RDP Idle-Disconnection doesn't work
Posted: Wed Aug 19, 2020 10:51 am
by wendla
I'm using WTware on a Raspberry PI to connect a Microsoft RDP-Farm.
The Farm is configured to disconnect the Sessions after an Idle-Time of 3 Hours.
This is working correctly an a normal mstsc-Client, but not on the WTware-Raspberry PI.
Is there any configuration for this issue?
Thank you
Re: RDP Idle-Disconnection doesn't work
Posted: Wed Aug 19, 2020 1:37 pm
Try to disconnect mouse and repeat test.
Posted: Wed Aug 19, 2020 2:16 pm
by wendla
i already tried this. Same effect!
Posted: Thu Aug 20, 2020 3:28 pm
Does the same user on the same server disconnect in mstsc and doesn't disconnect in wtware?
Show me the log, please:
https://wtware.ru/logs.html
3+ hours, boot without mouse.
Perhaps, it's easily to reproduce on separate server with timeout for several minutes instead of 3 hours.
Posted: Mon Sep 07, 2020 4:16 pm
by wendla
the Same user disconnects with mstsc correctly.
I attached the log, after i booted without a mouse and a runtime 3+ hours.
Posted: Thu Sep 17, 2020 12:41 pm
by Frozenfire
We have the same problem with a 2 hour lockout policy.
Ran Rasbian with xfreerdp and that timeout just fine. Just WTware that is causing the problem not timing out.
Posted: Wed Sep 23, 2020 5:25 pm
by wendla
Has anyone an Idea with this Problem?
Posted: Thu Oct 08, 2020 3:39 pm
by wendla
The Solution was, to set the Montior Poweroff parameter
Posted: Thu Oct 08, 2020 6:25 pm
RDP Idle-Disconnection depends on Monitor Poweroff?? Please, write more details.
