serial =com4(usb) BarCodeScanner from Pi2 to Win7 Pro
markus
Post by markus »
Hi
i have a issue with redirect of an USB BarCodeScanner which is connect via USB to the Rasp PI2.
Since the last couple of days, the scanner was not longer seen in the virutal WIN 7 system. Wtware .5.4.20 was in use.
Today i proceed an upgrade to 5.4.68 version.
In the log I can seen that the barscanner but not in the Windows OS.
Please check.
attached you can find the log.
WTware v.5.4.68
WTware v.5.4.68/RPi supervisor.
[ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[ KERNEL] [ 0.000000] Initializing cgroup subsys cpuset
[ KERNEL] [ 0.000000] Initializing cgroup subsys cpuacct
[ KERNEL] [ 0.000000] Linux version 4.4.32 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #41 SMP Tue Dec 20 16:29:36 +04 2016
[ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80915640, node_mem_map b9fa6000
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (94c0->f3003010)
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ KERNEL] [ 0.000000] PERCPU: Embedded 11 pages/cpu @b9f6a000 s13324 r8192 d23540 u45056
[ KERNEL] [ 0.000000] pcpu-alloc: s13324 r8192 d23540 u45056 alloc=11*4096
[ KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2709.boardrev=0xa01041 bcm2709.serial=0xa780526c smsc95xx.macaddr=B8:27:EB:80:52:6C bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 939208K/966656K available (3807K kernel code, 169K rwdata, 1180K rodata, 4116K init, 365K bss, 19256K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] .text : 0x80008000 - 0x804e6f94 (4988 kB)
[ KERNEL] [ 0.000000] .init : 0x804e7000 - 0x808ec000 (4116 kB)
[ KERNEL] [ 0.000000] .data : 0x808ec000 - 0x80916540 ( 170 kB)
[ KERNEL] [ 0.000000] .bss : 0x80919000 - 0x80974588 ( 366 kB)
[ KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ KERNEL] [ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ KERNEL] [ 0.000029] Switching to timer-based delay loop, resolution 52ns
[ KERNEL] [ 0.000248] Console: colour dummy device 80x30
[ KERNEL] [ 0.000453] console [tty1] enabled
[ KERNEL] [ 0.000478] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.000500] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000663] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000681] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001825] Disabling cpuset control group subsystem
[ KERNEL] [ 0.001864] Initializing cgroup subsys io
[ KERNEL] [ 0.001896] Initializing cgroup subsys memory
[ KERNEL] [ 0.001943] Initializing cgroup subsys devices
[ KERNEL] [ 0.001967] Initializing cgroup subsys freezer
[ KERNEL] [ 0.002026] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.002659] CPU0: update cpu_capacity 1024
[ KERNEL] [ 0.002676] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ KERNEL] [ 0.002688] [bcm2709_smp_prepare_cpus] enter
[ KERNEL] [ 0.002774] Setting up static identity map for 0x8240 - 0x8274
[ KERNEL] [ 0.004736] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ KERNEL] [ 0.005026] [bcm2709_secondary_init] enter cpu:1
[ KERNEL] [ 0.005071] CPU1: update cpu_capacity 1024
[ KERNEL] [ 0.005079] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ KERNEL] [ 0.005574] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ KERNEL] [ 0.005801] [bcm2709_secondary_init] enter cpu:2
[ KERNEL] [ 0.005830] CPU2: update cpu_capacity 1024
[ KERNEL] [ 0.005838] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ KERNEL] [ 0.006287] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ KERNEL] [ 0.006489] [bcm2709_secondary_init] enter cpu:3
[ KERNEL] [ 0.006515] CPU3: update cpu_capacity 1024
[ KERNEL] [ 0.006522] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ KERNEL] [ 0.006599] Brought up 4 CPUs
[ KERNEL] [ 0.006626] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.006635] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.006643] CPU: Virtualization extensions available.
[ KERNEL] [ 0.007208] devtmpfs: initialized
[ KERNEL] [ 0.019179] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ KERNEL] [ 0.019683] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.020402] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.021015] NET: Registered protocol family 16
[ KERNEL] [ 0.026582] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.049944] cpuidle: using governor ladder
[ KERNEL] [ 0.079969] cpuidle: using governor menu
[ KERNEL] [ 0.087534] Serial: AMBA PL011 UART driver
[ KERNEL] [ 0.087926] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ KERNEL] [ 0.088315] console [ttyAMA0] enabled
[ KERNEL] [ 0.088997] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.173649] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ KERNEL] [ 0.174363] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.174549] usbcore: registered new interface driver hub
[ KERNEL] [ 0.174690] usbcore: registered new device driver usb
[ KERNEL] [ 0.180278] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-11-16 12:24
[ KERNEL] [ 0.209140] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.227428] NET: Registered protocol family 2
[ KERNEL] [ 0.228217] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.228355] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.228546] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.228664] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.228727] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.229021] NET: Registered protocol family 1
[ KERNEL] [ 2.847000] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 2.910395] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ KERNEL] [ 2.910438] io scheduler noop registered
[ KERNEL] [ 2.910517] io scheduler deadline registered (default)
[ KERNEL] [ 2.914035] BCM2708FB: allocated DMA memory fac00000
[ KERNEL] [ 2.914104] BCM2708FB: allocated DMA channel 0 @ f3007000
[ KERNEL] [ 2.946755] Console: switching to colour frame buffer device 170x48
[ KERNEL] [ 3.855447] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 3.855866] vc-cma: Videocore CMA driver
[ KERNEL] [ 3.855886] vc-cma: vc_cma_base = 0x00000000
[ KERNEL] [ 3.855897] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ KERNEL] [ 3.855907] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ KERNEL] [ 3.856497] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ KERNEL] [ 3.860237] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ KERNEL] [ 3.865209] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 4.065679] Core Release: 2.80a
[ KERNEL] [ 4.065705] Setting default values for core params
[ KERNEL] [ 4.065746] Finished setting default values for core params
[ KERNEL] [ 4.266202] Using Buffer DMA mode
[ KERNEL] [ 4.266226] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 4.266235] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 4.266246] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 4.266294] Dedicated Tx FIFOs mode
[ KERNEL] [ 4.266819] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ KERNEL] [ 4.266859] FIQ FSM acceleration enabled for :
[ KERNEL] [ 4.266859] Non-periodic Split Transactions
[ KERNEL] [ 4.266859] Periodic Split Transactions
[ KERNEL] [ 4.266859] High-Speed Isochronous Endpoints
[ KERNEL] [ 4.266859] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 4.266886] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 4.266943] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8025a938
[ KERNEL] [ 4.266960] WARN::hcd_init_fiq:414: FIQ ASM at 0x8025ac9c length 36
[ KERNEL] [ 4.266977] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb908000
[ KERNEL] [ 4.267049] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 4.267103] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 4.267148] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ KERNEL] [ 4.267203] Init: Port Power? op_state=1
[ KERNEL] [ 4.267212] Init: Power Port (0)
[ KERNEL] [ 4.267477] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 4.267496] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 4.267511] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 4.267526] usb usb1: Manufacturer: Linux 4.4.32 dwc_otg_hcd
[ KERNEL] [ 4.267540] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 4.268436] hub 1-0:1.0: USB hub found
[ KERNEL] [ 4.268514] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 4.269098] dwc_otg: FIQ enabled
[ KERNEL] [ 4.269168] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 4.269181] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 4.269232] Module dwc_common_port init
[ KERNEL] [ 4.272218] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 4.273151] bcm2835-cpufreq: min=600000 max=900000
[ KERNEL] [ 4.277640] sdhost: log_buf @ bac13000 (fac13000)
[ KERNEL] [ 4.329161] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 4.329889] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 4.331683] usbcore: registered new interface driver usbhid
[ KERNEL] [ 4.331700] usbhid: USB HID core driver
[ KERNEL] [ 4.332566] NET: Registered protocol family 17
[ KERNEL] [ 4.332914] Registering SWP/SWPB emulation handler
[ KERNEL] [ 4.350040] registered taskstats version 1
[ KERNEL] [ 4.350169] vc-sm: Videocore shared memory driver
[ KERNEL] [ 4.350187] [vc_sm_connected_init]: start
[ KERNEL] [ 4.350841] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 4.358328] Freeing unused kernel memory: 4116K (804e7000 - 808ec000)
[ KERNEL] [ 4.406625] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 4.409564] mmc0: new high speed SDHC card at address e624
[ KERNEL] [ 4.410926] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ KERNEL] [ 4.416160] mmcblk0: p1
[ hotplug] [ 4.409713] Block device 179:1. No action.
[ hotplug] [ 4.409831] Block device 179:0. No action.
[ KERNEL] [ 4.459257] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 4.639187] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 4.639343] Indeed it is in host mode hprt0 = 00001101
[ pfac] [ 4.676246] Run /sbin/initrd.
[ pfac] [ 4.676554] Ok, PID 537.
[ initrd] [ 4.680415] WTware shell v.5.4.68/RPi
[ initrd] [ 4.703289] Local media boot.
[ KERNEL] [ 4.839494] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ KERNEL] [ 4.839523] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.840481] hub 1-1:1.0: USB hub found
[ KERNEL] [ 4.840629] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 5.119184] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 5.219462] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ KERNEL] [ 5.219484] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 5.299187] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ KERNEL] [ 5.401696] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0610
[ KERNEL] [ 5.401718] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.401733] usb 1-1.2: Product: USB2.0 Hub
[ KERNEL] [ 5.401747] usb 1-1.2: Manufacturer: GenesysLogic
[ KERNEL] [ 5.402780] hub 1-1.2:1.0: USB hub found
[ KERNEL] [ 5.403196] hub 1-1.2:1.0: 4 ports detected
[ KERNEL] [ 5.499183] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[ KERNEL] [ 5.604247] usb 1-1.4: New USB device found, idVendor=0461, idProduct=4e22
[ KERNEL] [ 5.604269] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.604284] usb 1-1.4: Product: USB Optical Mouse
[ KERNEL] [ 5.604298] usb 1-1.4: Manufacturer: PixArt
[ KERNEL] [ 5.610733] input: PixArt USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:0461:4E22.0001/input/input0
[ KERNEL] [ 5.612025] hid-generic 0003:0461:4E22.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3f980000.usb-1.4/input0
[ KERNEL] [ 5.679180] usb 1-1.2.1: new low-speed USB device number 6 using dwc_otg
[ KERNEL] [ 5.791527] usb 1-1.2.1: New USB device found, idVendor=413c, idProduct=2107
[ KERNEL] [ 5.791551] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.791567] usb 1-1.2.1: Product: Dell USB Entry Keyboard
[ KERNEL] [ 5.791581] usb 1-1.2.1: Manufacturer: DELL
[ KERNEL] [ 5.800414] input: DELL Dell USB Entry Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:413C:2107.0002/input/input1
[ KERNEL] [ 5.860744] hid-generic 0003:413C:2107.0002: input,hidraw1: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-3f980000.usb-1.2.1/input0
[ KERNEL] [ 5.939179] usb 1-1.2.2: new full-speed USB device number 7 using dwc_otg
[ KERNEL] [ 6.052187] usb 1-1.2.2: New USB device found, idVendor=05e0, idProduct=1701
[ KERNEL] [ 6.052210] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 6.052226] usb 1-1.2.2: Product: Symbol Bar Code Scanner
[ KERNEL] [ 6.052240] usb 1-1.2.2: Manufacturer: ᄅSymbol Technologies, Inc, 2002
[ KERNEL] [ 6.052257] usb 1-1.2.2: SerialNumber: S/N:Symbol Scanner**************
[ initrd] [ 6.156827] WTpassword present: 9ea2ba7cc1e77936450a3a3e2b01ba8d.
| clientIP=*
| config=local
| setupPassword=9ea2ba7cc1e77936450a3a3e2b01ba8d
[ initrd] [ 8.167228] Load ethernet drivers.
[ initrd] [ 8.167376] modprobe smsc95xx.
[ KERNEL] [ 8.186597] smsc95xx v1.0.4
[ KERNEL] [ 8.243790] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:80:52:6c
[ KERNEL] [ 8.244077] usbcore: registered new interface driver smsc95xx
[ KERNEL] [ 8.301575] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ KERNEL] [ 9.769674] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ initrd] [ 9.796784] WTpassword present: 9ea2ba7cc1e77936450a3a3e2b01ba8d.
[ initrd] [ 13.140261] dhcp: 324 bytes from 192.168.1.4.
[ initrd] [ 13.140546] 00000000:000001300000000000110000c0a80104c0a80170004300440130000002010600 ...0..............p.C.D.0......
[ initrd] [ 13.140737] 00000020:67458b6b0000000000000000c0a80170c0a8010400000000b827eb80526c0000 gE.k...........p.........'..Rl..
[ initrd] [ 13.140920] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.141098] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.141275] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.141453] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.141631] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.141807] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ KERNEL] [ 13.768010] random: nonblocking pool is initialized
[ initrd] [ 14.620215] dhcp: 324 bytes from 192.168.1.4.
[ initrd] [ 14.620453] 00000000:000001300000000000110000c0a80104c0a80170004300440130000002010600 ...0..............p.C.D.0......
[ initrd] [ 14.620638] 00000020:67458b6b0000000000000000c0a80170c0a8010400000000b827eb80526c0000 gE.k...........p.........'..Rl..
[ initrd] [ 14.620815] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.620993] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.621172] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.621349] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.621562] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.621741] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.650168] dhcp: server address 192.168.1.4.
[ initrd] [ 14.650339] dhcp: 192.168.1.112/255.255.255.0.
[ initrd] [ 14.650500] dhcp: default gateway 192.168.1.1.
[ initrd] [ 14.650676] dhcp: DNS 192.168.1.40.
[ initrd] [ 14.650828] dhcp: DNS 192.168.1.41.
[ initrd] [ 14.650981] dhcp: domain ff-mistelbach.at.
[ initrd] [ 14.651132] dhcp: TFTP from siaddr 192.168.1.4.
[ initrd] [ 14.651283] dhcp: TFTP 192.168.1.4.
[ initrd] [ 14.651432] No boot file from DHCP.
[ initrd] [ 14.651584] TFTP binary "", configs prefix "", using "/" slash.
[ initrd] [ 14.654682] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 14.654831] Run /sbin/httpd.
[ pfac] [ 14.655319] Ok, PID 580.
[ httpd] [ 14.666757] HTTP Server, WTware v.5.4.68/RPi
[ initrd] [ 14.793929] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[ initrd] [ 14.794151] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[ initrd] [ 14.794276] USB: 05e3:0610 Genesys Logic, Inc. 4-port hub.
[ initrd] [ 14.794400] USB: 0461:4e22 Primax Electronics, Ltd.
[ initrd] [ 14.794511] USB: 413c:2107 Dell Computer Corp..
[ initrd] [ 14.794616] USB: 05e0:1701 Symbol Technologies Bar Code Scanner (CDC).
[ initrd] [ 14.794720] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 14.797786] Common local disk config:
| bpp=32
| display=1920x1200
| server=192.168.1.66
| serial=COM4(usb)
| sound=on
| sound_level=50
| sound_rate=48000
| sound_buffer=250
| timezone=W. Europe Standard Time
| domain=FFMistelbach
| ask_password=onpin
| keyboard=de
| language=de,default
| graphic=abcdefg
| microphone_level=0
| clipboard=on
| clienthostname=ffatem1
| turnoffmenu=always
| autoshutdown=30
| animation_speed=3
| vnc=on
| vnc_password=xxxxxxx
| doubleclick=200
| chrome_language=en
| chrome_url=http://www.ff-mistelbach.at
| bpp=32
| display=1920x1200
| server=192.168.1.66
| serial=COM4(usb)
| sound=on
| sound_level=50
| sound_rate=48000
| sound_buffer=250
| domain=FFMistelbach
| ask_password=onpin
| keyboard=de
| language=de,default
| graphic=abcdefg
| microphone_level=0
| clipboard=on
| turnoffmenu=always
| autoshutdown=30
| animation_speed=3
| vnc=on
| doubleclick=200
| chrome_language=en
[ initrd] [ 14.824140] Hostname: "ffatem1".
[ httpd] [ 15.040222] Reread settings.
[ gm] [ 15.045089] WTware session manager v.5.4.68/RPi.
[ gm] [ 15.045240] Add keyboard event1: DELL Dell USB Entry Keyboard.
[ httpd] [ 15.045628] Everyone can control terminal by HTTP.
[ gm] [ 15.100195] EV_REL flag found. Add mouse event0: PixArt USB Optical Mouse.
[ gm] [ 15.100723] Display mode: 1360x768, 32 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 15.123504] Framebuffer device found.
[ gm] [ 15.123717] LINELENBYTES 5440
[ gm] [ 15.123888] VLEN 4177920
[ gm] [ 15.148157] Use /lib/ui32.so.
[ gm] [ 15.176034] Run serial daemon for ttyACM0.
[ gm] [ 15.176371] Run '/sbin/rdpdr[serial] 4', log '', env '', pid ''.
[ gm] [ 15.176728] Run serial daemon for ttyUSB0.
[ pfac] [ 15.176867] Run /sbin/rdpdr[serial] 4.
[ pfac] [ 15.177142] Ok, PID 581.
[ gm] [ 15.177250] Run '/sbin/rdpdr[serial] 0', log '', env '', pid ''.
[ pfac] [ 15.177630] Run /sbin/rdpdr[serial] 0.
[ pfac] [ 15.177956] Ok, PID 582.
[rdpdr-serial 4] [ 15.181670] RDP Serial Port Redirector, WTware v.5.4.68/RPi, device ttyACM0.
[rdpdr-serial 0] [ 15.181997] RDP Serial Port Redirector, WTware v.5.4.68/RPi, device ttyUSB0.
[ gm] [ 15.189570] Unpack /bootmedia/packages/pi2-alsa.
[ gm] [ 15.318600] modprobe snd-bcm2835.
[ gm] [ 15.342806] modprobe snd-usb-audio.
[ KERNEL] [ 15.374756] usbcore: registered new interface driver snd-usb-audio
[ gm] [ 30.387735] [SOUND ERROR] ==================================================
[ gm] [ 30.387997] [SOUND ERROR] Uncomment "dtparam=audio=on" line in config.txt
[ gm] [ 30.388147] [SOUND ERROR] on SD card to pass sound to HDMI.
[ gm] [ 30.388287] [SOUND ERROR] ==================================================
[ gm] [ 30.388411] hardware.cpp ( 1119): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 30.388529] globalConfig.cpp ( 1779): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 30.388642] ERROR: Sound card not found. Disable sound.
[ gm] [ 30.388752] Load usb <-> serial bridges drivers.
[ gm] [ 30.388866] modprobe usbserial.
[ KERNEL] [ 30.408314] usbcore: registered new interface driver usbserial
[ KERNEL] [ 30.408474] usbcore: registered new interface driver usbserial_generic
[ KERNEL] [ 30.408610] usbserial: USB Serial support registered for generic
[ gm] [ 30.401037] modprobe pl2303.
[ gm] [ 30.414475] modprobe ftdi_sio.
[ KERNEL] [ 30.421480] usbcore: registered new interface driver pl2303
[ KERNEL] [ 30.421644] usbserial: USB Serial support registered for pl2303
[ gm] [ 30.431069] modprobe cp210x.
[ KERNEL] [ 30.437469] usbcore: registered new interface driver ftdi_sio
[ KERNEL] [ 30.437640] usbserial: USB Serial support registered for FTDI USB Serial Device
[ gm] [ 30.443257] modprobe ch341.
[ KERNEL] [ 30.450829] usbcore: registered new interface driver cp210x
[ KERNEL] [ 30.450993] usbserial: USB Serial support registered for cp210x
[ gm] [ 30.455846] modprobe metro-usb.
[ KERNEL] [ 30.463626] usbcore: registered new interface driver ch341
[ KERNEL] [ 30.463787] usbserial: USB Serial support registered for ch341-uart
[ gm] [ 30.468796] modprobe symbolserial.
[ KERNEL] [ 30.476589] usbcore: registered new interface driver metro_usb
[ KERNEL] [ 30.476737] usbserial: USB Serial support registered for Metrologic USB to Serial
[ gm] [ 30.482891] modprobe opticon.
[ KERNEL] [ 30.489745] usbcore: registered new interface driver symbolserial
[ KERNEL] [ 30.489896] usbserial: USB Serial support registered for symbol
[ gm] [ 30.495633] modprobe cdc-acm.
[ KERNEL] [ 30.502349] usbcore: registered new interface driver opticon
[ KERNEL] [ 30.502600] usbserial: USB Serial support registered for opticon
[ KERNEL] [ 30.517911] cdc_acm 1-1.2.2:1.0: ttyACM0: USB ACM device
[ KERNEL] [ 30.520245] usbcore: registered new interface driver cdc_acm
[ KERNEL] [ 30.520267] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ gm] [ 30.522858] Run '/sbin/resolver 0x13bb118 dns [192.168.1.66]', log '', env '', pid ''.
[ pfac] [ 30.523097] Run /sbin/resolver 0x13bb118 dns [192.168.1.66].
[ gm] [ 30.523196] Everyone can control terminal by VNC.
[ pfac] [ 30.523378] Ok, PID 658.
[ gm] [ 30.523492] VNC listener at port 5900.
[ pfac] [ 30.531864] Process pid 658 terminated, status 00000000.
[ gm] [ 30.532091] 192.168.1.66 => 192.168.1.66.
[ gm] [ 30.532223] Incorrect parameter value: ask_password = onpin
[ gm] [ 30.532346] Free ram before fork terminal client /sbin/rdpclient (session 1): 922440 Kb.
[ pfac] [ 30.532469] Run /sbin/rdpclient 1.
[ gm] [ 30.532549] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 30.532848] Ok, PID 659.
[ rdpclient 659] [ 30.543322] RDP Terminal Client, WTware v.5.4.68/RPi, pipe 1, pid 659.
[ gm] [ 30.544517] COM4 => ttyACM0, single device.
[ rdpclient 659] [ 30.544683] Use /lib/ui32.so.
[ rdpclient 659] [ 30.545640] Add serial redirection, COM4 in the session = hardware ttyACM0.
[rdpdr-serial 4] [ 30.546288] New client connection, id 1.
[ rdpclient 659] [ 30.546378] Make RDP session with 192.168.1.66, port 3389.
[ rdpclient 659] [ 30.546511] No username.
[ rdpclient 659] [ 30.546920] No password.
[ rdpclient 659] [ 30.547053] No PIN.
[ rdpclient 659] [ 30.547183] Domain: "FFMistelbach".
[ rdpclient 659] [ 30.547309] No shell.
[ rdpclient 659] [ 30.547430] No directory.
[ rdpclient 659] [ 30.547566] Window: 1360x768@24.
[ rdpclient 659] [ 30.547716] PFlags 0x00000180.
[ rdpclient 659] [ 30.547862] Keyboard 00000407:00000000.
[ rdpclient 659] [ 30.548019] My hostname "ffatem1".
[ rdpclient 659] [ 30.548181] TCP: connecting to 192.168.1.66:3389.
[ rdpclient 659] [ 30.548328] TCP: connection with 192.168.1.66:3389 established.
[ rdpclient 659] [ 30.548499] Turn keepalive on.
[ rdpclient 659] [ 30.548813] Free ram after buffers allocation: 921764 KB.
[ rdpclient 659] [ 30.557459] Server supports GFX Pipeline.
[ rdpclient 659] [ 30.561129] Process RDP server certificate.
[ rdpclient 659] [ 30.561279] RDP4 encryption.
[ rdpclient 659] [ 30.567841] Timezone '(UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna'.
[ rdpclient 659] [ 30.568001] Enable font smoothing and Desktop Composition.
[ rdpclient 659] [ 30.776516] GFX codec.
[ rdpclient 659] [ 31.440341] Run 4 tile threads.
[ rdpclient 659] [ 57.813770] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000003.
[ rdpclient 659] [ 58.250874] SessionId 0x00000003: ffclient4\Admin.
[ httpd] [ 113.830254] read() failed, errno 11.
[ httpd] [ 113.830491] read() failed, errno 11.
[ httpd] [ 249.130211] read() failed, errno 11.
[ httpd] [ 249.130441] read() failed, errno 11.
[ httpd] [ 249.130948] read() failed, errno 11.
[ httpd] [ 249.131101] read() failed, errno 11.
Home WTware diskless client.
markus
Re: serial =com4(usb) BarCodeScanner from Pi2 to Win7 Pro
Post by markus »
After an additional test i found the following messages in the log, please help.
Either an addiontal issue with the USB HUb.
Please replace it, but why the scanner goes to ttyACM1 now?
Is there a possibility to redirect right?
Within in former post, i tried to redirect only the USB device ID - you mentioned to use serial=com4(USB)
markus
WTware v.5.4.68
[ KERNEL] [ 1244.787441] dwc_otg: DEVICE:007 : update_urb_state_xfer_intr:1435:trimming xfer length
[ KERNEL] [ 1262.424834] usb 1-1.2: USB disconnect, device number 4
[ KERNEL] [ 1262.424865] usb 1-1.2.1: USB disconnect, device number 6
[ KERNEL] [ 1262.426471] cdc_acm 1-1.2.2:1.0: acm_ctrl_irq - usb_submit_urb failed: -19
[ gm] [ 1262.510742] Close input device 'DELL Dell USB Entry Keyboard', errno 19.
[ KERNEL] [ 1262.570972] usb 1-1.2.2: USB disconnect, device number 7
[ KERNEL] [ 1262.809186] usb 1-1.2: new high-speed USB device number 8 using dwc_otg
[ KERNEL] [ 1262.911799] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0610
[ KERNEL] [ 1262.911826] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 1262.911842] usb 1-1.2: Product: USB2.0 Hub
[ KERNEL] [ 1262.911857] usb 1-1.2: Manufacturer: GenesysLogic
[ KERNEL] [ 1262.913067] hub 1-1.2:1.0: USB hub found
[ KERNEL] [ 1262.913674] hub 1-1.2:1.0: 4 ports detected
[rdpdr-serial 4] [ 1262.924385] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1262.924590] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[ KERNEL] [ 1263.189191] usb 1-1.2.1: new low-speed USB device number 9 using dwc_otg
[ KERNEL] [ 1263.299191] usb 1-1.2.1: New USB device found, idVendor=413c, idProduct=2107
[ KERNEL] [ 1263.299214] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 1263.299231] usb 1-1.2.1: Product: Dell USB Entry Keyboard
[ KERNEL] [ 1263.299245] usb 1-1.2.1: Manufacturer: DELL
[ KERNEL] [ 1263.307133] input: DELL Dell USB Entry Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:413C:2107.0003/input/input2
[ KERNEL] [ 1263.360861] hid-generic 0003:413C:2107.0003: input,hidraw1: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-3f980000.usb-1.2.1/input0
[ KERNEL] [ 1263.439190] usb 1-1.2.2: new full-speed USB device number 10 using dwc_otg
[ KERNEL] [ 1263.552096] usb 1-1.2.2: New USB device found, idVendor=05e0, idProduct=1701
[ KERNEL] [ 1263.552119] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 1263.552136] usb 1-1.2.2: Product: Symbol Bar Code Scanner
[ KERNEL] [ 1263.552151] usb 1-1.2.2: Manufacturer: ᄅSymbol Technologies, Inc, 2002
[ KERNEL] [ 1263.552166] usb 1-1.2.2: SerialNumber: S/N:Symbol Scanner**************
[ KERNEL] [ 1263.555524] cdc_acm 1-1.2.2:1.0: ttyACM1: USB ACM device
[rdpdr-serial 4] [ 1263.564419] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1263.564620] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1264.194211] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1264.194382] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1264.834249] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1264.834408] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1265.483366] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1265.483546] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1266.113275] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1266.113431] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1266.753290] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1266.753436] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1267.394333] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1267.394473] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1268.034295] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1268.034434] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1268.674341] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1268.674479] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1269.318402] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1269.318543] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1269.958405] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1269.958546] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1270.598414] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1270.598555] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1271.238417] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1271.238562] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1271.877435] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1271.877576] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1272.517447] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1272.517594] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1273.157681] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1273.157819] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1273.797572] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1273.797716] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1274.437622] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1274.437763] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1275.077665] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1275.077809] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1275.707706] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1275.707848] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1276.347720] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1276.347856] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1276.986719] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1276.986939] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1277.626785] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1277.627000] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1278.266779] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1278.266995] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1278.906733] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1278.906944] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1279.546759] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1279.546978] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1280.186803] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1280.187022] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1280.826874] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1280.827090] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1281.466921] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1281.467132] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[ KERNEL] [ 1281.540150] usb 1-1.2.2: USB disconnect, device number 10
[ KERNEL] [ 1281.939181] usb 1-1.2.2: new full-speed USB device number 11 using dwc_otg
[ KERNEL] [ 1282.052067] usb 1-1.2.2: New USB device found, idVendor=05e0, idProduct=1701
[ KERNEL] [ 1282.052092] usb 1-1.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 1282.052109] usb 1-1.2.2: Product: Symbol Bar Code Scanner
[ KERNEL] [ 1282.052125] usb 1-1.2.2: Manufacturer: ᄅSymbol Technologies, Inc, 2002
[ KERNEL] [ 1282.052140] usb 1-1.2.2: SerialNumber: S/N:Symbol Scanner**************
[ KERNEL] [ 1282.054245] cdc_acm 1-1.2.2:1.0: ttyACM1: USB ACM device
[rdpdr-serial 4] [ 1282.107201] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1282.107392] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1282.747033] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1282.747198] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1283.387026] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1283.387177] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1284.026984] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1284.027133] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1284.667037] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1284.667179] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1285.307079] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1285.307218] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1285.947118] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1285.947264] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1286.585098] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1286.585239] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1287.225136] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1287.225283] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1287.865194] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1287.865332] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1288.505235] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1288.505376] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1289.145205] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1289.145343] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1289.785245] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1289.785385] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1290.425217] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1290.425357] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1291.065337] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1291.065472] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1291.705370] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1291.705506] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1292.345450] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1292.345622] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1292.985362] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1292.985520] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1293.625367] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1293.625534] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1294.265365] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1294.265499] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1294.905364] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1294.905498] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1295.545388] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1295.545531] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1296.185503] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1296.185639] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1296.824439] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1296.824575] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1297.460524] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1297.460655] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1298.100497] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1298.100632] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1298.740567] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1298.740704] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1299.374564] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1299.374700] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1300.014511] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1300.014643] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1300.654532] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1300.654666] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1301.294643] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1301.294779] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1301.934636] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1301.934775] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1302.574678] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1302.574815] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1303.216662] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1303.216823] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1303.856664] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1303.856858] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1304.496651] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1304.496791] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1305.136700] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1305.136838] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1305.776721] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1305.776855] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1306.416796] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1306.416934] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1307.057833] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1307.057968] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1307.697864] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1307.697999] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1308.337938] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1308.338072] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1308.977930] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1308.978066] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1309.607838] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1309.607974] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1310.247901] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1310.248039] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1310.888026] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1310.888199] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1311.528113] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1311.528314] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1312.168154] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1312.168358] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1312.808111] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1312.808300] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1313.448272] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1313.448481] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1314.088064] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1314.088227] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1314.728172] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1314.728371] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1315.368101] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1315.368284] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1316.008239] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1316.008434] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1316.648175] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1316.648375] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1317.288271] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1317.288472] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1317.926197] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1317.926388] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1318.566414] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1318.566625] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1319.206367] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1319.206564] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1319.846271] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1319.846433] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1320.486450] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1320.486657] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1321.126397] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1321.126594] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1321.766414] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1321.766602] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1322.406375] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1322.406558] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1323.046359] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1323.046538] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1323.686854] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1323.687041] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1324.326532] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1324.326747] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1324.966425] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1324.966624] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1325.606485] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1325.606689] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1326.246500] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1326.246699] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1326.886795] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1326.887012] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1327.517681] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1327.517937] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1328.165592] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1328.165818] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1328.805423] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1328.805584] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1329.441405] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1329.441558] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1330.081448] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1330.081627] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1330.721994] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1330.722386] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1331.361533] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1331.361732] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1332.001569] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1332.001754] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1332.641614] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1332.641777] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1333.281786] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1333.281975] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1333.918626] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1333.918821] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1334.558834] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1334.559032] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1335.198770] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1335.199015] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1335.838836] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1335.839025] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1336.479808] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1336.480091] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1337.118741] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1337.118948] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1337.759071] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1337.759257] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1338.398722] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1338.398887] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1339.039000] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1339.039261] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1339.678751] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1339.678965] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1340.318824] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1340.319044] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1340.958939] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1340.959175] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1341.588894] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1341.589096] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1342.228861] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1342.229056] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1342.868877] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1342.869076] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1343.508911] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1343.509095] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1344.148972] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1344.149176] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1344.790197] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1344.790416] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1345.429170] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1345.429379] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1346.069059] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1346.069259] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1346.706087] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1346.706289] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1347.347344] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1347.347549] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1347.986153] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1347.986344] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1348.625159] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1348.625357] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1349.272242] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1349.272422] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1349.905724] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1349.905988] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1350.549300] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1350.549481] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1351.184523] rdpdr[serial]-worker.cpp ( 1451): -- ERROR -- ioctl failed, return -1, errno 5.
[rdpdr-serial 4] [ 1351.184736] rdpdr[serial]-worker.cpp ( 1455): -- ERROR -- ioctl failed, return -1, errno 5.
Please, show me the full log. From boot to the error. Do not disconnect scanner while you use it. Remove USB hub if there's any. Check twice, that you provide enough power to Raspberry.
markus
Post by markus »
HI,
I changed the USB Port of the BarCode Scanner from the USB Hub(where it was near by one year) to the Rasp direct.
In the log you can see the change. Nothing changed in issue.
WTware v.5.4.68
WTware v.5.4.68/RPi supervisor.
[ KERNEL] [ 0.000000] Booting Linux on physical CPU 0xf00
[ KERNEL] [ 0.000000] Initializing cgroup subsys cpuset
[ KERNEL] [ 0.000000] Initializing cgroup subsys cpuacct
[ KERNEL] [ 0.000000] Linux version 4.4.32 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #41 SMP Tue Dec 20 16:29:36 +04 2016
[ KERNEL] [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ KERNEL] [ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ KERNEL] [ 0.000000] free_area_init_node: node 0, pgdat 80915640, node_mem_map b9fa6000
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] enter (94c0->f3003010)
[ KERNEL] [ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ KERNEL] [ 0.000000] PERCPU: Embedded 11 pages/cpu @b9f6a000 s13324 r8192 d23540 u45056
[ KERNEL] [ 0.000000] pcpu-alloc: s13324 r8192 d23540 u45056 alloc=11*4096
[ KERNEL] [ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2709.boardrev=0xa01041 bcm2709.serial=0xa780526c smsc95xx.macaddr=B8:27:EB:80:52:6C bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 console=ttyAMA0,115200 console=tty1 quiet wtboot=mmc
[ KERNEL] [ 0.000000] Memory: 939208K/966656K available (3807K kernel code, 169K rwdata, 1180K rodata, 4116K init, 365K bss, 19256K reserved, 8192K cma-reserved)
[ KERNEL] [ 0.000000] .text : 0x80008000 - 0x804e6f94 (4988 kB)
[ KERNEL] [ 0.000000] .init : 0x804e7000 - 0x808ec000 (4116 kB)
[ KERNEL] [ 0.000000] .data : 0x808ec000 - 0x80916540 ( 170 kB)
[ KERNEL] [ 0.000000] .bss : 0x80919000 - 0x80974588 ( 366 kB)
[ KERNEL] [ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ KERNEL] [ 0.000010] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ KERNEL] [ 0.000028] Switching to timer-based delay loop, resolution 52ns
[ KERNEL] [ 0.000249] Console: colour dummy device 80x30
[ KERNEL] [ 0.000454] console [tty1] enabled
[ KERNEL] [ 0.000478] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ KERNEL] [ 0.000501] pid_max: default: 32768 minimum: 301
[ KERNEL] [ 0.000666] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.000683] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ KERNEL] [ 0.001812] Disabling cpuset control group subsystem
[ KERNEL] [ 0.001850] Initializing cgroup subsys io
[ KERNEL] [ 0.001881] Initializing cgroup subsys memory
[ KERNEL] [ 0.001930] Initializing cgroup subsys devices
[ KERNEL] [ 0.001955] Initializing cgroup subsys freezer
[ KERNEL] [ 0.002016] CPU: Testing write buffer coherency: ok
[ KERNEL] [ 0.002648] CPU0: update cpu_capacity 1024
[ KERNEL] [ 0.002669] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ KERNEL] [ 0.002682] [bcm2709_smp_prepare_cpus] enter
[ KERNEL] [ 0.002766] Setting up static identity map for 0x8240 - 0x8274
[ KERNEL] [ 0.004759] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ KERNEL] [ 0.005050] [bcm2709_secondary_init] enter cpu:1
[ KERNEL] [ 0.005096] CPU1: update cpu_capacity 1024
[ KERNEL] [ 0.005104] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ KERNEL] [ 0.005607] [bcm2709_boot_secondary] cpu:2 started (0) 16
[ KERNEL] [ 0.005835] [bcm2709_secondary_init] enter cpu:2
[ KERNEL] [ 0.005863] CPU2: update cpu_capacity 1024
[ KERNEL] [ 0.005871] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ KERNEL] [ 0.006325] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ KERNEL] [ 0.006530] [bcm2709_secondary_init] enter cpu:3
[ KERNEL] [ 0.006555] CPU3: update cpu_capacity 1024
[ KERNEL] [ 0.006563] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ KERNEL] [ 0.006640] Brought up 4 CPUs
[ KERNEL] [ 0.006667] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ KERNEL] [ 0.006677] CPU: All CPU(s) started in HYP mode.
[ KERNEL] [ 0.006685] CPU: Virtualization extensions available.
[ KERNEL] [ 0.007253] devtmpfs: initialized
[ KERNEL] [ 0.019232] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ KERNEL] [ 0.019727] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ KERNEL] [ 0.020428] pinctrl core: initialized pinctrl subsystem
[ KERNEL] [ 0.021040] NET: Registered protocol family 16
[ KERNEL] [ 0.026647] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ KERNEL] [ 0.049965] cpuidle: using governor ladder
[ KERNEL] [ 0.079990] cpuidle: using governor menu
[ KERNEL] [ 0.087567] Serial: AMBA PL011 UART driver
[ KERNEL] [ 0.087957] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ KERNEL] [ 0.088346] console [ttyAMA0] enabled
[ KERNEL] [ 0.089033] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ KERNEL] [ 0.163667] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ KERNEL] [ 0.164391] usbcore: registered new interface driver usbfs
[ KERNEL] [ 0.164572] usbcore: registered new interface driver hub
[ KERNEL] [ 0.164710] usbcore: registered new device driver usb
[ KERNEL] [ 0.170305] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-11-16 12:24
[ KERNEL] [ 0.199191] clocksource: Switched to clocksource arch_sys_counter
[ KERNEL] [ 0.216888] NET: Registered protocol family 2
[ KERNEL] [ 0.217675] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ KERNEL] [ 0.217812] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ KERNEL] [ 0.218003] TCP: Hash tables configured (established 8192 bind 8192)
[ KERNEL] [ 0.218120] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.218181] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ KERNEL] [ 0.218484] NET: Registered protocol family 1
[ KERNEL] [ 2.843015] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ KERNEL] [ 2.906440] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ KERNEL] [ 2.906476] io scheduler noop registered
[ KERNEL] [ 2.906499] io scheduler deadline registered (default)
[ KERNEL] [ 2.915005] BCM2708FB: allocated DMA memory fac00000
[ KERNEL] [ 2.915069] BCM2708FB: allocated DMA channel 0 @ f3007000
[ KERNEL] [ 2.947713] Console: switching to colour frame buffer device 170x48
[ KERNEL] [ 3.859470] bcm2835-rng 3f104000.rng: hwrng registered
[ KERNEL] [ 3.859903] vc-cma: Videocore CMA driver
[ KERNEL] [ 3.859928] vc-cma: vc_cma_base = 0x00000000
[ KERNEL] [ 3.859939] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ KERNEL] [ 3.859950] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ KERNEL] [ 3.860329] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ KERNEL] [ 3.863983] vchiq: vchiq_init_state: slot_zero = 0xbac80000, is_master = 0
[ KERNEL] [ 3.869248] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ KERNEL] [ 4.069707] Core Release: 2.80a
[ KERNEL] [ 4.069732] Setting default values for core params
[ KERNEL] [ 4.069775] Finished setting default values for core params
[ KERNEL] [ 4.270191] Using Buffer DMA mode
[ KERNEL] [ 4.270216] Periodic Transfer Interrupt Enhancement - disabled
[ KERNEL] [ 4.270225] Multiprocessor Interrupt Enhancement - disabled
[ KERNEL] [ 4.270236] OTG VER PARAM: 0, OTG VER FLAG: 0
[ KERNEL] [ 4.270285] Dedicated Tx FIFOs mode
[ KERNEL] [ 4.270817] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma = 0xfac14000 len=9024
[ KERNEL] [ 4.270860] FIQ FSM acceleration enabled for :
[ KERNEL] [ 4.270860] Non-periodic Split Transactions
[ KERNEL] [ 4.270860] Periodic Split Transactions
[ KERNEL] [ 4.270860] High-Speed Isochronous Endpoints
[ KERNEL] [ 4.270860] Interrupt/Control Split Transaction hack enabled
[ KERNEL] [ 4.270887] dwc_otg: Microframe scheduler enabled
[ KERNEL] [ 4.270948] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8025a938
[ KERNEL] [ 4.270967] WARN::hcd_init_fiq:414: FIQ ASM at 0x8025ac9c length 36
[ KERNEL] [ 4.270984] WARN::hcd_init_fiq:439: MPHI regs_base at 0xbb908000
[ KERNEL] [ 4.271062] dwc_otg 3f980000.usb: DWC OTG Controller
[ KERNEL] [ 4.271143] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ KERNEL] [ 4.271189] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ KERNEL] [ 4.271243] Init: Port Power? op_state=1
[ KERNEL] [ 4.271252] Init: Power Port (0)
[ KERNEL] [ 4.271521] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ KERNEL] [ 4.271542] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ KERNEL] [ 4.271558] usb usb1: Product: DWC OTG Controller
[ KERNEL] [ 4.271573] usb usb1: Manufacturer: Linux 4.4.32 dwc_otg_hcd
[ KERNEL] [ 4.271587] usb usb1: SerialNumber: 3f980000.usb
[ KERNEL] [ 4.272474] hub 1-0:1.0: USB hub found
[ KERNEL] [ 4.272543] hub 1-0:1.0: 1 port detected
[ KERNEL] [ 4.273185] dwc_otg: FIQ enabled
[ KERNEL] [ 4.273207] dwc_otg: NAK holdoff enabled
[ KERNEL] [ 4.273221] dwc_otg: FIQ split-transaction FSM enabled
[ KERNEL] [ 4.273268] Module dwc_common_port init
[ KERNEL] [ 4.276337] usbcore: registered new interface driver usbtouchscreen
[ KERNEL] [ 4.277235] bcm2835-cpufreq: min=600000 max=900000
[ KERNEL] [ 4.280491] sdhost: log_buf @ bac13000 (fac13000)
[ KERNEL] [ 4.339217] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ KERNEL] [ 4.339944] hidraw: raw HID events driver (C) Jiri Kosina
[ KERNEL] [ 4.341673] usbcore: registered new interface driver usbhid
[ KERNEL] [ 4.341696] usbhid: USB HID core driver
[ KERNEL] [ 4.342677] NET: Registered protocol family 17
[ KERNEL] [ 4.343047] Registering SWP/SWPB emulation handler
[ KERNEL] [ 4.346695] registered taskstats version 1
[ KERNEL] [ 4.346795] vc-sm: Videocore shared memory driver
[ KERNEL] [ 4.346811] [vc_sm_connected_init]: start
[ KERNEL] [ 4.360130] [vc_sm_connected_init]: end - returning 0
[ KERNEL] [ 4.367333] Freeing unused kernel memory: 4116K (804e7000 - 808ec000)
[ KERNEL] [ 4.416556] mmc0: host does not support reading read-only switch, assuming write-enable
[ KERNEL] [ 4.420026] mmc0: new high speed SDHC card at address e624
[ KERNEL] [ 4.422840] mmcblk0: mmc0:e624 SU08G 7.40 GiB
[ KERNEL] [ 4.427591] mmcblk0: p1
[ hotplug] [ 4.421075] Block device 179:0. No action.
[ hotplug] [ 4.422343] Block device 179:1. No action.
[ KERNEL] [ 4.469412] Indeed it is in host mode hprt0 = 00021501
[ KERNEL] [ 4.649246] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ KERNEL] [ 4.649401] Indeed it is in host mode hprt0 = 00001101
[ pfac] [ 4.686248] Run /sbin/initrd.
[ pfac] [ 4.686386] Ok, PID 537.
[ initrd] [ 4.688965] WTware shell v.5.4.68/RPi
[ initrd] [ 4.712280] Local media boot.
[ KERNEL] [ 4.849555] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ KERNEL] [ 4.849588] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 4.850942] hub 1-1:1.0: USB hub found
[ KERNEL] [ 4.851117] hub 1-1:1.0: 5 ports detected
[ KERNEL] [ 5.129224] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ KERNEL] [ 5.229528] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ KERNEL] [ 5.229550] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ KERNEL] [ 5.309227] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ KERNEL] [ 5.411689] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0610
[ KERNEL] [ 5.411715] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.411730] usb 1-1.2: Product: USB2.0 Hub
[ KERNEL] [ 5.411744] usb 1-1.2: Manufacturer: GenesysLogic
[ KERNEL] [ 5.413103] hub 1-1.2:1.0: USB hub found
[ KERNEL] [ 5.416062] hub 1-1.2:1.0: 4 ports detected
[ KERNEL] [ 5.509246] usb 1-1.4: new full-speed USB device number 5 using dwc_otg
[ KERNEL] [ 5.661037] usb 1-1.4: New USB device found, idVendor=05e0, idProduct=1701
[ KERNEL] [ 5.661060] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ KERNEL] [ 5.661075] usb 1-1.4: Product: Symbol Bar Code Scanner
[ KERNEL] [ 5.661090] usb 1-1.4: Manufacturer: ᄅSymbol Technologies, Inc, 2002
[ KERNEL] [ 5.661105] usb 1-1.4: SerialNumber: S/N:Symbol Scanner**************
[ KERNEL] [ 5.729253] usb 1-1.2.1: new low-speed USB device number 6 using dwc_otg
[ KERNEL] [ 5.841563] usb 1-1.2.1: New USB device found, idVendor=413c, idProduct=2107
[ KERNEL] [ 5.841586] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 5.841601] usb 1-1.2.1: Product: Dell USB Entry Keyboard
[ KERNEL] [ 5.841616] usb 1-1.2.1: Manufacturer: DELL
[ KERNEL] [ 5.849940] input: DELL Dell USB Entry Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:413C:2107.0001/input/input0
[ KERNEL] [ 5.916108] hid-generic 0003:413C:2107.0001: input,hidraw0: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-3f980000.usb-1.2.1/input0
[ KERNEL] [ 5.989249] usb 1-1.2.4: new low-speed USB device number 7 using dwc_otg
[ initrd] [ 6.014758] WTpassword present: 9ea2ba7cc1e77936450a3a3e2b01ba8d.
[ KERNEL] [ 6.095610] usb 1-1.2.4: New USB device found, idVendor=0461, idProduct=4e22
[ KERNEL] [ 6.095637] usb 1-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ KERNEL] [ 6.095652] usb 1-1.2.4: Product: USB Optical Mouse
[ KERNEL] [ 6.095666] usb 1-1.2.4: Manufacturer: PixArt
[ KERNEL] [ 6.102343] input: PixArt USB Optical Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4:1.0/0003:0461:4E22.0002/input/input1
[ KERNEL] [ 6.102867] hid-generic 0003:0461:4E22.0002: input,hidraw1: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-3f980000.usb-1.2.4/input0
| clientIP=*
| config=local
| setupPassword=9ea2ba7cc1e77936450a3a3e2b01ba8d
[ initrd] [ 8.027339] Load ethernet drivers.
[ initrd] [ 8.027495] modprobe smsc95xx.
[ KERNEL] [ 8.046804] smsc95xx v1.0.4
[ KERNEL] [ 8.113108] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:80:52:6c
[ KERNEL] [ 8.113439] usbcore: registered new interface driver smsc95xx
[ KERNEL] [ 8.171645] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ KERNEL] [ 9.687451] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ initrd] [ 9.767001] WTpassword present: 9ea2ba7cc1e77936450a3a3e2b01ba8d.
[ initrd] [ 13.090236] dhcp: 324 bytes from 192.168.1.4.
[ initrd] [ 13.090518] 00000000:000001300000000000110000c0a80104c0a80170004300440130000002010600 ...0..............p.C.D.0......
[ initrd] [ 13.090714] 00000020:67458b6b0000000000000000c0a80170c0a8010400000000b827eb80526c0000 gE.k...........p.........'..Rl..
[ initrd] [ 13.090897] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.091079] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.091256] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.091434] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.091612] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 13.091788] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ KERNEL] [ 13.716035] random: nonblocking pool is initialized
[ initrd] [ 14.580234] dhcp: 324 bytes from 192.168.1.4.
[ initrd] [ 14.580479] 00000000:000001300000000000110000c0a80104c0a80170004300440130000002010600 ...0..............p.C.D.0......
[ initrd] [ 14.580668] 00000020:67458b6b0000000000000000c0a80170c0a8010400000000b827eb80526c0000 gE.k...........p.........'..Rl..
[ initrd] [ 14.580849] 00000040:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.581029] 00000060:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.581210] 00000080:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.581386] 000000a0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.581596] 000000c0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.581774] 000000e0:0000000000000000000000000000000000000000000000000000000000000000 ................................
[ initrd] [ 14.610134] dhcp: server address 192.168.1.4.
[ initrd] [ 14.610305] dhcp: 192.168.1.112/255.255.255.0.
[ initrd] [ 14.610467] dhcp: default gateway 192.168.1.1.
[ initrd] [ 14.610643] dhcp: DNS 192.168.1.40.
[ initrd] [ 14.610793] dhcp: DNS 192.168.1.41.
[ initrd] [ 14.610947] dhcp: domain ff-mistelbach.at.
[ initrd] [ 14.611101] dhcp: TFTP from siaddr 192.168.1.4.
[ initrd] [ 14.611253] dhcp: TFTP 192.168.1.4.
[ initrd] [ 14.611405] No boot file from DHCP.
[ initrd] [ 14.611556] TFTP binary "", configs prefix "", using "/" slash.
[ initrd] [ 14.614716] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[ pfac] [ 14.614863] Run /sbin/httpd.
[ pfac] [ 14.615264] Ok, PID 579.
[ httpd] [ 14.627074] HTTP Server, WTware v.5.4.68/RPi
[ initrd] [ 14.753937] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[ initrd] [ 14.754144] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[ initrd] [ 14.754263] USB: 05e3:0610 Genesys Logic, Inc. 4-port hub.
[ initrd] [ 14.754380] USB: 05e0:1701 Symbol Technologies Bar Code Scanner (CDC).
[ initrd] [ 14.754492] USB: 413c:2107 Dell Computer Corp..
[ initrd] [ 14.754596] USB: 0461:4e22 Primax Electronics, Ltd.
[ initrd] [ 14.754695] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[ initrd] [ 14.757817] Common local disk config:
| bpp=32
| display=1920x1200
| server=192.168.1.66
| serial=COM4(usb)
| sound=on
| sound_level=50
| sound_rate=48000
| sound_buffer=250
| timezone=W. Europe Standard Time
| domain=FFMistelbach
| ask_password=onpin
| keyboard=de
| language=de,default
| graphic=abcdefg
| microphone_level=0
| clipboard=on
| clienthostname=ffatem1
| turnoffmenu=always
| autoshutdown=30
| animation_speed=3
| vnc=on
| vnc_password=FFmb123
| doubleclick=200
| chrome_language=en
| chrome_url=http://www.ff-mistelbach.at
| bpp=32
| display=1920x1200
| server=192.168.1.66
| serial=COM4(usb)
| sound=on
| sound_level=50
| sound_rate=48000
| sound_buffer=250
| domain=FFMistelbach
| ask_password=onpin
| keyboard=de
| language=de,default
| graphic=abcdefg
| microphone_level=0
| clipboard=on
| turnoffmenu=always
| autoshutdown=30
| animation_speed=3
| vnc=on
| doubleclick=200
| chrome_language=en
[ initrd] [ 14.784364] Hostname: "ffatem1".
[ httpd] [ 14.980386] Reread settings.
[ httpd] [ 14.980621] Everyone can control terminal by HTTP.
[ gm] [ 14.981239] WTware session manager v.5.4.68/RPi.
[ gm] [ 15.040224] EV_REL flag found. Add mouse event1: PixArt USB Optical Mouse.
[ gm] [ 15.040384] Add keyboard event0: DELL Dell USB Entry Keyboard.
[ gm] [ 15.040593] Display mode: 1360x768, 32 bit, 0 Hz, modeline "", DDC enabled, connector 0.
[ gm] [ 15.063154] Framebuffer device found.
[ gm] [ 15.063304] LINELENBYTES 5440
[ gm] [ 15.063417] VLEN 4177920
[ gm] [ 15.087158] Use /lib/ui32.so.
[ gm] [ 15.114431] Run serial daemon for ttyACM0.
[ pfac] [ 15.114670] Run /sbin/rdpdr[serial] 4.
[ gm] [ 15.114755] Run '/sbin/rdpdr[serial] 4', log '', env '', pid ''.
[ gm] [ 15.114887] Run serial daemon for ttyUSB0.
[ pfac] [ 15.115141] Ok, PID 580.
[ gm] [ 15.115267] Run '/sbin/rdpdr[serial] 0', log '', env '', pid ''.
[ pfac] [ 15.115435] Run /sbin/rdpdr[serial] 0.
[ pfac] [ 15.115603] Ok, PID 581.
[rdpdr-serial 0] [ 15.119952] RDP Serial Port Redirector, WTware v.5.4.68/RPi, device ttyUSB0.
[rdpdr-serial 4] [ 15.120929] RDP Serial Port Redirector, WTware v.5.4.68/RPi, device ttyACM0.
[ gm] [ 15.124220] Unpack /bootmedia/packages/pi2-alsa.
[ gm] [ 15.253856] modprobe snd-bcm2835.
[ gm] [ 15.276712] modprobe snd-usb-audio.
[ KERNEL] [ 15.310630] usbcore: registered new interface driver snd-usb-audio
[ gm] [ 30.320249] [SOUND ERROR] ==================================================
[ gm] [ 30.320437] [SOUND ERROR] Uncomment "dtparam=audio=on" line in config.txt
[ gm] [ 30.320554] [SOUND ERROR] on SD card to pass sound to HDMI.
[ gm] [ 30.320664] [SOUND ERROR] ==================================================
[ gm] [ 30.320773] hardware.cpp ( 1119): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 30.320881] globalConfig.cpp ( 1779): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 30.320987] ERROR: Sound card not found. Disable sound.
[ gm] [ 30.321091] Load usb <-> serial bridges drivers.
[ gm] [ 30.323922] modprobe usbserial.
[ gm] [ 30.337730] modprobe pl2303.
[ KERNEL] [ 30.345284] usbcore: registered new interface driver usbserial
[ KERNEL] [ 30.345426] usbcore: registered new interface driver usbserial_generic
[ KERNEL] [ 30.345543] usbserial: USB Serial support registered for generic
[ KERNEL] [ 30.358898] usbcore: registered new interface driver pl2303
[ KERNEL] [ 30.359065] usbserial: USB Serial support registered for pl2303
[ gm] [ 30.351218] modprobe ftdi_sio.
[ gm] [ 30.368418] modprobe cp210x.
[ KERNEL] [ 30.375177] usbcore: registered new interface driver ftdi_sio
[ KERNEL] [ 30.375475] usbserial: USB Serial support registered for FTDI USB Serial Device
[ KERNEL] [ 30.388582] usbcore: registered new interface driver cp210x
[ KERNEL] [ 30.388727] usbserial: USB Serial support registered for cp210x
[ gm] [ 30.383961] modprobe ch341.
[ gm] [ 30.395653] modprobe metro-usb.
[ KERNEL] [ 30.403337] usbcore: registered new interface driver ch341
[ KERNEL] [ 30.403499] usbserial: USB Serial support registered for ch341-uart
[ gm] [ 30.408358] modprobe symbolserial.
[ KERNEL] [ 30.416205] usbcore: registered new interface driver metro_usb
[ KERNEL] [ 30.416357] usbserial: USB Serial support registered for Metrologic USB to Serial
[ KERNEL] [ 30.428356] usbcore: registered new interface driver symbolserial
[ KERNEL] [ 30.428628] usbserial: USB Serial support registered for symbol
[ gm] [ 30.420830] modprobe opticon.
[ gm] [ 30.433064] modprobe cdc-acm.
[ KERNEL] [ 30.440850] usbcore: registered new interface driver opticon
[ KERNEL] [ 30.440994] usbserial: USB Serial support registered for opticon
[ KERNEL] [ 30.456041] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ KERNEL] [ 30.458718] usbcore: registered new interface driver cdc_acm
[ KERNEL] [ 30.458739] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ gm] [ 30.461781] Run '/sbin/resolver 0x1229118 dns [192.168.1.66]', log '', env '', pid ''.
[ pfac] [ 30.462003] Run /sbin/resolver 0x1229118 dns [192.168.1.66].
[ pfac] [ 30.462325] Ok, PID 657.
[ gm] [ 30.462547] Everyone can control terminal by VNC.
[ gm] [ 30.462706] VNC listener at port 5900.
[ pfac] [ 30.469312] Process pid 657 terminated, status 00000000.
[ gm] [ 30.471383] 192.168.1.66 => 192.168.1.66.
[ gm] [ 30.471566] Incorrect parameter value: ask_password = onpin
[ gm] [ 30.471695] Free ram before fork terminal client /sbin/rdpclient (session 1): 922064 Kb.
[ pfac] [ 30.471822] Run /sbin/rdpclient 1.
[ gm] [ 30.471896] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[ pfac] [ 30.472686] Ok, PID 658.
[ rdpclient 658] [ 30.482835] RDP Terminal Client, WTware v.5.4.68/RPi, pipe 1, pid 658.
[ rdpclient 658] [ 30.484760] Use /lib/ui32.so.
[ gm] [ 30.486075] COM4 => ttyACM0, single device.
[ rdpclient 658] [ 30.486955] Add serial redirection, COM4 in the session = hardware ttyACM0.
[ rdpclient 658] [ 30.487188] Make RDP session with 192.168.1.66, port 3389.
[ rdpclient 658] [ 30.487356] No username.
[rdpdr-serial 4] [ 30.487494] New client connection, id 1.
[ rdpclient 658] [ 30.487572] No password.
[ rdpclient 658] [ 30.487698] No PIN.
[ rdpclient 658] [ 30.487915] Domain: "FFMistelbach".
[ rdpclient 658] [ 30.488092] No shell.
[ rdpclient 658] [ 30.488236] No directory.
[ rdpclient 658] [ 30.488378] Window: 1360x768@24.
[ rdpclient 658] [ 30.488509] PFlags 0x00000180.
[ rdpclient 658] [ 30.488632] Keyboard 00000407:00000000.
[ rdpclient 658] [ 30.488759] My hostname "ffatem1".
[ rdpclient 658] [ 30.488894] TCP: connecting to 192.168.1.66:3389.
[ rdpclient 658] [ 30.489047] TCP: connection with 192.168.1.66:3389 established.
[ rdpclient 658] [ 30.489196] Turn keepalive on.
[ rdpclient 658] [ 30.490529] Free ram after buffers allocation: 921732 KB.
[ rdpclient 658] [ 30.499245] Server supports GFX Pipeline.
[ rdpclient 658] [ 30.502432] Process RDP server certificate.
[ rdpclient 658] [ 30.502603] RDP4 encryption.
[ rdpclient 658] [ 30.508481] Timezone '(UTC+01:00) Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna'.
[ rdpclient 658] [ 30.508649] Enable font smoothing and Desktop Composition.
[ rdpclient 658] [ 30.710295] GFX codec.
[ rdpclient 658] [ 31.384443] Run 4 tile threads.
[ rdpclient 658] [ 39.940951] LOGON_EX_LOGONERRORS 0xfffffffe 0x00000003.
[ rdpclient 658] [ 42.437079] SessionId 0x00000003: FFMISTELBACH\markus.galler.
[ httpd] [ 232.300220] read() failed, errno 11.
Home WTware diskless client.
markus
Re: serial =com4(usb) BarCodeScanner from Pi2 to Win7 Pro
Post by markus »
any news regarding my issue. I tried already a couple of possiblities but nothing helps.
No problems in log. WTware found and redirected scanner. Look at Windows side.
Connect this scanner to Windows machine and redirect with mstsc.exe. Will it work? What exactly do you do to see the scanner on Windows?
markus
Post by markus »
hi,
thx for response.
before the issue occured, the redirection created in the device-manager the com4 device.
that is missing, so the software can not find it.
More or less thats the reason.
maybe do you know a solution?
the scanner connect to the system direct works fine.
M.
Connect this scanner to Windows machine and redirect with mstsc.exe. Not direct. To another Windows machine. Will it work? What exactly do you do to see the scanner on Windows?
PS: com device does NOT appear in Device Manager if serial port is redirected over RDP. Run "change port" from windows command line cmd.exe to see if port is redirected.
markus
Post by markus »
HI,
update to the issue regarding usb -> com4 port forwarding.
First thx for help and take notice from my issue.
For explaination an USB wireless barcode scanner is used.
The software, which runs on the Windows 7 system (old visual environment), which is used in the voluntary LowerAustria Fire Brigade, this is used to collect the used equipment and resources.
Since I am active in the IT, the system virutalized (Vmware) installed.
This greatly facilitates the continuous patching of the OS, as well as the installation of the running software updates and master data maintenance, which are made available via various IP protocols.
The Raspberry is therefore only used as a USB redirector (scanner) as a classic terminal.
Yesterday evening, after an assignment, I opened the radio scanner and connected the accu and connected again.
Since then the scanner can be reused.
Funk BarCode scanner, by means of disconnect / connect from the internal accu works again flawlessly.
Thx again,
Markus
