please... i need some help
package integrity error
Post by package integrity error »
I've downloaded wtware in your last version (2004-12-16) and did everything like showed in tutorial. The client starts the boot from DHCP, receive the image but when it will start the WTware an error is showed, something like this: "package integrity error"...
I already have downloaded again the file, oldest files, etc, but the error still happing.
Someone knows what I would do? Help-me guyz...
Regards []'s
1. Do you use a 486 without PCI bus?
2. Please, send the four lines printed before the "package integrity error" line.
Guest
Post by Guest »
Yes, I'm using a 486 without PCI bus, but I already tested to boot with a Pentium 3 450Mhz with PCI bus but i've got the same error...
The complete message is:
[...].......................................................done
mknbi-1.2.7/first32.c (GPL)
Top of ramdisk is 0X01000000
Ramdisk at 0X00F7E000, size 0X00082000
Uncompressing Linux... Ok, booting the kernel.
WTware shell v.1.0.5
               An error ocurred while terminal boot
ERROR: Package Integrity error. Please restore from distribuition.
Unable to continue until the error is corrected.
WTware project documentation is avaiable at http://www.wtware.com/doc.html
Technical support, forum: http://forum.wtware.com
                          email: support@wtware.com
                          ICQ: 89596217
Like I said, I already tested P3 450Mhz with PCI bus, and so many other configurations and other WTware packages, including one *RUSSIAN* package, little older than the actually.
Thankz the help, cya.
AlaorCarvalho
Post by AlaorCarvalho »
I've registered now, I'm the guest that have posted this messages, cya []'s.
The bug, appeared with 486 without PCI bus, has already been fixed, but only in russian beta 2005-04-14 build. English version will be avaible just when we'll make stable release. It may take up to three months.
Do all the packages you test on P3 give the same error?
AlaorCarvalho
I don't renember, but I think that only the english version I've tested in other machines, I'll test the russian beta and will post my experience here later... (lol, I'm brazilian and is hard to speak in english, in russian so... lol)
karl
Post by karl »
I download the package to do a testing. I follow the faststart step by step.
up to uncompressing. I got CRC error, then system halted. any idea?
thank you
karl
Post by karl »
after download again, no more crc error.
thankyou
