Is there anything extra I need to do to access images on a digital camera ?
It is a Sony Cybershot DSC-W35, we see it in the USB device list:
USB ID: 054c:0010, bus ID: 1-1.3.3, class: 0x00, subclass: 0x00, Sony Corp. DSC-S30/S70/S75/F505V/F505/FD92/W1 Cybershot/Mavica Digital Cam
Unplugging and plugging in the log:
[ KERNEL] [2348526.150583] usb 1-1.3.3: new high-speed USB device number 10 using dwc_otg
[ KERNEL] [2348526.282819] usb 1-1.3.3: New USB device found, idVendor=054c, idProduct=0010
[ KERNEL] [2348526.282833] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [2348526.282840] usb 1-1.3.3: Product: Sony DSC
[ KERNEL] [2348526.282849] usb 1-1.3.3: Manufacturer: Sony
However in the terminal server session the server does not show the device.
Thanks,
Robert
Sony Cybershot
Re: Sony Cybershot
The display on the camera stays on status "USB Mode: Connecting"
It doesn't switch to "USB Mode: Mass Storage. Memory Stick"
Re: Sony Cybershot
"class: 0x00, subclass: 0x00" is not good
In wtware config file:
disk=usb
On the camera, look for mode setting. if there are PTP, MPT or Auto, change it to Mass Storage.
And send us full log to support@wtware.com
disk=usb
Re: Sony Cybershot
Great atatik !
Changing the setting from auto to mass storage made it work indeed.
The USB id is now:
[3] USB ID: 054c:0010, bus ID: 1-1.3.4, class: 0x00, subclass: 0x00, Sony Corp. DSC-S30/S70/S75/F505V/F505/FD92/W1 Cybershot/Mavica Digital Cam
The USB id is now:
