Logon keyboard layout
Omicron
Post by Omicron »
at first I want to thank you for this great piece of software!
May I ask if you plan to add more keyboard layouts for 'language' parameter.
I would really appreciate CS layout (ASCII - Czech - 243) for language parameter.
Raspberry Pi computers are more powerfull than thin clients that we use now.
But users on thin clients are really BFU and using EN (QWERTY) keyboard for login and than use CS (QWERTZ) is hard to explain them.
Looking to hear from you soon.
Have a nice day!
Re: Logon keyboard layout
Omicron
Post by Omicron »
Yes, thats correct.
Please, try this build:
http://wtware.com/testing/201801191820.zip
In config file:
language=cs,default
Omicron
Post by Omicron »
Hello aka,
thanks for your really quick reply.
CS layout works great now.
But there is probalbly little bug at boot time - it can't find file /usr/ter-c0b.psf
When is RPi client booting, it shows up: "sh: can't open /usr/ter-c0b.psf: no such file
It shows a while and after that is login screen display.
May I ask if is there any option to change login table? Just description "USERNAME" and "PASSWORD".
Have nice day!
Omicron wrote: Tue Jan 23, 2018 12:30 pm When is RPi client booting, it shows up: "sh: can't open /usr/ter-c0b.psf: no such file
Ups..
http://wtware.com/testing/201801221802.zip
Omicron wrote: Tue Jan 23, 2018 12:30 pm May I ask if is there any option to change login table? Just description "USERNAME" and "PASSWORD".
No such setting.
Omicron
Post by Omicron »
Thanks a lot. It works fine now.
Great job guys!
