Change login screen graphics on Ras Pi version?
Arup
Post by Arup »
Currently testing this product with a Ras Pi 3 with 2016 server RDSH, and it is impressive thus far. The login screen is really lacking, and gives users the initial feeling that the product is not going to work well. Is there a way to change the small icon and background for the login screen?
If there is a way to auto-connect to the Windows server login screen(no username/password), I guess that would be just as good, but not preferred.
Re: Change login screen graphics on Ras Pi version?
Disable NLA on server to get Windows login screen.
https://wtware.com/win/nla.html
Arup
Post by Arup »
Thank you. I also found the image.png file that can go in the config folder for the desktop background.
menta
Post by menta »
hi, i try this and dont work for me. Any idea why? I have to enable or disable any option on wtware config?
-windows server 2016 with last update
-Raspberry pi 3
-WTware 5.8.34
menta
Post by menta »
here is my file log.
log.txt
(33.69 KiB) Downloaded 1109 times
Remove "ask_password=on" line from config.
