WTware failing to boot from hard drive, sometimes grub screen
chris@tagsol.co.za
Post by chris@tagsol.co.za »
Installed WTware to hard drive on a mini PC, ask for restart.
Fail to boot from hard drive - need restart - fail again.
Sometimes a grub screen is presented, not sure how to troubleshoot grub errors, complaining need to load kernel.
No idea what to do.
Installed an Ubuntu flavour on the mini PC - working.
Please guide me to troubleshoot.
Re: WTware failing to boot from hard drive, sometimes grub screen
chris@tagsol.co.za wrote: Wed May 25, 2022 11:46 am Installed WTware to hard drive on a mini PC, ask for restart.
I need at this moment terminal log: http://wtware.com/docs5/logs.html
Last part when there's no network on terminal. Send it to support@wtware.com
Update: we need log AFTER INSTALLATION.
1. Install wtware again.
2. When wtware finishes installation and writes "reboot now", do not reboot. Instead, press ESC. It should run command prompt.
3. From command prompt run command "log" as written in logging manual.
chris@tagsol.co.za
E-mailed the requested log file.
