.
07-54-32-835| | #config_hdmi_boost=4
07-54-32-835| | # Uncomment to overclock the arm. 700 MHz is the default.
07-54-32-835| | #arm_freq=800
07-54-32-835| | disable_splash=1
07-54-32-835| | framebuffer_depth=32
07-54-32-835| | # Uncomment for 16-bit color.
07-54-32-835| | #framebuffer_depth=16
07-54-32-835| | # Enable onboard audio (HDMI or jack).
07-54-32-835| | dtparam=audio=on
07-54-32-835| | # Removes the warning overlay.
07-54-32-835| | #avoid_warnings=1
07-54-32-835| | # Additionally allows turbo when low-voltage is present.
07-54-32-835| | #avoid_warnings=2
07-54-32-835| | [pi4]
07-54-32-835| | max_framebuffers=2
07-54-32-835| | [all]
07-54-32-835| | # Uncomment these two lines to set display resolution:
07-54-32-835| | #hdmi_group=2
07-54-32-835| | #hdmi_mode=58
07-54-32-835| | #
07-54-32-835| | # Specify correct value in hdmi_mode= line from the list of valid values:
07-54-32-835| | # 800x600: hdmi_mode=9
07-54-32-835| | # 1024x768: hdmi_mode=16
07-54-32-835| | # 1280x1024: hdmi_mode=35
07-54-32-835| | # 1360x768: hdmi_mode=39
07-54-32-835| | # 1400x1050: hdmi_mode=42
07-54-32-835| | # 1440x900: hdmi_mode=47
07-54-32-835| | # 1600x1200: hdmi_mode=51
07-54-32-835| | # 1680x1050: hdmi_mode=58
07-54-32-835| | # 1366x768: hdmi_mode=81
07-54-32-835| | # 1920x1080: hdmi_mode=82
07-54-32-835| | # 1920x1200: hdmi_mode=69
07-54-32-835| | #
07-54-32-835| | # Find more resolutions in manual:
07-54-32-835| | # https://www.raspberrypi.org/documentati ... t/video.md
07-54-32-835| | #
07-54-32-835| | # Uncomment six lines with such syntax and right hdmi_mode= values for
07-54-32-835| | # dual displays on Raspberry Pi 4:
07-54-32-835| | #
07-54-32-835| | #[HDMI:0]
07-54-32-835| | # hdmi_group=2
07-54-32-835| | # hdmi_mode=42
07-54-32-835| | #[HDMI:1]
07-54-32-835| | # hdmi_mode=58
07-54-32-835| | hdmi_group=2
07-54-32-835| | hdmi_mode=82
07-54-32-835| | framebuffer_depth=16
07-54-32-835| \----------------------------------------------------
07-54-32-835| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
07-54-32-835| | clientIP = *
07-54-32-835| | config = local
07-54-32-835| [ initrd] [ 1.577335] Do not cache package files.
07-54-32-835| [ initrd] [ 1.577394] WTpassword empty.
07-54-32-835| [ initrd] [ 1.577444] Unpack /bootmedia/packages/pi2-lib.
07-54-32-835| [ KERNEL] [ 1.851367] usb 1-1.2: new full-speed USB device number 3 using xhci_hcd
07-54-32-835| [ KERNEL] [ 2.010392] usb 1-1.2: New USB device found, idVendor=0a5f, idProduct=0085, bcdDevice=17.17
07-54-32-835| [ KERNEL] [ 2.010398] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
07-54-32-835| [ KERNEL] [ 2.010402] usb 1-1.2: Product: ZTC GX420t
07-54-32-835| [ KERNEL] [ 2.010405] usb 1-1.2: Manufacturer: Zebra Technologies
07-54-32-835| [ KERNEL] [ 2.010409] usb 1-1.2: SerialNumber: 31J163000415
07-54-32-835| [ KERNEL] [ 2.111381] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
07-54-32-835| [ initrd] [ 2.164023] USB: 2109:3431 VIA Labs, Inc. Hub.
07-54-32-835| [ initrd] [ 2.164076] USB: 0a5f:0085 Zebra.
07-54-32-835| [ initrd] [ 2.164125] Load Ethernet drivers.
07-54-32-835| [ initrd] [ 2.164168] modprobe genet.
07-54-32-835| [ KERNEL] [ 2.168736] bcmgenet fd580000.ethernet: failed to get enet clock
07-54-32-835| [ KERNEL] [ 2.168743] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
07-54-32-835| [ KERNEL] [ 2.168748] bcmgenet fd580000.ethernet: failed to get enet-wol clock
07-54-32-835| [ KERNEL] [ 2.168753] bcmgenet fd580000.ethernet: failed to get enet-eee clock
07-54-32-835| [ KERNEL] [ 2.168767] bcmgenet: Skipping UMAC reset
07-54-32-835| [ KERNEL] [ 2.181345] libphy: bcmgenet MII bus: probed
07-54-32-835| [ KERNEL] [ 2.259063] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.01
07-54-32-835| [ KERNEL] [ 2.259074] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
07-54-32-835| [ KERNEL] [ 2.259081] usb 1-1.4: Product: USB Receiver
07-54-32-835| [ KERNEL] [ 2.259089] usb 1-1.4: Manufacturer: Logitech
07-54-32-835| [ KERNEL] [ 2.281421] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
07-54-32-835| [ KERNEL] [ 2.282433] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.4/input2
07-54-32-835| [ KERNEL] [ 2.282586] bcmgenet: Skipping UMAC reset
07-54-32-835| [ KERNEL] [ 2.284135] bcmgenet fd580000.ethernet: configuring instance for external RGMII
07-54-32-835| [ KERNEL] [ 2.284605] bcmgenet fd580000.ethernet eth0: Link is Down
07-54-32-835| [ KERNEL] [ 2.436801] input: Logitech MX Master 2S as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:4069.0004/input/input0
07-54-32-835| [ KERNEL] [ 2.437676] logitech-hidpp-device 0003:046D:4069.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech MX Master 2S] on usb-0000:01:00.0-1.4/input2:1
07-54-32-835| [ KERNEL] [ 2.448425] input: Logitech K540/K545 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:046D:C52B.0003/0003:046D:4076.0005/input/input1
07-54-32-835| [ KERNEL] [ 2.448819] logitech-hidpp-device 0003:046D:4076.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K540/K545] on usb-0000:01:00.0-1.4/input2:2
07-54-32-835| [ KERNEL] [ 7.511466] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
07-54-32-835| [ initrd] [ 7.591068] WTpassword empty.
07-54-32-835| [ initrd] [ 8.800151] dhcp: 387 bytes from 192.168.6.26.
07-54-32-835| [ initrd] [ 8.800255] 00000000:0000016F0000000000110000C0A8061AFFFFFFFF00430044016F000002010600 ...o...............C.D.o......
07-54-32-835| [ initrd] [ 8.800342] 00000020:67458B6B0000000000000000C0A8078FC0A8061A00000000DCA6327ED4E60000 gE.k.....................2~....
07-54-32-835| [ initrd] [ 8.800426] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 8.800510] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 8.800594] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 8.800677] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 8.800761] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 8.800844] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 8.800928] 00000100:0000000000000000638253633501020104FFFFFE003A04000546003B0400093A ........c.Sc5........:...F.;...:
07-54-32-835| [ initrd] [ 8.801011] 00000120:803304000A8C003604C0A8061A0304C0A8062B060CC0A80611C0A8061AC0A806 .3.....6.........+...........
07-54-32-835| [ initrd] [ 9.970174] dhcp: 387 bytes from 192.168.6.26.
07-54-32-835| [ initrd] [ 9.970270] 00000000:0000016F0000000000110000C0A8061AFFFFFFFF00430044016F000002010600 ...o...............C.D.o......
07-54-32-835| [ initrd] [ 9.970356] 00000020:67458B6B0000000000000000C0A8078F0000000000000000DCA6327ED4E60000 gE.k......................2~....
07-54-32-835| [ initrd] [ 9.970440] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 9.970523] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 9.970607] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 9.970689] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 9.970773] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 9.970870] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
07-54-32-835| [ initrd] [ 9.970955] 00000100:0000000000000000638253633501053A04000546003B0400093A803304000A8C ........c.Sc5..:...F.;...:.3....
07-54-32-835| [ initrd] [ 9.971039] 00000120:003604C0A8061A0104FFFFFE000304C0A8062B060CC0A80611C0A8061AC0A806 .6...............+...........
07-54-32-835| [ initrd] [ 10.010090] [DHCP] DHCP server address 192.168.6.26.
07-54-32-835| [ initrd] [ 10.010181] [DHCP] IP 192.168.7.143 mask 255.255.254.0.
07-54-32-835| [ initrd] [ 10.010264] [DHCP] Default gateway 192.168.6.43.
07-54-32-835| [ initrd] [ 10.010347] [DHCP] DNS 192.168.6.17.
07-54-32-835| [ initrd] [ 10.010429] [DHCP] DNS 192.168.6.26.
07-54-32-835| [ initrd] [ 10.010512] [DHCP] DNS 192.168.6.27.
07-54-32-835| [ initrd] [ 10.010593] [DHCP] Domain HG.local.
07-54-32-835| [ initrd] [ 10.010674] [DHCP] TFTP from siaddr 192.168.6.26.
07-54-32-835| [ initrd] [ 10.010755] [DHCP] TFTP 192.168.6.26.
07-54-32-835| [ initrd] [ 10.010837] [DHCP] No boot file from DHCP.
07-54-32-835| [ initrd] [ 10.010918] [DHCP] TFTP binary "", configs prefix "", using "/" slash.
07-54-32-835| WTC listener is active.
07-54-32-835| WTC broadcast listener is active.
07-54-32-835| Send broadcast WTCU discover.
07-54-32-835| [ pfac] [ 10.012298] Run /sbin/httpd.
07-54-32-835| [ initrd] [ 10.012363] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
07-54-32-835| [ pfac] [ 10.012477] Ok, PID 864.
07-54-32-835| [ initrd] [ 10.012524] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
07-54-32-835| [ initrd] [ 10.014101] /bootmedia/configs/config.wtc -> /tmp/config.wtc, 242 bytes copied.
07-54-32-835| [ initrd] [ 10.014219] Common local disk config:
07-54-32-835| /--- FILE "/tmp/config.wtc" -----------------------
07-54-32-835| | [BOM]
07-54-32-835| | server=192.168.6.24
07-54-32-835| | bpp=16
07-54-32-835| | display=1280x1024
07-54-32-835| | keyboard=de
07-54-32-835| | language=de,default
07-54-32-835| | printer=usb
07-54-32-835| | scanner=on
07-54-32-835| | connection
07-54-32-835| /--- FILE "/etc/config.compiled" -----------------------
07-54-32-835| [ initrd] [ 10.015847] Hostname: "wtwDCA6327ED4E6".
07-54-32-835| [ httpd] [ 10.020760] Internal HTTP Server, WTware 6.0.30/RPi
07-54-32-835| [ initrd] [ 10.250235] [NTP] 42 DHCP option is not set.
07-54-32-835| Everyone can control terminal by RSH.
07-54-32-835| RSH: listener is active.
07-54-32-835| [ httpd] [ 10.254556] Reread settings.
07-54-32-835| [ initrd] [ 10.254663] Unpack /bootmedia/packages/print.
07-54-32-835| [ httpd] [ 10.254792] Everyone can control terminal by HTTP.
07-54-32-835| [ initrd] [ 10.338393] Unpack /bootmedia/packages/pi2-print.
07-54-32-835| [ initrd] [ 10.346358] Run '/sbin/printer 0 1 0 0 0 0000:0000', log '', env '', pid ''.
07-54-32-835| [ pfac] [ 10.346406] Run /sbin/printer 0 1 0 0 0 0000:0000.
07-54-32-835| [ pfac] [ 10.346530] Ok, PID 865.
07-54-32-835| [ initrd] [ 10.346579] Load usb printer driver.
07-54-32-835| [ initrd] [ 10.346625] modprobe usblp.
07-54-32-835| [ printer 0] [ 10.347719] Printserver, WTware 6.0.30/RPi.
07-54-32-835| [ printer 0] [ 10.347770] Printserver 0, device /dev/usb/lp0, listen at port 9100.
07-54-32-835| [ printer 0] [ 10.347813] Printer device not found. Waiting...
07-54-32-835| [ initrd] [ 10.355970] Unpack /bootmedia/packages/pi2-f.
07-54-32-835| [ KERNEL] [ 10.356894] usblp 1-1.2:1.0: usblp0: USB Bidirectional printer dev 3 if 0 alt 0 proto 2 vid 0x0A5F pid 0x0085
07-54-32-835| [ KERNEL] [ 10.356955] usbcore: registered new interface driver usblp
07-54-32-835| [ KERNEL] [ 10.509746] random: crng init done
07-54-32-835| [ gm] [ 10.514071] WTware 6.0.30/RPi session manager.
07-54-32-835| [ gm] [ 10.514654] EV_REL flag found. Add event1: Logitech K540/K545.
07-54-32-835| [ gm] [ 10.514738] EV_REL flag found. Add event0: Logitech MX Master 2S.
07-54-32-835| [ gm] [ 10.514892] Display mode: 1920x1080, 16 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
07-54-32-835| [ gm] [ 10.800675] Framebuffer device found.
07-54-32-835| [ gm] [ 10.800747] LINELENBYTES 3840
07-54-32-835| [ gm] [ 10.800800] VLEN 4147200
07-54-32-835| [ gm] [ 10.802129] Use /lib/ui16.so.
07-54-32-835| [ gm] [ 10.816846] Unpack /bootmedia/packages/pi2-lstdcpp.
07-54-32-835| [ gm] [ 10.883702] Unpack /bootmedia/packages/pi2-xml2.
07-54-32-835| [ gm] [ 13.283052] Unpack /bootmedia/packages/pi2-dbus.
07-54-32-835| [ gm] [ 13.413774] +--- Executing "/usr/bin/dbus-uuidgen --ensure"
07-54-32-835| [ gm] [ 13.417782] +- Errorlevel: 0, output:
07-54-32-835| | <No output>
07-54-32-835| [ gm] [ 13.417937] +------------------------
07-54-32-835| [ gm] [ 13.417991] +--- Executing "/usr/bin/dbus-daemon --system "
07-54-32-835| [ gm] [ 13.431275] +- Errorlevel: 0, output:
07-54-32-835| [ gm] [ 13.431462] +------------------------
07-54-32-835| [ gm] [ 13.431521] Run '/usr/bin/dbus-daemon --session --address=unix:path=/run/user/1007/bus', log '', env '', pid ''.
07-54-32-835| [ pfac] [ 13.431786] Run /usr/bin/dbus-daemon --session --address=unix:path=/run/user/1007/bus.
07-54-32-835| [ pfac] [ 13.431843] Ok, PID 876.
07-54-32-835| [ gm] [ 13.432008] Unpack /bootmedia/packages/pi2-scan.
07-54-32-835| [ gm] [ 13.734627] Start saned: '/usr/local/sbin/saned -lD', environment is empty.
07-54-32-835| [ SYSLOG] [ 13.743179] <31>Jan 16 00:00:12 saned[877]: saned (IPv4 only) from sane-backends 1.0.31-237-gd46fbd9d7 starting up
07-54-32-835| [ SYSLOG] [ 13.744217] <31>Jan 16 00:00:12 saned[878]: Now daemonized
07-54-32-835| [ gm] [ 13.751949] Run '/sbin/resolver 0x1f91e60 dns [192.168.6.24]', log '', env '', pid ''.
07-54-32-835| [ pfac] [ 13.752228] Run /sbin/resolver 0x1f91e60 dns [192.168.6.24].
07-54-32-835| [ pfac] [ 13.752282] Ok, PID 879.
07-54-32-835| [ gm] [ 13.752371] Nobody can control terminal by VNC.
07-54-32-835| [ gm] [ 13.752431] Nobody can control terminal by WTRC.
07-54-32-835| [ pfac] [ 13.754942] Process pid 879 terminated, status 00000000.
07-54-32-835| [ gm] [ 13.755071] 192.168.6.24 => 192.168.6.24.
07-54-32-835| [ gm] [ 13.758600] Free ram before fork terminal client /sbin/rdpclient (session 1): 3843944 Kb.
07-54-32-835| [ gm] [ 13.758663] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
07-54-32-835| [ pfac] [ 13.758889] Run /sbin/rdpclient 1.
07-54-32-835| [ pfac] [ 13.758941] Ok, PID 880.
07-54-32-835| [ rdpclient 880] [ 13.764318] RDP Terminal Client, WTware 6.0.30/RPi, pipe 1, pid 880.
07-54-32-835| [ rdpclient 880] [ 13.764562] Use /lib/ui16.so.
07-54-32-835| [ rdpclient 880] [ 13.765448] Make RDP session with 192.168.6.24, port 3389.
07-54-32-835| [ rdpclient 880] [ 13.765527] No username.
07-54-32-835| [ rdpclient 880] [ 13.765586] No password.
07-54-32-835| [ rdpclient 880] [ 13.765626] No PIN.
07-54-32-835| [ rdpclient 880] [ 13.765664] No domain.
07-54-32-835| [ rdpclient 880] [ 13.765701] No shell.
07-54-32-835| [ rdpclient 880] [ 13.765739] No directory.
07-54-32-835| [ rdpclient 880] [ 13.765775] Window: 1856x1080@16.
07-54-32-835| [ rdpclient 880] [ 13.765818] PFlags 0x0000002F.
07-54-32-835| [ rdpclient 880] [ 13.765856] Keyboard 00000407:00000000.
07-54-32-835| [ rdpclient 880] [ 13.765893] My hostname "wtwDCA6327ED4E6".
07-54-32-835| [ rdpclient 880] [ 13.765931] TCP: connecting to 192.168.6.24:3389.
07-54-32-835| [ rdpclient 880] [ 13.766179] TCP: connection with 192.168.6.24:3389 established.
07-54-32-835| [ rdpclient 880] [ 13.766234] Turn keepalive on.
07-54-32-835| [ rdpclient 880] [ 13.767210] Free ram after buffers allocation: 3843188 KB.
07-54-32-835| [ rdpclient 880] [ 13.773988] Process RDP server certificate.
07-54-32-835| [ rdpclient 880] [ 13.774049] RDP5 encryption (X.509).
07-54-32-835| [ rdpclient 880] [ 13.776286] License: STATUS_VALID_CLIENT.
07-54-32-835| [ KERNEL] [ 21.558874] logitech-hidpp-device 0003:046D:4076.0005: HID++ 4.1 device connected.
07-54-32-835| [ rdpclient 880] [ 26.081686] LOGON_EX_LOGONERRORS: ErrorNotificationType 0xfffffffe, ErrorNotificationData 0x00000008.
07-54-32-835| [ rdpclient 880] [ 29.745144] SessionId 0x00000008: OHRA\serviceadmin.
07-54-32-835| [ KERNEL] [ 37.939171] logitech-hidpp-device 0003:046D:4069.0004: HID++ 4.5 device connected.
07-54-32-835| [ KERNEL] [ 61.921239] usb 1-1.4: USB disconnect, device number 4
07-54-32-835| [ gm] [ 62.030248] evdev.cpp ( 1325): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
07-54-32-835| [ gm] [ 62.030308] Close input device 'Logitech MX Master 2S', errno 19.
07-54-32-835| [ gm] [ 62.190470] evdev.cpp ( 1325): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
07-54-32-835| [ gm] [ 62.190619] Close input device 'Logitech K540/K545', errno 19.
07-54-32-836| Connection from wtc.exe at 192.168.6.123.
Re: Zebra Printer
I see no problems with printer in this log.
Did you try to print before saving it?
Did you configure windows side? Here is the manual: https://wtware.com/docs5/printer.html
Also, make the same log with "printer=usb,debug"
Fabio
Re: Zebra Printer
Post by Fabio »
Hello again,
I got it through your instructions. Thanks!
I'll go over the whole thing again with my manager and then we'll probably buy the program.
Thank you!
