Rotate Screen
geefox
Rotate Screen
Post by geefox »
I would like to know if its possible to rotate the 2nd screen around 90°
best regards
Re: Rotate Screen
No way :(
geefox
Re: Rotate Screen
Post by geefox »
any plans for including this feature in the next version?
I really need this for 50+ x86 clients
geefox
Re: Rotate Screen
Post by geefox »
I just wanted to bump this thread again. Maybe it is possible to implement this feature in an updated version of wtware.
It would be also possible to pay you guys for this feature-request.
best regards
Re: Rotate Screen
It may be done for video=...(U) drivers only, any from (U) set. Can all your 50+ x86 clients run video=...(U)?
Show me the log: https://wtware.com/logs.html
geefox
Re: Rotate Screen
Post by geefox »
yes - all of my clients can run the (U) drivers. I've tested it with the following line in the config file:
video = intel(U)
I've also attached you the log file
thanks in advance
logfile.txt
(107.95 KiB) Downloaded 1562 times
Re: Rotate Screen
Please, try this:
http://pxe.ru/files/testing/201711032214.zip
In config file:
display=1024x768, portrait
geefox
Re: Rotate Screen
Post by geefox »
thank you very much - will try it on monday and give you feedback!
best regards
geefox
Re: Rotate Screen
Post by geefox »
first of all thank you - the portrait mode is working with one monitor, but if I want to use the portrait mode M2_display parameter, it fails with an error with invalid argument - and is it possible to specify this: display=1920x1080, DP, portrait ?
In addition I recognize a strange behaviour:
If I attach only one monitor and configure these parameters into the config file, the monitor is working properly
  • video=intel(U)
  • display=1024x768, DP
but if I attach the second screen and add these parameters to the config file, the screens turns dark, and there is only an underscore blinking in the left upper corner
  • M2_display=1920x1080, DP2
  • M2_position=left
If I remove the video=intel(U) parameter, the screens are both working.
I've attached you two logfiles, the first one with the working monitor, and the second one with the two monitors, with the blinking underscore
best regards
two_screens_not_working.txt
(107.97 KiB) Downloaded 1576 times
one_screen_working.txt
(123.94 KiB) Downloaded 1572 times
Re: Rotate Screen
geefox wrote:but if I want to use the portrait mode M2_display parameter, it fails with an error with invalid argument
Log?
geefox wrote:is it possible to specify this: display=1920x1080, DP, portrait ?
Yes.
geefox wrote:If I attach only one monitor and configure these parameters into the config file, the monitor is working properly
  • video=intel(U)
video=...(U) ignores video output setting for single monitor configuration and duplicates image at all available outputs.
Use video=...(F) to check real output names. Or read the log:
[             X] [  157.863289] [   157.863] (II) intel(0): EDID for output DP1
[             X] [  158.130221] [   158.130] (II) intel(0): EDID for output DP2
[             X] [  158.130242] [   158.130] (II) intel(0): EDID for output DP3
And no information about monitors on DP1, DP2, DP3 outputs.
Then for HDMI1:
[             X] [  158.158473] [   158.158] (II) intel(0): EDID for output HDMI1
[             X] [  158.158480] [   158.158] (II) intel(0): Manufacturer: SAM  Model: 56a  Serial#: 1297691186
[             X] [  158.158482] [   158.158] (II) intel(0): Year: 2009  Week: 34
...and many more text about display at HDMI1.
And for HDMI2:
[             X] [  158.175801] [   158.175] (II) intel(0): EDID for output HDMI2
[             X] [  158.175808] [   158.175] (II) intel(0): Manufacturer: BNQ  Model: 78a5  Serial#: 21573
[             X] [  158.175810] [   158.175] (II) intel(0): Year: 2012  Week: 39
So right configuration for dual monitors on this device is:
display=1680x1050, HDMI
M2_display=1920x1080, HDMI2
geefox
Re: Rotate Screen
Post by geefox »
thank you, now I'm a bit closer to the finish line :D
I've tested this config without the video=intel(U) parameter and both monitors are working
display=1680x1050, DP
M2_display=1920x1080, DP2, portrait
M2_position=left
Only one problem remains as you can see in the picture I've attached you. Left side shows the monitor which should be in portrait mode, but some parts of the picture are cut off. Right side shows the other monitor with some shuttered lines. This behaviour only occures if I add the portrait parameter to the config file --> see log1.txt
If I test the config with the video=intel(U) parameter, the screen stays black with the underscore in top left corner --> see log2.txt
best regards
log2.txt
(107.64 KiB) Downloaded 1610 times
log1.txt
(99.4 KiB) Downloaded 1579 times
Re: Rotate Screen
Do not write "video=i915(f)". Write:
video=intel(u)
Do not write "display=...DP" and "m2_display=..DP2". Write:
And remove all unnecessary lines from config. "sound=" and "microphone=" in logs are completely wrong.
geefox
Re: Rotate Screen
Post by geefox »
Hello aka,
thank you very much, now its working without any problem. But I dont understand why I have to select the HDMI and HDMI2 parameters.
Do you have any tips for me? - because a rollout of a large amount of devices could be a little bit annoying if I have to choose "randomly" the output sources.
The sound and microphone stuff needs to be edited, because i copied the config from a raspberry pi.
Going to evaluate this a few days, and then buy a bunch of licenses :D
Edit: The client from above has 2 displayport output. Now I've tried to reproduce config on a second client which has an VGA and DisplayPort output. But I am not able to do this. Could you please have a look at the logfile? - in the logfile its stated to use "VIRTUAL1" as display parameter, but this isnt working.
Thank you very much!
log.txt
(109.76 KiB) Downloaded 1590 times
Re: Rotate Screen
geefox wrote:But I dont understand why I have to select the HDMI and HDMI2 parameters.
Sometimes I don't understand it too :(
1. Connect both monitors.
2. Run it with video=put_right_driver_not_vesa_here(U) and without m2_display.
3. Take log and read it until you understand it...
HDMI1 in log is HDMI in config (DP1 is DP and so on) and HDMI2 in log is HDMI2 in config.
Physical interfaces may differ from specified in log. Do not think about physical interfaces. Look into log and take output names from log.
geefox wrote:Could you please have a look at the logfile? - in the logfile its stated to use "VIRTUAL1" as display parameter, but this isnt working.
Show me the logfile without m2_display in config.
geefox
Re: Rotate Screen
Post by geefox »
thank you, now I've realized how it works.
Monitor on VGA is VGA, and the other one which is plugged in in DP, is HDMI2.
Just need to read the logfile and initially disable the m2 parameter to discover the proper output type.
Now everything is working - thank you very much for your time, your answers to my questions and for the implementation of this feature!
best regards
