No matter what I tend to do regarding settings with WTware, I can't seem to get network boot to work.
I'll add the log from the terminal in hope that'll help. Tips are always welcome! Fyi, I'm fairly new to WTware and all the network boot tutorials are still a bit unclear in my eyes
Thanks in advance!
Log file:
11-59-14-758| WTware 5.6.16/RPi supervisor.
11-59-14-758| [ KERNEL] [ 0.000000] Booting Linux on physical CPU 0x0
11-59-14-758| [ KERNEL] [ 0.000000] Linux version 4.9.51 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #2 SMP Sat Sep 30 11:33:59 +04 2017
11-59-14-758| [ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
11-59-14-758| [ KERNEL] [ 0.000000] CPU: div instructions available: patching division code
11-59-14-758| [ KERNEL] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
11-59-14-758| [ KERNEL] [ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
11-59-14-758| [ KERNEL] [ 0.000000] cma: Reserved 8 MiB at 0x3ac00000
11-59-14-758| [ KERNEL] [ 0.000000] Memory policy: Data cache writealloc
11-59-14-758| [ KERNEL] [ 0.000000] On node 0 totalpages: 242688
11-59-14-758| [ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80b22cc0, node_mem_map ba3a1000
11-59-14-758| [ KERNEL] [ 0.000000] Normal zone: 2133 pages used for memmap
11-59-14-758| [ KERNEL] [ 0.000000] Normal zone: 0 pages reserved
11-59-14-758| [ KERNEL] [ 0.000000] Normal zone: 242688 pages, LIFO batch:31
11-59-14-758| [ KERNEL] [ 0.000000] percpu: Embedded 11 pages/cpu @ba367000 s16076 r8192 d20788 u45056
11-59-14-758| [ KERNEL] [ 0.000000] pcpu-alloc: s16076 r8192 d20788 u45056 alloc=11*4096
11-59-14-758| [ KERNEL] [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
11-59-14-758| [ KERNEL] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 240555
11-59-14-758| [ KERNEL] [ 0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 quiet wtboot=mmc
11-59-14-758| [ KERNEL] [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
11-59-14-758| [ KERNEL] [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
11-59-14-758| [ KERNEL] [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
11-59-14-758| [ KERNEL] [ 0.000000] Memory: 942176K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 4096K init, 373K bss, 20384K reserved, 8192K cma-reserved)
11-59-14-758| [ KERNEL] [ 0.000000] Virtual kernel memory layout:
11-59-14-758| [ KERNEL] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
11-59-14-758| [ KERNEL] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
11-59-14-758| [ KERNEL] [ 0.000000] vmalloc : 0xbb800000 - 0xff800000 (1088 MB)
11-59-14-758| [ KERNEL] [ 0.000000] lowmem : 0x80000000 - 0xbb400000 ( 948 MB)
11-59-14-758| [ KERNEL] [ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
11-59-14-758| [ KERNEL] [ 0.000000] .text : 0x80008000 - 0x80600000 (6112 kB)
11-59-14-758| [ KERNEL] [ 0.000000] .init : 0x80700000 - 0x80b00000 (4096 kB)
11-59-14-758| [ KERNEL] [ 0.000000] .data : 0x80b00000 - 0x80b23f78 ( 144 kB)
11-59-14-758| [ KERNEL] [ 0.000000] .bss : 0x80b25000 - 0x80b826a0 ( 374 kB)
11-59-14-758| [ KERNEL] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
11-59-14-758| [ KERNEL] [ 0.000000] Hierarchical RCU implementation.
11-59-14-758| [ KERNEL] [ 0.000000] Build-time adjustment of leaf fanout to 32.
11-59-14-758| [ KERNEL] [ 0.000000] NR_IRQS:16 nr_irqs:16 16
11-59-14-758| [ KERNEL] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
11-59-14-758| [ KERNEL] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
11-59-14-758| [ KERNEL] [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
11-59-14-758| [ KERNEL] [ 0.000017] Switching to timer-based delay loop, resolution 52ns
11-59-14-758| [ KERNEL] [ 0.000211] Console: colour dummy device 80x30
11-59-14-758| [ KERNEL] [ 0.000224] console [tty0] enabled
11-59-14-758| [ KERNEL] [ 0.000240] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
11-59-14-758| [ KERNEL] [ 0.000253] pid_max: default: 32768 minimum: 301
11-59-14-758| [ KERNEL] [ 0.000384] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
11-59-14-758| [ KERNEL] [ 0.000391] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
11-59-14-758| [ KERNEL] [ 0.001228] Disabling memory control group subsystem
11-59-14-758| [ KERNEL] [ 0.001280] CPU: Testing write buffer coherency: ok
11-59-14-758| [ KERNEL] [ 0.001615] CPU0: update cpu_capacity 1024
11-59-14-758| [ KERNEL] [ 0.001622] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
11-59-14-758| [ KERNEL] [ 0.001647] Setting up static identity map for 0x100000 - 0x100034
11-59-14-758| [ KERNEL] [ 0.003139] CPU1: update cpu_capacity 1024
11-59-14-758| [ KERNEL] [ 0.003145] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
11-59-14-758| [ KERNEL] [ 0.003698] CPU2: update cpu_capacity 1024
11-59-14-758| [ KERNEL] [ 0.003704] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
11-59-14-758| [ KERNEL] [ 0.004253] CPU3: update cpu_capacity 1024
11-59-14-758| [ KERNEL] [ 0.004259] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
11-59-14-758| [ KERNEL] [ 0.004335] Brought up 4 CPUs
11-59-14-758| [ KERNEL] [ 0.004344] SMP: Total of 4 processors activated (153.60 BogoMIPS).
11-59-14-758| [ KERNEL] [ 0.004348] CPU: All CPU(s) started in HYP mode.
11-59-14-758| [ KERNEL] [ 0.004351] CPU: Virtualization extensions available.
11-59-14-758| [ KERNEL] [ 0.004889] devtmpfs: initialized
11-59-14-758| [ KERNEL] [ 0.014456] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
11-59-14-758| [ KERNEL] [ 0.014837] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
11-59-14-758| [ KERNEL] [ 0.014852] futex hash table entries: 1024 (order: 4, 65536 bytes)
11-59-14-758| [ KERNEL] [ 0.015330] pinctrl core: initialized pinctrl subsystem
11-59-14-758| [ KERNEL] [ 0.015855] NET: Registered protocol family 16
11-59-14-758| [ KERNEL] [ 0.017685] DMA: preallocated 1024 KiB pool for atomic coherent allocations
11-59-14-758| [ KERNEL] [ 0.027861] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
11-59-14-758| [ KERNEL] [ 0.111167] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
11-59-14-758| [ KERNEL] [ 0.113514] usbcore: registered new interface driver usbfs
11-59-14-758| [ KERNEL] [ 0.113639] usbcore: registered new interface driver hub
11-59-14-758| [ KERNEL] [ 0.113725] usbcore: registered new device driver usb
11-59-14-758| [ KERNEL] [ 0.120165] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-09-12 15:21
11-59-14-758| [ KERNEL] [ 0.122436] clocksource: Switched to clocksource arch_sys_counter
11-59-14-758| [ KERNEL] [ 0.137176] NET: Registered protocol family 2
11-59-14-758| [ KERNEL] [ 0.137745] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
11-59-14-758| [ KERNEL] [ 0.137852] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
11-59-14-758| [ KERNEL] [ 0.138036] TCP: Hash tables configured (established 8192 bind 8192)
11-59-14-758| [ KERNEL] [ 0.138123] UDP hash table entries: 512 (order: 2, 16384 bytes)
11-59-14-758| [ KERNEL] [ 0.138164] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
11-59-14-758| [ KERNEL] [ 0.138343] NET: Registered protocol family 1
11-59-14-758| [ KERNEL] [ 2.240805] workingset: timestamp_bits=14 max_order=18 bucket_order=4
11-59-14-758| [ KERNEL] [ 2.277104] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
11-59-14-758| [ KERNEL] [ 2.277116] io scheduler noop registered
11-59-14-758| [ KERNEL] [ 2.277121] io scheduler deadline registered (default)
11-59-14-758| [ KERNEL] [ 2.285865] BCM2708FB: allocated DMA memory fad10000
11-59-14-758| [ KERNEL] [ 2.285919] BCM2708FB: allocated DMA channel 0 @ bb80f000
11-59-14-758| [ KERNEL] [ 2.344760] Console: switching to colour frame buffer device 240x67
11-59-14-758| [ KERNEL] [ 2.382613] bcm2835-rng 3f104000.rng: hwrng registered
11-59-14-758| [ KERNEL] [ 2.382821] vc-cma: Videocore CMA driver
11-59-14-758| [ KERNEL] [ 2.382828] vc-cma: vc_cma_base = 0x00000000
11-59-14-758| [ KERNEL] [ 2.382834] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
11-59-14-758| [ KERNEL] [ 2.382838] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
11-59-14-758| [ KERNEL] [ 2.383187] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
11-59-14-758| [ KERNEL] [ 2.383995] vc-sm: Videocore shared memory driver
11-59-14-758| [ KERNEL] [ 2.392013] zram: Added device: zram0
11-59-14-758| [ KERNEL] [ 2.392075] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
11-59-14-758| [ KERNEL] [ 2.620232] Core Release: 2.80a
11-59-14-758| [ KERNEL] [ 2.620248] Setting default values for core params
11-59-14-758| [ KERNEL] [ 2.620275] Finished setting default values for core params
11-59-14-758| [ KERNEL] [ 2.820641] Using Buffer DMA mode
11-59-14-758| [ KERNEL] [ 2.820646] Periodic Transfer Interrupt Enhancement - disabled
11-59-14-758| [ KERNEL] [ 2.820650] Multiprocessor Interrupt Enhancement - disabled
11-59-14-758| [ KERNEL] [ 2.820658] OTG VER PARAM: 0, OTG VER FLAG: 0
11-59-14-758| [ KERNEL] [ 2.820688] Dedicated Tx FIFOs mode
11-59-14-758| [ KERNEL] [ 2.821153] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
11-59-14-758| [ KERNEL] [ 2.821180] FIQ FSM acceleration enabled for :
11-59-14-758| [ KERNEL] [ 2.821180] Non-periodic Split Transactions
11-59-14-758| [ KERNEL] [ 2.821180] Periodic Split Transactions
11-59-14-758| [ KERNEL] [ 2.821180] High-Speed Isochronous Endpoints
11-59-14-758| [ KERNEL] [ 2.821180] Interrupt/Control Split Transaction hack enabled
11-59-14-758| [ KERNEL] [ 2.821187] dwc_otg: Microframe scheduler enabled
11-59-14-758| [ KERNEL] [ 2.821227] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80398974
11-59-14-758| [ KERNEL] [ 2.821235] WARN::hcd_init_fiq:460: FIQ ASM at 0x80398cd8 length 36
11-59-14-758| [ KERNEL] [ 2.821245] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
11-59-14-758| [ KERNEL] [ 2.821297] dwc_otg 3f980000.usb: DWC OTG Controller
11-59-14-758| [ KERNEL] [ 2.821331] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
11-59-14-758| [ KERNEL] [ 2.821362] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
11-59-14-758| [ KERNEL] [ 2.821407] Init: Port Power? op_state=1
11-59-14-758| [ KERNEL] [ 2.821411] Init: Power Port (0)
11-59-14-758| [ KERNEL] [ 2.821592] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
11-59-14-758| [ KERNEL] [ 2.821603] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
11-59-14-758| [ KERNEL] [ 2.821610] usb usb1: Product: DWC OTG Controller
11-59-14-758| [ KERNEL] [ 2.821617] usb usb1: Manufacturer: Linux 4.9.51 dwc_otg_hcd
11-59-14-758| [ KERNEL] [ 2.821624] usb usb1: SerialNumber: 3f980000.usb
11-59-14-758| [ KERNEL] [ 2.822359] hub 1-0:1.0: USB hub found
11-59-14-758| [ KERNEL] [ 2.822394] hub 1-0:1.0: 1 port detected
11-59-14-758| [ KERNEL] [ 2.823115] dwc_otg: FIQ enabled
11-59-14-758| [ KERNEL] [ 2.823120] dwc_otg: NAK holdoff enabled
11-59-14-758| [ KERNEL] [ 2.823124] dwc_otg: FIQ split-transaction FSM enabled
11-59-14-758| [ KERNEL] [ 2.823138] Module dwc_common_port init
11-59-14-758| [ KERNEL] [ 2.823552] usbcore: registered new interface driver usbtouchscreen
11-59-14-758| [ KERNEL] [ 2.824910] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
11-59-14-758| [ KERNEL] [ 2.825368] bcm2835-cpufreq: min=600000 max=1200000
11-59-14-758| [ KERNEL] [ 2.826478] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
11-59-14-758| [ KERNEL] [ 2.828974] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
11-59-14-758| [ KERNEL] [ 2.831447] ledtrig-cpu: registered to indicate activity on CPUs
11-59-14-758| [ KERNEL] [ 2.831624] hidraw: raw HID events driver (C) Jiri Kosina
11-59-14-758| [ KERNEL] [ 2.832486] usbcore: registered new interface driver usbhid
11-59-14-758| [ KERNEL] [ 2.832494] usbhid: USB HID core driver
11-59-14-758| [ KERNEL] [ 2.833546] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
11-59-14-758| [ KERNEL] [ 2.841001] [vc_sm_connected_init]: start
11-59-14-758| [ KERNEL] [ 2.848804] [vc_sm_connected_init]: end - returning 0
11-59-14-758| [ KERNEL] [ 2.849085] NET: Registered protocol family 17
11-59-14-758| [ KERNEL] [ 2.849225] Registering SWP/SWPB emulation handler
11-59-14-758| [ KERNEL] [ 2.849719] registered taskstats version 1
11-59-14-758| [ KERNEL] [ 2.853993] sdhost: log_buf @ bad07000 (fad07000)
11-59-14-758| [ KERNEL] [ 2.932478] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
11-59-14-758| [ KERNEL] [ 2.934601] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
11-59-14-758| [ KERNEL] [ 2.934605] mmc-bcm2835 3f300000.mmc: DMA channel allocated
11-59-14-758| [ KERNEL] [ 2.992494] of_cfs_init
11-59-14-758| [ KERNEL] [ 2.992548] of_cfs_init: OK
11-59-14-758| [ KERNEL] [ 3.003043] Freeing unused kernel memory: 4096K
11-59-14-758| [ KERNEL] [ 3.019580] mmc0: host does not support reading read-only switch, assuming write-enable
11-59-14-758| [ KERNEL] [ 3.021553] mmc0: new high speed SDHC card at address 59b4
11-59-14-758| [ KERNEL] [ 3.022034] mmcblk0: mmc0:59b4 SDU1 14.6 GiB
11-59-14-758| [ KERNEL] [ 3.029059] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
11-59-14-758| [ KERNEL] [ 3.030501] mmcblk0: p1
11-59-14-758| [ KERNEL] [ 3.030570] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
11-59-14-758| [ KERNEL] [ 3.032164] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
11-59-14-758| [ KERNEL] [ 3.034906] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
11-59-14-758| [ KERNEL] [ 3.042526] Indeed it is in host mode hprt0 = 00021501
11-59-14-758| [ KERNEL] [ 3.114173] random: fast init done
11-59-14-758| [ KERNEL] [ 3.181232] mmc1: new high speed SDIO card at address 0001
11-59-14-758| [ KERNEL] [ 3.252484] usb 1-1: new high-speed USB device number 2 using dwc_otg
11-59-14-758| [ KERNEL] [ 3.252621] Indeed it is in host mode hprt0 = 00001101
11-59-14-758| [ hotplug] [ 3.297789] Block device 254:0. No action.
11-59-14-758| [ hotplug] [ 3.330348] Block device 179:0. No action.
11-59-14-758| [ hotplug] [ 3.330454] Block device 179:1. No action.
11-59-14-758| [ pfac] [ 3.334753] Run /sbin/initrd.
11-59-14-758| [ pfac] [ 3.334847] Ok, PID 608.
11-59-14-758| [ initrd] [ 3.338216] WTware shell 5.6.16/RPi
11-59-14-758| [ initrd] [ 3.383913] HDD/MMC/SD boot.
11-59-14-758| [ KERNEL] [ 3.482706] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
11-59-14-758| [ KERNEL] [ 3.482719] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
11-59-14-758| [ KERNEL] [ 3.483458] hub 1-1:1.0: USB hub found
11-59-14-758| [ KERNEL] [ 3.483552] hub 1-1:1.0: 5 ports detected
11-59-14-758| [ KERNEL] [ 3.802464] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
11-59-14-758| [ KERNEL] [ 3.932692] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
11-59-14-758| [ KERNEL] [ 3.932705] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
11-59-14-758| [ KERNEL] [ 4.032469] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
11-59-14-758| [ KERNEL] [ 4.174367] usb 1-1.2: New USB device found, idVendor=0461, idProduct=4d51
11-59-14-758| [ KERNEL] [ 4.174379] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
11-59-14-758| [ KERNEL] [ 4.174386] usb 1-1.2: Product: DELL Laser Mouse
11-59-14-758| [ KERNEL] [ 4.188579] input: DELL Laser Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:0461:4D51.0001/input/input0
11-59-14-758| [ KERNEL] [ 4.189174] hid-generic 0003:0461:4D51.0001: input,hidraw0: USB HID v1.11 Mouse [DELL Laser Mouse] on usb-3f980000.usb-1.2/input0
11-59-14-758| [ KERNEL] [ 4.292473] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
11-59-14-758| [ KERNEL] [ 4.547366] usb 1-1.3: New USB device found, idVendor=04d9, idProduct=1702
11-59-14-758| [ KERNEL] [ 4.547376] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
11-59-14-758| [ KERNEL] [ 4.547383] usb 1-1.3: Product: USB Keyboard
11-59-14-758| [ KERNEL] [ 4.547391] usb 1-1.3: Manufacturer:
11-59-14-758| [ KERNEL] [ 4.607102] input: USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:04D9:1702.0002/input/input1
11-59-14-758| [ KERNEL] [ 4.673606] hid-generic 0003:04D9:1702.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-3f980000.usb-1.3/input0
11-59-14-758| [ KERNEL] [ 4.771018] input: USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:04D9:1702.0003/input/input2
11-59-14-758| [ KERNEL] [ 4.832916] hid-generic 0003:04D9:1702.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-3f980000.usb-1.3/input1
11-59-14-758| [ initrd] [ 4.874610] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
11-59-14-758| /--- FILE "/bootmedia/config.txt" -----------------------
11-59-14-758| | # For more options and information see
11-59-14-758| | # http://www.raspberrypi.org/documentatio ... fig-txt.md
11-59-14-758| | # Some settings may impact device functionality. See link above for details
11-59-14-758| | # Uncomment if you get no picture on HDMI for a default "safe" mode.
11-59-14-758| | #hdmi_safe=1
11-59-14-758| | # Uncomment this if your display has a black border of unused pixels visible
11-59-14-758| | # and your display can output without overscan.
11-59-14-758| | disable_overscan=1
11-59-14-758| | # Uncomment if hdmi display is not detected and composite is being output.
11-59-14-758| | #hdmi_force_hotplug=1
11-59-14-758| | # Uncomment to force a specific HDMI mode (this will force VGA).
11-59-14-758| | #hdmi_group=1
11-59-14-758| | #hdmi_mode=1
11-59-14-758| | # Force the monitor to HDMI mode so that sound will be sent over HDMI cable.
11-59-14-758| | #hdmi_drive=2
11-59-14-758| | # Uncomment to increase signal to HDMI, if you have interference, blanking, or
11-59-14-758| | # no display.
11-59-14-758| | #config_hdmi_boost=4
11-59-14-758| | # Uncomment to overclock the arm. 700 MHz is the default.
11-59-14-758| | #arm_freq=800
11-59-14-758| | disable_splash=1
11-59-14-758| | #hdmi_group=2
11-59-14-758| | # 800x600: hdmi_mode=9
11-59-14-758| | # 1024x768: hdmi_mode=16
11-59-14-758| | # 1280x1024: hdmi_mode=35
11-59-14-758| | # 1360x768: hdmi_mode=39
11-59-14-758| | # 1400x1050: hdmi_mode=42
11-59-14-758| | # 1440x900: hdmi_mode=47
11-59-14-758| | # 1600x1200: hdmi_mode=51
11-59-14-758| | # 1680x1050: hdmi_mode=58
11-59-14-758| | # 1366x768: hdmi_mode=81
11-59-14-758| | # 1920x1080: hdmi_mode=82
11-59-14-758| | # 1920x1200: hdmi_mode=69
11-59-14-758| | framebuffer_depth=32
11-59-14-758| | # Uncomment for 16-bit color. It is up to two
11-59-14-758| | # times faster than default 32-bit.
11-59-14-758| | #framebuffer_depth=16
11-59-14-758| | # Enable onboard audio (HDMI or jack).
11-59-14-758| | dtparam=audio=on
11-59-14-758| | # Removes the warning overlay.
11-59-14-758| | #avoid_warnings=1
11-59-14-758| | # Additionally allows turbo when low-voltage is present.
11-59-14-758| | #avoid_warnings=2
11-59-14-758| \----------------------------------------------------
11-59-14-758| [ initrd] [ 4.880102] WTpassword empty.
11-59-14-758| /--- FILE "/bootmedia/configs/initrd.wtc" -----------------------
11-59-14-758| | [BOM]
11-59-14-758| | clientIP=*
11-59-14-758| | netmask=255.255.255.0
11-59-14-758| | routerIP=172.16.58.1
11-59-14-758| | nameserverIP=172.16.56.8
11-59-14-758| | config=network
11-59-14-758| | tftpIP=172.16.59.53
11-59-14-758| [ initrd] [ 6.910112] Load ethernet drivers.
11-59-14-758| [ initrd] [ 6.910202] modprobe smsc95xx.
11-59-14-758| [ KERNEL] [ 6.919903] smsc95xx v1.0.5
11-59-14-758| [ KERNEL] [ 7.006098] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:94:eb:64
11-59-14-758| [ KERNEL] [ 7.008263] usbcore: registered new interface driver smsc95xx
11-59-14-758| [ KERNEL] [ 7.104229] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
11-59-14-758| [ initrd] [ 8.604822] WTpassword empty.
11-59-14-758| [ KERNEL] [ 8.603826] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
11-59-14-758| [ initrd] [ 9.840165] dhcp: 386 bytes from 172.16.58.2.
11-59-14-758| [ initrd] [ 9.840289] 00000000:0000016E0000000000110000AC103A02AC103A8E00430044016E000002010601 ...n........:..:..C.D.n......
11-59-14-758| [ initrd] [ 9.840361] 00000020:67458B6B0000000000000000AC103A8EAC103809AC103A02B827EB94EB640000 gE.k.........:..8..:..'...d..
11-59-14-758| [ initrd] [ 9.840430] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 9.840500] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 9.840569] 00000080:0000000000000000736D73626F6F745C7836345C7764736D6766772E65666900 ........smsboot\x64\wdsmgfw.efi.
11-59-14-758| [ initrd] [ 9.840637] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 9.840704] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 9.840772] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 12.100131] dhcp: 386 bytes from 172.16.58.2.
11-59-14-758| [ initrd] [ 12.100243] 00000000:0000016E0000000000110000AC103A02AC103A8E00430044016E000002010601 ...n........:..:..C.D.n......
11-59-14-758| [ initrd] [ 12.100317] 00000020:67458B6B0000000000000000AC103A8EAC103809AC103A02B827EB94EB640000 gE.k.........:..8..:..'...d..
11-59-14-758| [ initrd] [ 12.100386] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 12.100477] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 12.100546] 00000080:0000000000000000736D73626F6F745C7836345C7764736D6766772E65666900 ........smsboot\x64\wdsmgfw.efi.
11-59-14-758| [ initrd] [ 12.100614] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 12.100682] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 12.100749] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
11-59-14-758| [ initrd] [ 12.140086] dhcp: server address 172.16.56.6.
11-59-14-758| [ initrd] [ 12.140161] dhcp: 172.16.58.142/255.255.255.0.
11-59-14-758| [ initrd] [ 12.140230] dhcp: default gateway 172.16.58.1.
11-59-14-758| [ initrd] [ 12.140297] dhcp: DNS 172.16.56.6.
11-59-14-758| [ initrd] [ 12.140364] dhcp: DNS 172.16.56.8.
11-59-14-758| [ initrd] [ 12.140429] dhcp: domain zedek1.kappapackaging.com.
11-59-14-758| [ initrd] [ 12.140495] TFTP IP 172.16.59.53 already specified.
11-59-14-758| [ initrd] [ 12.140561] dhcp: boot file (067) smsboot\x64\wdsmgfw.efi.
11-59-14-758| [ initrd] [ 12.140628] TFTP binary "smsboot\x64\", configs prefix "smsboot\", using "\" slash.
11-59-14-758| WTC listener is active.
11-59-14-758| WTC broadcast listener is active.
11-59-14-758| Send broadcast WTCU discover.
11-59-14-758| [ initrd] [ 12.142476] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
11-59-14-758| [ pfac] [ 12.142603] Run /sbin/httpd.
11-59-14-758| [ pfac] [ 12.142806] Ok, PID 649.
11-59-14-758| [ httpd] [ 12.147699] HTTP Server, WTware 5.6.16/RPi
11-59-14-758| [ initrd] [ 12.265492] USB: 04d9:1702 Holtek Semiconductor, Inc. Keyboard LKS02.
11-59-14-758| [ initrd] [ 12.265641] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
11-59-14-758| [ initrd] [ 12.265719] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
11-59-14-758| [ initrd] [ 12.265791] USB: 0461:4d51 Primax Electronics, Ltd 0Y357C PMX-MMOCZUL (B) [Dell Laser Mouse].
11-59-14-758| [ initrd] [ 12.265862] [TFTP] Download config file smsboot\Everyone\list.wtc from 172.16.59.53.
11-59-14-758| [ initrd] [ 12.770155] Got EAGAIN, resend wtware hello.
11-59-14-758| [ initrd] [ 13.280122] Got EAGAIN, resend wtware hello.
11-59-14-758| [ initrd] [ 13.790095] Got EAGAIN, resend wtware hello.
11-59-14-758| [ initrd] [ 14.300109] Got EAGAIN, resend wtware hello.
11-59-14-758| [ KERNEL] [ 14.642127] random: crng init done
11-59-14-758| [ initrd] [ 14.810094] Got EAGAIN, resend wtware hello.
11-59-14-758| [ initrd] [ 15.320095] Got EAGAIN, resend wtware hello.
11-59-14-767| Connection from wtc.exe at 172.16.59.53.
11-59-14-785| [ initrd] [ 15.830121] Got EAGAIN, resend wtware hello.
11-59-15-284| [ initrd] [ 16.340127] Got EAGAIN, resend wtware hello.
11-59-15-794| [ initrd] [ 16.850097] Got EAGAIN, resend wtware hello.
11-59-16-302| [ initrd] [ 17.360098] Got EAGAIN, resend wtware hello.
11-59-16-811| [ initrd] [ 17.870099] recv() return -1, errno 11.
11-59-29-531| [ initrd] [ 30.580136] tftp.cpp ( 890): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-59-29-595| [ initrd] [ 30.580326] [TFTP] Download config file smsboot\Terminals\B8.27.EB.94.EB.64\config.wtc from 172.16.59.53.
11-59-42-231| [ initrd] [ 43.290121] tftp.cpp ( 890): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-59-42-315| [ initrd] [ 43.290289] [TFTP] Download config file smsboot\Terminals\B8.27.EB.94.EB.64.wtc from 172.16.59.53.
11-59-54-953| [ initrd] [ 56.000128] tftp.cpp ( 890): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
11-59-55-006| [ initrd] [ 56.000234] [TFTP] Download config file smsboot\Everyone\default.wtc from 172.16.59.53.
12-00-07-651| [ initrd] [ 68.710112] tftp.cpp ( 890): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
12-00-07-714| [ initrd] [ 68.710217] [TFTP] Download config file smsboot\Everyone\all.wtc from 172.16.59.53.
12-00-20-368| [ initrd] [ 81.420126] tftp.cpp ( 890): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
12-00-20-430| [ initrd] [ 81.420593] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
12-00-20-430| [ initrd] [ 81.421407] Common local disk config:
12-00-20-430| /--- FILE "/tmp/config.wtc" -----------------------
12-00-20-446| | [BOM]
12-00-20-447| | server=tsfarm
12-00-20-452| | graphic=abcdefg
12-00-20-452| | clienthostname=TEST
12-00-20-452| | onerror=quiet
12-00-20-452| | bpp=16
12-00-20-468| | connection
12-00-20-468| \----------------------------------------------------
