Wi-Fi boot option ignored in WTware 6.2.54 ISO
laesyar
Post by laesyar »
When creating a bootable ISO using WTware Center in version 6.2.54, we selected the option "Work over Wi-Fi. Wi-Fi configuration is performed from terminal" in the wizard.
In previous versions, this option correctly configured the terminal to boot with Wi-Fi enabled. However, in version 6.2.54, the terminal incorrectly defaults to Ethernet as the selected network interface upon boot.
It appears that the generated ISO is missing the line netmedia=wifi in the initrd.wtc configuration file, which may be causing the terminal to default to Ethernet.
Re: Wi-Fi boot option ignored in WTware 6.2.54 ISO
Thank you, it's our error. Will be fixed in the next version.
