Hi@all,
is there a way to modify the look of the loginscreen or to add some text as information?
We would like to make it look more fancy
Greetings Supajo
Modification for Loginscreen
- wtware-login.jpg (34.05 KiB) Viewed 13814 times
Re: Modification for Loginscreen
Did you figure this out ? because I need to change the english "username" and "password" to french words
Is it OK?
ask_password = username:Nom d'utilisateur, password:Mot de passe, on
- Untitled.png (4.84 KiB) Viewed 13730 times
Thank you for being so quick on the reply, it is working perfecly !
