OpenVPN Auto Login?
Posted: Fri May 03, 2019 2:33 am
by Bootalito
Is there a way to configure OpenVPN with the credentials for automatic login so the user does not have to enter them? Such as use the configuration file?
Re: OpenVPN Auto Login?
Posted: Fri May 03, 2019 12:59 pm
http://wtware.com/docs5/openvpn.html
"Rename tested configuration file to openvpn.cfg and place it to configs directory on boot disk..."
Posted: Sat May 04, 2019 4:02 am
by Bootalito
I think I figured it out but something is still wrong. In the OpenVPN.cfg file I added the following line:
auth-user-pass pass.txt
auth-user-pass was already there, I just added " pass.txt". I added a file called pass.txt with the username and password on two different lines, but I'm getting a WTWare error:
ERROR: INTERNAL ERROR
WTWare 5.8.50/RPi
File: initrdConfig.cpp
Line 439
Posted: Sat May 04, 2019 11:49 am
initrdConfig.cpp Line 439 is "openvpn did not understand your config and did not start".
More details in log: https://wtware.com/logs.html
Also try this line:
auth-user-pass /bootmedia/configs/pass.txt
Posted: Fri Jan 17, 2020 2:31 am
by Bootalito
It's been a while, but I just wanted to respond to help other people out in the future that aka's solution was the final solution
with pass.txt being a two line text file with the OpenVPN auth user name on the first line and the password on the second line.
i.e.
OpenVPNUserName
SomeComplexPassword
I can confirm that WTWare 5.8.50/Rpi is working very well providing remote access for our office manager connecting to a pfsense router (v2.4.4-RELEASE-p3) via OpenVPN configured in the most secure way humanly possible (4096bit DH paramter, AES-256-GCM, only available in the most recent version of OpenVPN, using mode: "SSL/TLS + User Auth" with TLS key mode "TLS Encryption and Authentication". The raspberry pi is mounted to the back of a monitor via a VESA mount.
If the devs would like, I could provide a full write up with screen shots and pictures that they could use to update the documentation (especially the OpenVPN documentation page, which is really lacking) on how to provide a fully secure remote access station for an employee. Please let me know if this is something WTWare would find useful and I'll make some time to provide
Posted: Thu Jan 23, 2020 6:25 am
It would be very great, we'll appreciate such work. Thank you.
