tsclient internal error
laesyar
Post by laesyar »
Can you please tell me what this error means?
09-38-05-628| [rdpclient 1117] [10438.616151]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616292]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616414]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616473]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616531]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616588]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616647]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616703]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616764]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616833]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616893]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.616953]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617012]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617083]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617146]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617206]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617265]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617309]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617352]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617395]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617437]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617593]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617638]                   ./wtvector.h (  551): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
09-38-05-628| [rdpclient 1117] [10438.617681]              tsclient-main.cpp (  162): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
Thanks!
Re: tsclient internal error
Full log please.
laesyar
Post by laesyar »
I attached the log. Hope you understand I needed to make some private information anonymous.
terminallog.txt
(248.77 KiB) Downloaded 3293 times
Try to save log immediatelly after boot. I want to see first messages, when error appears.
laesyar
Post by laesyar »
The attached log in my previous reply is the full log.
All messages are in there, so you should be able to see what happens after boot.
The error does not happen immediately after boot, it is random.
Timestamp is 10438.616151.
Wifi disconnects every one-two minutes. It is a problem.
In "tsclient-main.cpp ( 162)" terminal can not send keyboard event (key pressed or key released) because there are too many events already in queue and network connection doesn't work. Keyboard event dropped.
laesyar
Post by laesyar »
Thanks, that explains it. Terminals are roaming between access points.
