RDP session crashing when playing sound
Muetzenfrosch
Hi guys,
I've just updated to WTWare 6.0.22 on my RPi4 (4GB). And now, when Windows (Win10 20H2) starts playing any sound, the WTWare RDP crashes (I get totally disconnected and end up on the Windows RDP login screen again).
I see this in the logs:
[rdpclient 1219] [ 525.463165] Sound version: 8.
[rdpclient 1219] [ 525.463319] ADPCM sound compression.
[rdpclient 1219] [ 525.463415] Sound redirection: 44100 frames per second.
[rdpclient 1219] [ 525.805000] rdpclient-rdpsnd.cpp ( 424): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1219] [ 525.805494] Caught signal SIGSEGV.
[ gm] [ 525.806700] TSClientSession.cpp ( 276): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 525.806814] Main pipe closed.
[ gm] [ 525.806904] TSClientSession.cpp ( 276): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 525.806993] TSClientSession.cpp ( 297): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 525.807082] Session is over. Final message: Main pipe closed.
And also this:
[rdpclient 1305] [ 525.839019] RDP Terminal Client, WTware 6.0.22/RPi, pipe 4, pid 1305.
[rdpclient 1305] [ 525.839248] Use /lib/ui32.so.
[rdpclient 1305] [ 525.839993] Redirect sound.
[rdpclient 1305] [ 528.841177] rdpclient-rdpsnd.cpp ( 576): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1305] [ 528.841356] rdpclient-vchans.cpp ( 67): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[rdpclient 1305] [ 528.841461] Make RDP session with 192.168.1.33, port 3389.
The full log is attached.
It would be really nice, if you could have a look. Thanks a lot!
Best regards
Björn
And also this:
Best regards
Björn
- wtware6022log.txt
- (135.07 KiB) Downloaded 1669 times
Re: RDP session crashing when playing sound
There's no device hw:0:1. I see in log
| 16: [ 0- 0]: digital audio playback
| 48: [ 1- 0]: digital audio playback
Please, read our manual about sound configuration and specify correct sound value:
http://wtware.com/docs5/sound.html
Muetzenfrosch
Ohh, you are so right. Don't know, how this got in there.
With sound=on,hw:0:0 all is working now.
Thanks a lot for the quick support!
Muetzenfrosch
Sorry, I was a little bit too fast with my answer. The client is not crashing anymore, but I have no sound at all. No matter if I choose hw:0:0 (HDMI) or hw:1:0 (and connect the 3.5mm audio jack), I do not hear anything.
And there are new errors in the log:
[ X02] [ 79.833796] [966:976:1113/141827.997423:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -100
[ X02] [ 89.827673] [966:976:1113/141837.991383:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -100
[ rdpclient 917] [ 98.417109] Sound version: 8.
[ rdpclient 917] [ 98.419068] ADPCM sound compression.
[ rdpclient 917] [ 98.419120] Sound redirection: 44100 frames per second.
[ rdpsnd] [ 98.693805] ALSA: use device plug:dmixer.
[ rdpsnd] [ 98.702796] ALSA: Hardware rate 44100Hz.
[ rdpsnd] [ 98.707344] ALSA: chunk size 940 frames, 1880 bytes, 21 msec.
[ rdpsnd] [ 98.707412] ALSA: buffer size 15052 bytes, 170 miliseconds.
[ X02] [ 113.734425] [966:976:1113/141901.898039:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -100
[ X02] [ 134.558014] [966:976:1113/141922.721678:ERROR:ssl_client_socket_impl.cc(969)] handshake failed; returned -1, SSL error code 1, net_error -100
[ rdpclient 917] [ 143.668736] ./wtvector.h ( 195): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 143.668861] rdpclient-rdpsnd-queue.cpp ( 267): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 143.851092] ./wtvector.h ( 195): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 143.851273] rdpclient-rdpsnd-queue.cpp ( 267): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 144.043530] ./wtvector.h ( 195): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 144.043601] rdpclient-rdpsnd-queue.cpp ( 267): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 144.221983] ./wtvector.h ( 195): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 144.222057] rdpclient-rdpsnd-queue.cpp ( 267): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ rdpclient 917] [ 144.411871] ./wtvector.h ( 195): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
Any idea?
Thanks, best regards
Björn
Any idea?
Björn
Here is logging manual: https://wtware.com/logs.html
There are no words "remove everything interesting and show only a few lines".
Muetzenfrosch
Sorry,
here is the full log.
- wtware6022log2.txt
- (128.98 KiB) Downloaded 1731 times
Will it play sound with minimal config?
Two lines, nothing else.
server=192.168.1.33
sound=on-
Muetzenfrosch
Yes, with this minimal config, sound is playing. So I tried a little bit more adding and removing lines to and from the config and it turns out, that while this
is working perfectly fine, the following
is not. As soon as I add a screen with chrome, the sound stops working. I also tried to remove my custom chrome profile (chprf.zip) but this did not make any difference.
The version I was on before updating was 6.0.6. With that version the sound was playing fine.
Best regards
Björn
server=192.168.1.33
sound=onCode: Select all
server=192.168.1.33
sound=on
next screen
application=chrome
chrome_url=https://www.google.deThe version I was on before updating was 6.0.6. With that version the sound was playing fine.
Best regards
Björn
Muetzenfrosch
Just to clarify: I don't expect Chrome to have sound. When I add the Chrome screen, the other RDP screen has no sound anymore.
All sessions will try sound (and have no sound if something goes wrong, we'll try to fix this bug, but now it goes wrong):
Only RDP session will use sound, Chrome should not afect:
sound=on
connection
server=192.168.1.1
connection
application chromeCode: Select all
connection
sound=on
server=192.168.1.1
connection
application chrome-
Muetzenfrosch
Ok, I have tried
and I have no sound in the RDP session. If I remove the chrome app and have only this
sound is working in the RDP session.
[EDIT] Oh and I just realized: Clicking on "Beep!" in the WTware config section "Test sound" works and gives a beep, also with the first config containing chrome. But no windows sounds, no sound in browsers, no sound from any application running in the RDP session (tested several).
Do you need another log? Seems to be a pretty generic issue, not related to my setup, I guess.
connection
sound=on
server=192.168.1.33
connection
connection
sound=on
server=192.168.1.33[EDIT] Oh and I just realized: Clicking on "Beep!" in the WTware config section "Test sound" works and gives a beep, also with the first config containing chrome. But no windows sounds, no sound in browsers, no sound from any application running in the RDP session (tested several).
Please, show me the log.Muetzenfrosch wrote: Thu Nov 19, 2020 9:35 pmand I have no sound in the RDP session.Code: Select all
connection sound=on server=192.168.1.33 connection application chrome
Muetzenfrosch
Yes, sure. Here it is.
- wtware6022log3.txt
- (64 KiB) Downloaded 1643 times
Muetzenfrosch
Awesome!!! Sound is working now perfectly! Good job! Thanks a lot for the quick support and update!
