Touchscreen redirect usb
Webjom
Post by Webjom »
it is possible to redirect usb port because we try to connect touchscreen. The program used to calibrate the touchscreen does not record the connection when usb is connected and the program does not want to work with it. Is it possible to redirect usb when we connect the touchscreen to wtware to register the server as if it was connected directly to the servers?
Re: Touchscreen redirect usb
Webjom wrote: Fri Feb 28, 2020 12:22 am Is it possible to redirect usb when we connect the touchscreen to wtware to register the server as if it was connected directly to the servers?
Yes: viewforum.php?f=27
But it will become a server touch screen. It will move mouse pointer on server screen.
Webjom
Post by Webjom »
We tried to calibrate the touch screen environment, but we just can't. When logging on a whiteboard displays
touchscreen=0..4095,0..4095
Our mouse pointer is about 10cm to the right, and we can't get it to the left ... like with those caddies?
1. https://wtware.com/logs.html
2. Try:
touchscreen=0..2000,0..2000
