Template for writing SD Card
WtWareJunky
Post by WtWareJunky »
Since Network Boot is not too reliable, it would be great to have the possibility to save the parameters that are defined while running through the write on SD-Card Dialog. It would be much quicker if you could choose this saved setting on the first page of the dialog and than just click write on SD-Card.
Re: Template for writing SD Card
WtWareJunky wrote: Mon Jul 27, 2020 10:57 am Since Network Boot is not too reliable,
Just mark: on Raspberry is not too reliable. On x86, in safe network, it's reliable.
WtWareJunky wrote: Mon Jul 27, 2020 10:57 am ...if you could choose this saved setting on the first page of the dialog and than just click write on SD-Card.
"settings" is in configs/initrd.wtc on SD. There is no boot magic on Raspberry boot SD. It's just SD with files. You may copy all files and folders from Raspberry boot SD to new formatted SD in Windows Explorer.
