Hi Support guys,
I want to test WTWare & raspberry with wifi so i wanted to enter my WPA password.
But my password has more than 31 characters and WPA password field is limited to 31 characters only.
Normally a WPA password should contain up to 63 characters right ?
Is it possible to add more than 31 characters in a way or another ?
Thanks for your help!
Wifi WPA password with 31 characters only ?
Re: Wifi WPA password with 31 characters only ?
You can remember more than 31 characters password?
It's in fact easy to remember when you use a sentence as a password like for example :
"Ohmygod!MyTaylorisreallyveryrichindeed!"
Easy to remember and much longer than 31 characters
Try wtware 5.4.70. Up to 63 chars passwords should work.
I'd like other companies support to be as fast as you are to solve issues!
Thanks a lot for this quick resolution !
Hello again,
I've just started to test the new version and i can already see that wifi password is written in initrd.wtc file but is not encrypted...
I mean, all the others passwords (setup, vnc) are encrypted so i'm wondering : is it possible to crypt the wifi password ?
Thanks for your work !
Please, try this:
http://pxe.ru/files/testing/201702090334.zip
Note it's the security mirage, not real security.
Hi Support guys,
Downloaded and tested : works great !
I feel better with my encrypted wifi password.
Thanks for your help and your speed.
