Network Boot does not work
glowmancz
Post by glowmancz »
Now I have WTWARE installed on my computer together with TFTP. But as a DHCP I use microtik, but I set the microtik DHCP option to 67 and 66 see below. Next I create a programmable SD card for RPI 3 B +, insert it into the RPI boot and then remove and disconnect and nothing happens on the screen black and nothing in the log. But if you set up boot from SD card both config and system and everything works. Please advise me what settings to make it work with a microtik. I'm new to WTware, so I'm sorry if I forgot something but I don't know anymore.
RPI: Model 3 B+
WTWare: Windows 10 Pro
DHCP: Mikrotik 4011
Version of WTWARE: 5.8.62
Thank you very much
boot option.PNG (5.8 KiB) Viewed 99742 times
Re: Network Boot does not work
For 3B+ do not make programmable SD. Try to boot without SD at all.
glowmancz
Post by glowmancz »
It also doesn't work. when I monitor a network with a wireshark, the RPI sends a request for data from DHCP, but it just doesn't work.
