NFC + SmartCard - only one working on the same time?
Re: NFC + SmartCard - only one working on the same time?
Eskulap
Post by Eskulap »
Nicely done!
It's working! :D
Aka, You are amazing :) THANK YOU!
Eskulap
Post by Eskulap »
Agh. Carbon type won't work anymore.
Aplication shows empty card slot.
Sounds like no Carbon Card Driver @ this time...
Can't login two card types on one terminal.
Eskulap
Post by Eskulap »
Bingo! :)
Perfect!
I can log in with both cards now!
Thank You!
Eskulap
Post by Eskulap »
More things to do...
What about USB camera and my card readers?
Can I use it with no problems? What's models are supported?
Logitech perhabs?
No. Sometimes it works with VirtualHere viewforum.php?f=27 It takes a lot of network traffic and sound becomes a problem.
Microsoft is introducing video capture device redirection in the latest servers. Someday we will support it too.
