Clone RDP onto 2 monitors RPI4
cobash
Post by cobash »
Hello!
I am working with a RPI4 and I am trying to get a RDP session to duplicate on to 2 monitors. Currently I can only get it to span across. Is there a way to do this?
Thanks!
Re: Clone RDP onto 2 monitors RPI4
Please try 6.2.42 wtware version.
In wtware terminal config file:
m2_display = clone
cobash
Post by cobash »
Thanks! Is the option in the GUI editor or do I have to change the version to "No Version".
On "Text" tab. I've just added this option, GUI editor doesn't know it yet.
cobash
Post by cobash »
Hello! I was wondering if this was added to the GUI yet.
Thanks!
Does it work from text config?
Goyo
Post by Goyo »
I have tried with 6.2.58/RPi64 and it is not working. I get black screen in HDMI2.
Regards
Goyo
Post by Goyo »
How can I solve this problem?
Regards
Goyo
Post by Goyo »
I have sent youthe logsby email.
Regars
Goyo
Restore the original config.txt file to the SD card. If the wtware is installed on Windows, the original file for version 6.2.62 can be copied from:
"C:\Program Files (x86)\WTware\TFTPDROOT\6.2.62\pi2\localboot\config.txt"
config.txt
(1.65 KiB) Downloaded 476 times
