Oh, I see. Thanks for the clarification.
Wtware on RPi4
Re: Wtware on RPi4
5.8.64 is still here: http://wtware.com/files/
It runs on Pi4 and sees 4 Gig RAM. But it fails using USB on older Pis.
That's why we don't port WTware to other ARMs: Linux kernel quality for ARMs is low. Even on Raspberry with better kernel support than others.
We have single Linux kernel for thousands of x86 machines produced by different manufactures for tens of years.
But we can not run single kernel on Pi3+ and Pi4. The same manufacturer, similar processors. And USB driver that brakes if we turn on high memory to access 4Gig on Pi4. On Raspbian there are three kernels on boot SD: kernel.img (for older than Pi2), kernel7.img for Pi2-Pi3+ and kernel7l.img for Pi4.
We'll do it the same way and new version will appear in a few days.
Re: Wtware on RPi4
I'am testing RASP 4 with WTW. But die rasp mentioned at startup, that there is no configuration file at the WTW Server.
At the server system i can see the client and all the settings.
Whats going wrong?
Whats going wrong?
Re: Wtware on RPi4
OK, i check the log files. The Raspi is using the wrong TFTP Server. It's the second DNS Server in our network.
How can I configure the Windows DHCP server for the RASPI to use the right TFTP server?
Re: Wtware on RPi4
TFTP server is 066 DHCP option. Enter IP address here, not "name"!
https://wtware.com/docs5/dhcp.html
Re: Wtware on RPi4
OK, i did it but nothing changed. The Raspi 4 is getting a DHCP Adress and a wrong TFTP Server,
Any Idea?
Any Idea?
Re: Wtware on RPi4
Can you share your settings for a lossless and lagfree youtube playback? I have a heavy lag with sound and playback is not smooth (Pi4b 4gB)Fraal wrote: ↑Tue Aug 06, 2019 4:46 pmOne last thing to add, I configure the remote desktop settings to use lossless video setting however I have also configured it to detect network bandwidth and compress based off bandwidth, meaning some client sessions the video is pixelated and goes to lossless when image is static. Not a great experience when watching videos however the end result is a video with audio in sync and no lag\jitter. I will change host config to full lossless and then should see some changes, I'm hoping windows mode videos are perfect lossless with sound in frame sync, full screen yet to comment!
