Chanege network interface via web...?
mixtype
Post by mixtype »
Hello
I have to change network interface (from wifi to Ethernet) but unfortunately i haven't locally access to Rpi3 :( ...
Is there any way to change under web ?
Thx for your help
Re: Chanege network interface via web...?
No. Network options are only configured locally.
mixtype
Post by mixtype »
Thank you
Are you consider to enable this possibility in the future upgrades ?
I'm not sure we should enable so easy way to shoot yourself in the foot. Device will not be able to run web interface after reboot in case of any mistake in network configuration and will be unusable until you come to RPi physically.
