Dual channel memory performance
kevin.murilo
Post by kevin.murilo »
I have my terminals set to boot via network and to keep the config in memory, so that I can ditch the HDDs. I'm only running a single 2GB DDR3 stick on each machine, since WTware requires very little space. My question is, if I put a second stick os RAM on each system, would it be more responsive? Or is the RAM only accessed when fetching the config file from the TFTP?
Re: Dual channel memory performance
kevin.murilo wrote:
Thu Aug 06, 2020 5:21 pm
It will be more responsive if you run local Chromium. For RDP sessions 1GB is more than enough.
kevin.murilo
akatik wrote:
Thu Aug 06, 2020 9:46 pm
I know the space is more than enough, but what about the speed? Would the system be more responsive with 2 sticks of RAM, therefore enabling the use of Dual Channel Memory? Or would I feel no difference?
