Keyboard ja layout
Keyboard ja layout
Is 'ja' keyboard layout supported?
If not, could you please add it?
Re: Keyboard ja layout
Yes, supported.
http://wtware.ru/docs46/config.html#keyboard
Unfortunately, several key codes are not assigned properly in my environment.
i.e. Although '\'(backslash) of en layout should be ']' in ja layout, it still assigned as '\'.
http://ascii-table.com/keyboard.php/194
I added 'keyboard = ja' line to *.wtc file and confirmed its setting appeared on
wtware syslog below.
| initrd: Download file "pro\4.6.8/configs/00.1E.C9.7C.B8.9E.wtc" from TFTP server "172.16.0.150".
| +--- FILE "/tmp/cfg" -----------------------
| | keyboard = ja
Could you please tell me how to solve this problem?
| | keyboard = ja
Sorry, correct link is http://wtware.com/docs46/config.html#keyboard
This is only language mode in "windows login" screen.
You talking about key with Base code U+005C?
Which char this key puts to Notepad while typing through mstsc.exe session?
Nice site. Looking on it, please tell me, what is wrong.a-lab wrote:Unfortunately, several key codes are not assigned properly in my environment.
Thank you for reply.
Yes, and some other characters. ('[', ']', ':', etc.)
'\' -> puts '\' thurough mstsc.exe session (key does not respond thru wtware session)
']' -> puts ']' thru tsc ('\' thru wtware)
':' -> puts ':' thru tsc (''' thru wtware)
These results indicate wtware sends 101 keyboard layout in 'ja' config
instead of 106 layout. I confirmed incorrect key events sent
using freeware "SharpKeys".
Please, install and boot this:
http://pxe.ru/files/testing/201011051150.zip
This build will post scancodes we receive from hardware. You'll see new lines in wtware event viewer every time you press or release any key. Please, put log samples here for every incorrect key and write, which char should appear in notepad. Chars appear incorrectly when you type in ENglish or in JApanese?
Thank you for providing debug program.
In English, which ja imput-method is turned off (= single-byte mode).
Okay. Every key described below is laid out as:
key 'Size' (shown on left-top corner in http://ascii-table.com/keyboard.php/194)
expected: ja imput-method toggled and no char should appear
incorrect result: '`' (backquote) appears on notepad
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x29 (41), pressed
key 'Shift-2' (U+0022, incorrect char shown in http://ascii-table.com/keyboard.php/194)
expected: '"' (quotation mark) should appear in notepad
incorrect result: '@' appears
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x36 (54), pressed
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x03 (3), pressed
key 'Shift-6'
expected: '&'
incorrect result: '^'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x07 (7), pressed
key 'Shift-7'
expected: ''' (apos)
incorrect result: '&'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x08 (8), pressed
key 'Shift-8'
expected: '('
incorrect result: '*'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x36 (54), released
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x09 (9), released
key 'Shift-9'
expected: ')'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x0a (10), pressed
key 'Shift-0'
expected: no char should appear
incorrect result: ')'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x0b (11), pressed
key 'Shift--' (minus sign)
expected: '='
incorrect result: '_'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x0c (12), pressed
key 'Shift-^' (left of '-' key)
expected: '~'
incorrect result: '+'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x0d (13), pressed
key 'Shift-\' (U+00A5, right of 'BS' key)
expected: '|' (vertical bar)
incorrect result: no char appears
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x7c (124), pressed
init: video/video_keyboard.c ( 224), keyProcessInDS: -- ERROR -- Unknown character, scancode 0x7c
key '\' (U+00A5, right of 'BS' key)
expected: '\'
incorrect result: no char appears on notepad
key '@' (U+0040)
incorrect result: '['
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x1a (26), pressed
key '[' (U+005B)
incorrect result: ']'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x1b (27), pressed
key ':' (U+003A)
incorrect result: ''
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x28 (40), pressed
key ']' (U+005D)
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x2b (43), pressed
key '\' (U+005C, left of right-shift key)
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x59 (89), pressed
key 'Shift-;'
expected: '+'
incorrect result: ':'
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x27 (39), pressed
key 'Shift-:'
expected: '*'
incorrect result: '"'
key 'Shift-@'
expected: '`'
incorrect result: '{'
key 'Shift-['
expected: '{'
incorrect result: '}'
key 'Shift-]'
expected: '}'
incorrect result: '|'
key 'Shift-\' (U+005C, left of right-shift key)
expected: '_'
key 'Noconv' (shown on bottom middle-left in http://ascii-table.com/keyboard.php/194)
expected: ja imput-method responds 'noconv' and no char should appear
incorrect result: no response
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x5e (94), pressed
init: video/video_keyboard.c ( 224), keyProcessInDS: -- ERROR -- Unknown character, scancode 0x5e
key 'Convert' (shown on bottom middle-right in http://ascii-table.com/keyboard.php/194)
expected: ja imput-method responds 'convert' and no char should appear
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x5c (92), pressed
init: video/video_keyboard.c ( 224), keyProcessInDS: -- ERROR -- Unknown character, scancode 0x5c
key 'Kana' (shown on bottom middle-left in http://ascii-table.com/keyboard.php/194
expected: ja imput-method toggles and no char should appear
init: video/video_keyboard.c ( 73), keyProcessInDS: scan 0x5d (93), pressed
init: video/video_keyboard.c ( 224), keyProcessInDS: -- ERROR -- Unknown character, scancode 0x5d
key 'Shift-6'
expected: '&'
key 'Shift-7'
key 'Shift-8'
expected: '('
key 'Shift-9'
expected: ')'
key 'Shift-0'
expected: '='
expected: '~'
expected: '\'
key '@' (U+0040)
key '[' (U+005B)
key ':' (U+003A)
key ']' (U+005D)
key 'Shift-;'
expected: '+'
key 'Shift-:'
expected: '*'
key 'Shift-@'
expected: '`'
key 'Shift-['
expected: '{'
key 'Shift-]'
expected: '}'
expected: '_'
It seems I do not understand, what is "layout".
I have keyboard with 'shift' and with '6'. I have mstsc.exe and original english windows7. I add Japan language, keyboard Japanese and Microsoft IME. In "JA" language, with both keyboards I got ^ when I press Shift-6.
In "RU" language, I got :
In "EN", I got ^, same as in "JA"
What should I do to get & when I press 'Shift-6'?
- Untitled.png (16.43 KiB) Viewed 54724 times
Probably you need to change keyboard driver at the Device Manager to emulate JA layout. Please see attached image.
Successful with local windows.
Unsuccessful with mstsc.exe.
Now I have two windows (winXP sp3 and win7, both english). Both have 106-key keyboard driver installed and three languages (EN, RU, JP). When I select JP, I got & for Shift-6 in both OSes. Locally.
But when I connect with mstsc.exe from one windows to another, I got ^ for Shift-6 in EN and JP.
Where am I wrong?
Where am I wrong?
Please set the Input Language in the Text Service along with attached image.
Yes!
Thank you.
Now I need some days to do the same in WTware.
Thank you.
Good news: most of keys fixed. Here it is:
http://pxe.ru/files/testing/201011120723.zip
Specify keyboard=ja in config file. Please, try it.
To fix other keys, I need your assistance. Please contact my terminal server with mstsc.exe from win7 of winxp sp3 over Internet and press five times every key from following list:
Please, send me email at aka@pxe.ru when you have time to do this. So that I could turn on my server, start sniffer and send you server IP.a-lab wrote: key 'Shift-\' (U+00A5, right of 'BS' key)
expected: '\'
expected: '_'
Great! I confirmed lots of problems except specified above have been fixed.
However, one key 'Size' still does not respond. Please examine it also through sniffer later.
I will contact you soon.
