Disable TLS 1.0 & 1.1?
nholderafa
Post by nholderafa »
Can you disable TLS 1.0 & 1.1 on WTware for Raspberry Pi?
Re: Disable TLS 1.0 & 1.1?
We have no such setting. You can disable TLS 1.0 & 1.1 on your server so WTware should connect with TLS 1.2.
Here is the guide: viewtopic.php?p=75811#p75811
nholderafa
Sorry I should have been more specific. I am talking about https on the web interface. Not connecting to a server.
We have no such setting now.
httpd= config file option controls web interface assess list and turns it off: http://wtware.com/docs5/config.html#httpd
I can add "httpd=tls 1.2" value to disable SSL and TLS below 1.2.
Will it work for you?
