CredSSP connection failed with expired password
I have a question about expired passwords. When a user must change his/her Active Directory password on the next logon, they get a CredSSP connection failed on WTWare clients. We have a setup with a Connection Broker and two Session Hosts, all servers are configured with Windows Server 2016. Is this a known error? Am I missing something in our WTWare Setup?
Re: CredSSP connection failed with expired password
Hello Aka, thanks for your reply. Is this an issue which will be resolved in the near future? I understand it's not that easy, but it is pretty critical, because it would result in user frustration and workload for an administrator.
Very "not that easy"
In the next build, WTware will print correct error message. Disable NLA at all to allow user to change password in Windows interface: https://wtware.com/win/nla.html
Hey akatik, is this still an issue which is on the list to be fixed? I do not want to disable NLA.
It is on the list to be fixed until it will be fixed. Not sure it will be fixed in near feature
