PC banking not working
Stefaan
Post by Stefaan »
Hi everybody,
At school we are using the Raspberry Pi 3B in combination with wtware. This is working great and we want to use it for administration as well. When testing, everything works, even the smardcard reader works properly which is great.
There is only one final problem. When using the smartcard reader for reading identity cards, it works properly as it should. When using the smartcard reader with a bankcard, we are not able to get into the system of the bank. I tried the same smartcard reader and bankcard on a regular laptop and this works as it should.
We think it has something to do with a protocol or something? When using it with an existing client, we have to set the rdp connection in the settings as legacy. Does it have to do something with this or is there someone else with the same problem?
When testing, the bankcard asks the pin code, but it cannot verificate it, so it seems it has something to do with a verification or protocol or something from the wtware Raspberry Pi through rdp to the terminal server.
What can we do to solve it? It's our final problem, everything works great.
Thanks in advance!
Sincerely yours,
Stefaan
Re: PC banking not working
https://wtware.com/logs.html
In config:
smartcard=replace-with-your-card-name,debug
Stefaan
Post by Stefaan »
aka wrote: Sat Jan 13, 2018 6:42 pm https://wtware.com/logs.html
In config:
Dear aka,
The smartcard reader I use is: ACS - ACR38
This is the log for using the smartcard reader with a regular identity card:
Smartcard present.
[ rdpdr-scard] [ 792.976305] rdpdr[scard]-worker.cpp ( 1618): -- ERROR -- Unknown SCardControl code 0x00313520.
[ rdpdr-scard] [ 792.976499] rdpdr[scard]-worker.cpp ( 1619): -- ERROR -- 0 bytes of binary:
[ rdpdr-scard] [ 792.976632] rdpdr[scard]-worker.cpp ( 1620): -- ERROR -- SCARD_E_INVALID_VALUE, invalid parameter.
[ rdpdr-scard] [ 793.611727] rdpdr[scard]-worker.cpp ( 1618): -- ERROR -- Unknown SCardControl code 0x00313520.
[ rdpdr-scard] [ 793.611920] rdpdr[scard]-worker.cpp ( 1619): -- ERROR -- 0 bytes of binary:
[ rdpdr-scard] [ 793.612056] rdpdr[scard]-worker.cpp ( 1620): -- ERROR -- SCARD_E_INVALID_VALUE, invalid parameter.
[ rdpdr-scard] [ 794.350651] rdpdr[scard]-worker.cpp ( 1618): -- ERROR -- Unknown SCardControl code 0x00313520.
[ rdpdr-scard] [ 794.350840] rdpdr[scard]-worker.cpp ( 1619): -- ERROR -- 0 bytes of binary:
[ rdpdr-scard] [ 794.350972] rdpdr[scard]-worker.cpp ( 1620): -- ERROR -- SCARD_E_INVALID_VALUE, invalid parameter.
[ rdpdr-scard] [ 795.000423] rdpdr[scard]-worker.cpp ( 1618): -- ERROR -- Unknown SCardControl code 0x00313520.
[ rdpdr-scard] [ 795.000620] rdpdr[scard]-worker.cpp ( 1619): -- ERROR -- 0 bytes of binary:
[ rdpdr-scard] [ 795.000754] rdpdr[scard]-worker.cpp ( 1620): -- ERROR -- SCARD_E_INVALID_VALUE, invalid parameter.
[ rdpdr-scard] [ 795.989936] rdpdr[scard]-worker.cpp ( 1618): -- ERROR -- Unknown SCardControl code 0x00313520.
[ rdpdr-scard] [ 795.990165] rdpdr[scard]-worker.cpp ( 1619): -- ERROR -- 0 bytes of binary:
[ rdpdr-scard] [ 795.990251] rdpdr[scard]-worker.cpp ( 1620): -- ERROR -- SCARD_E_INVALID_VALUE, invalid parameter.
As you can see, there are errors, but it works as it should.
Now come the logs for using the smartcard reader with a bankcard:
[ rdpdr-scard] [ 822.210165] Smartcard present.
[ rdpdr-scard] [ 823.495978] CCID 2: commands.c:1523:CCID_Receive Card absent or mute.
[ rdpdr-scard] [ 823.496084] rdpdr[scard]-ccid.cpp ( 500): -- ERROR -- IFDHSetProtocolParameters (0) return 605.
[ rdpdr-scard] [ 823.496165] rdpdr[scard]-opencttools.cpp ( 288): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
Do you have any idea what it could be?
Thanks in advance!
Sincerely yours,
Stefaan
Please, read carefully and execute every step as it's written:
There is no "cut log and hide everything important from techsupport" text. Mail log to support@wtware.com if you think it needs to stay secure.
Stefaan
Post by Stefaan »
Dear Aka,
A couple of days ago we bought another cardreader which is from the list. We bought the ACR39U-l1-m. It works worse than the cardreader we used which was not on the list. When inserting the id card, it works, but from the moment we eject it, the cardreader hangs. Also pc banking is not working with this card.
Is there a possibility to get into the system by using ssh so we can try certain codes ourselves or is there another option to get it working?
Thanks in advance!
Sincerely yours,
Stefaan
Stefaan wrote: Fri Jan 19, 2018 11:54 amis there another option to get it working?
Yes. Here is it: https://wtware.com/logs.html
Stefaan
Post by Stefaan »
Dear Aka,
Thanks for your reply. A couple of days ago I have sent a logfile from another cardreader. Were you able to analyse the log? Is there a cardreader which is 100% fully functional from your list?
Thanks in advance!
Sincerely yours,
Stefaan
I see mail with ACR38 SmartCard Reader log. It is a wtware issue, we need more time to fix it. Before your mail, I thought this reader is 100% fully functional.
Stefaan
Post by Stefaan »
Dear Aka,
Thanks for your answer. Do you think the issue will be solved in the near future?
Thanks in advance!
Sincerely yours,
Stefaan
Please, try this build:
http://wtware.com/testing/201801200839.zip
In config:
smartcard=acs,debug
Stefaan
Post by Stefaan »
Dear Aka,
Thanks for your fast reply. I tried installing WTWare and creating a bootable media, but there is an error which occurs on startup of the system in Raspberry Pi. I have tried it several times, but everytime I want to startup the Raspberry Pi the error occurs:
sh: can't open /usr/ter-c0b.psf: no such file
Error: internal error.
Wtware 5.6.25/RPI
File: console.cpp
Line: 362
This is the error.
Thanks in advance!
Sincerely yours,
Stefaan
Dario
Post by Dario »
Hi I have the same problem, I test the WTware 5.6.25 version but the smartcard message in terminal is " no valid certificate found"
Dario
Post by Dario »
[ KERNEL] [ 5.223634] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ KERNEL] [ 5.365750] usb 1-1.4: New USB device found, idVendor=072f, idProduct=90cc
[ KERNEL] [ 5.365766] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.365775] usb 1-1.4: Product: CCID USB Reader
[ KERNEL] [ 5.365784] usb 1-1.4: Manufacturer: ACS
Smartcard information ACS CCID USB Reader 0 2018-02-14_08-01-17.txt
(678 Bytes) Downloaded 3296 times
