USB network adapter for Raspberry Pi 3
chris
Post by chris »
I was looking for getting more video performance (e.g. Youtube, local video etc) out of the raspberry pi 3. I am connecting to windows 2012 servers as well as Windows 10 desktops and playing videos does not run smoothly. From the hardware side the Pi 3 should be powerful enough to run videos in HD resolution. Using it stand-alone with Raspbian all video applications work properly. So obviously the network is the bottleneck here.
I was wondering if it is (or will be) possible to hook up an external USB network interface. When benchmarking the internal 100Mbit card I get (on a basic raspbian) about 80Mbit out of it. Using one of the cheaply available USB3 network adapters (with standard realtec chipsets) I was measuring 350Mbit, what should be sufficient for smooth video playback.
Has someone successfully done this, or is it a plan for the future?
I really like the new Pi as they are extremely powerful, cheap and therefore are the perfect thin client platforms.
Chris
Re: USB network adapter for Raspberry Pi 3
Video on terminal is not a good idea. RDP uses lossy compression. 1080p over RDP will be worse then 720p local.
Test network load playing video on Windows 10. Will it be more than 80Mbit? Will it look smooth connecting with USB net card?
chris
Post by chris »
Video on terminal for casual browsing activities does not have to be 1080 for my needs. From Windows 10 to Windows Server (on a fat client) playback works with 1080 using 1Gbit ethernet without stuttering. The max. bandwidth of the fat client is 950Mbit, when connecting to the windows server.
I tried to use a USB 1G device on the RPI, but wtware does not seem to use it for outgoing connections. Is there anything to do/activate in the config to use other network interfaces instead of the build-in ones?
chris wrote:...but wtware does not seem to use it for outgoing connections. Is there anything to do/activate in the config to use other network interfaces instead of the build-in ones?
No.
Test it with something else (Windows with USB 2.0 port, not USB 3.0 or Raspbian). If it will work significantly faster then 100Mbit, we'll add it to wtware.
chris
Post by chris »
I hooked up the adapter to a core2duo notebook with USB2.0 running Debian 8. Speed measured with iperf3 to a test server (Debian 8 with LACP 2x1Gbit) was between 280 and 390Mbit, depending on the packet size and queue size. Connections from the linux laptop to the Windows 10 reaches 300Mbit in average. The RDP connect from the Linux Laptop to the Windows 10 machine plays videos pretty smoothly. There is some stuttering though. I guess this because of the xfreerdp client uses framebuffers and shows the same behavior on a 1Gbit (internal NIC) connection. On a MacBook Air, using the Microsoft RDP client, video playback works like a charme even on WiFi.
The WiFi connection runs at 300Mbit.
Connect adapter to pi with wtware (working with internal card, I only want to know adapter USB ID) and make me log: https://wtware.com/logs.html
chris
Post by chris »
No problem. The thing you probably are looking for is:
[0] USB ID: 0424:ec00, bus ID: 1-1.1, class: 0xff, subclass: 0x00, Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
The usb regarding log section:
[        KERNEL] [    3.452649] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.452661] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.453444] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.453561] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.772426] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.902668] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.902678] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.202426] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.333272] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8153
[        KERNEL] [    4.333284] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[        KERNEL] [    4.333291] usb 1-1.4: Product: USB 10/100/1000 LAN
[        KERNEL] [    4.333298] usb 1-1.4: Manufacturer: Realtek
[        KERNEL] [    4.333305] usb 1-1.4: SerialNumber: 000001000000
[        KERNEL] [    4.632428] usb 1-1.2: new full-speed USB device number 5 using dwc_otg
[        KERNEL] [    4.768202] usb 1-1.2: New USB device found, idVendor=062a, idProduct=4101
[        KERNEL] [    4.768212] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.768220] usb 1-1.2: Product: 2.4G Keyboard Mouse
[        KERNEL] [    4.768228] usb 1-1.2: Manufacturer: MOSART Semi.
[        KERNEL] [    4.773307] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:062A:4101.0001/input/input0
[        KERNEL] [    4.843524] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.851114] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:062A:4101.0002/input/input1
[        KERNEL] [    4.913228] hid-generic 0003:062A:4101.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-3f980000.usb-1.2/input1
[        initrd] [    5.026700] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
Please, try 5.6.20 version. And show me FULL log.
chris
Post by chris »
OK, downloaded latest version. When plugging the USB ethernet in, connection to the RPI won't work, so I started without the USB adapter and plugged it in afterwards:
WTware 5.6.20
WTware 5.6.20/RPi supervisor.
[        KERNEL] [    0.000000] Linux version 4.9.61 (aka@c12) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #4 SMP Fri Nov 17 04:28:27 +04 2017
[        KERNEL] [    0.000000] free_area_init_node: node 0, pgdat 80b22b40, node_mem_map ba3a1000
[        KERNEL] [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2708_fb.fbdepth=32 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  quiet wtboot=mmc
[        KERNEL] [    0.000000] Memory: 942184K/970752K available (5120K kernel code, 143K rwdata, 920K rodata, 4096K init, 365K bss, 20376K reserved, 8192K cma-reserved)
[          pfac] [    3.053875] Run /sbin/initrd.
[        KERNEL] [    0.000000]       .init : 0x80700000 - 0x80b00000   (4096 kB)
[        KERNEL] [    0.000000]       .data : 0x80b00000 - 0x80b23df8   ( 144 kB)
[        KERNEL] [    0.000000]        .bss : 0x80b25000 - 0x80b805a0   ( 366 kB)
[        KERNEL] [    0.000000] 	Build-time adjustment of leaf fanout to 32.
[        KERNEL] [    0.000222] console [tty0] enabled
[        KERNEL] [    0.000251] pid_max: default: 32768 minimum: 301
[        KERNEL] [    0.000382] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.000389] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[        KERNEL] [    0.001286] CPU: Testing write buffer coherency: ok
[        KERNEL] [    0.001619] CPU0: update cpu_capacity 1024
[        KERNEL] [    0.001626] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[        KERNEL] [    0.001650] Setting up static identity map for 0x100000 - 0x100034
[        KERNEL] [    0.003172] CPU1: update cpu_capacity 1024
[        KERNEL] [    0.003178] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[        KERNEL] [    0.003736] CPU2: update cpu_capacity 1024
[        KERNEL] [    0.003743] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[        KERNEL] [    0.004297] CPU3: update cpu_capacity 1024
[          pfac] [    3.055413] Ok, PID 603.
[        KERNEL] [    0.004304] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[        KERNEL] [    0.004380] Brought up 4 CPUs
[        KERNEL] [    0.004390] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[        KERNEL] [    0.004394] CPU: All CPU(s) started in HYP mode.
[        KERNEL] [    0.004397] CPU: Virtualization extensions available.
[        KERNEL] [    0.004936] devtmpfs: initialized
[        KERNEL] [    0.014564] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[        KERNEL] [    0.014864] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[        KERNEL] [    0.014881] futex hash table entries: 1024 (order: 4, 65536 bytes)
[        KERNEL] [    0.015374] pinctrl core: initialized pinctrl subsystem
[        KERNEL] [    0.015813] NET: Registered protocol family 16
[        KERNEL] [    0.017659] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[        KERNEL] [    0.027214] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[        KERNEL] [    0.091010] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
[        KERNEL] [    0.092743] usbcore: registered new interface driver usbfs
[        KERNEL] [    0.092823] usbcore: registered new interface driver hub
[        KERNEL] [    0.092914] usbcore: registered new device driver usb
[        KERNEL] [    0.100141] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-11-03 17:00
[        KERNEL] [    0.101931] clocksource: Switched to clocksource arch_sys_counter
[        KERNEL] [    0.113545] NET: Registered protocol family 2
[        KERNEL] [    0.114121] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[        KERNEL] [    0.114229] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[        KERNEL] [    0.114413] TCP: Hash tables configured (established 8192 bind 8192)
[        KERNEL] [    0.114498] UDP hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.114539] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[        KERNEL] [    0.114713] NET: Registered protocol family 1
[        KERNEL] [    2.215529] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[        KERNEL] [    2.250062] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[        KERNEL] [    2.250075] io scheduler noop registered
[        KERNEL] [    2.250080] io scheduler deadline registered (default)
[        KERNEL] [    2.259569] BCM2708FB: allocated DMA memory fad10000
[        KERNEL] [    2.259606] BCM2708FB: allocated DMA channel 0 @ bb80f000
[        KERNEL] [    2.282643] Console: switching to colour frame buffer device 128x48
[        KERNEL] [    2.297501] bcm2835-rng 3f104000.rng: hwrng registered
[        KERNEL] [    2.297679] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[        KERNEL] [    2.298488] vc-sm: Videocore shared memory driver
[        KERNEL] [    2.305342] zram: Added device: zram0
[        KERNEL] [    2.305387] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[        KERNEL] [    2.533583] Core Release: 2.80a
[        KERNEL] [    2.533592] Setting default values for core params
[        KERNEL] [    2.533617] Finished setting default values for core params
[        KERNEL] [    2.733986] Using Buffer DMA mode
[        KERNEL] [    2.733994] Periodic Transfer Interrupt Enhancement - disabled
[        KERNEL] [    2.733997] Multiprocessor Interrupt Enhancement - disabled
[        KERNEL] [    2.734004] OTG VER PARAM: 0, OTG VER FLAG: 0
[        KERNEL] [    2.734033] Dedicated Tx FIFOs mode
[        KERNEL] [    2.734534] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
[        KERNEL] [    2.734558] FIQ FSM acceleration enabled for :
[        KERNEL] [    2.734558] Non-periodic Split Transactions
[        KERNEL] [    2.734558] Periodic Split Transactions
[        KERNEL] [    2.734558] High-Speed Isochronous Endpoints
[        KERNEL] [    2.734558] Interrupt/Control Split Transaction hack enabled
[        KERNEL] [    2.734564] dwc_otg: Microframe scheduler enabled
[        KERNEL] [    2.734609] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x80397c10
[        KERNEL] [    2.734618] WARN::hcd_init_fiq:460: FIQ ASM at 0x80397f74 length 36
[        KERNEL] [    2.734627] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb925000
[        KERNEL] [    2.734683] dwc_otg 3f980000.usb: DWC OTG Controller
[        KERNEL] [    2.734715] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[        KERNEL] [    2.734744] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[        KERNEL] [    2.734788] Init: Port Power? op_state=1
[        KERNEL] [    2.734792] Init: Power Port (0)
[        KERNEL] [    2.734972] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[        KERNEL] [    2.734981] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[        KERNEL] [    2.734989] usb usb1: Product: DWC OTG Controller
[        KERNEL] [    2.734996] usb usb1: Manufacturer: Linux 4.9.61 dwc_otg_hcd
[        KERNEL] [    2.735002] usb usb1: SerialNumber: 3f980000.usb
[        KERNEL] [    2.735725] hub 1-0:1.0: USB hub found
[        KERNEL] [    2.735759] hub 1-0:1.0: 1 port detected
[        KERNEL] [    2.736423] dwc_otg: FIQ enabled
[        KERNEL] [    2.736427] dwc_otg: NAK holdoff enabled
[        KERNEL] [    2.736431] dwc_otg: FIQ split-transaction FSM enabled
[        KERNEL] [    2.736444] Module dwc_common_port init
[        KERNEL] [    2.736785] usbcore: registered new interface driver usbtouchscreen
[        KERNEL] [    2.738098] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[        KERNEL] [    2.738573] bcm2835-cpufreq: min=600000 max=1200000
[        KERNEL] [    2.739546] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[        KERNEL] [    2.742315] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[        KERNEL] [    2.745406] ledtrig-cpu: registered to indicate activity on CPUs
[        KERNEL] [    2.745585] hidraw: raw HID events driver (C) Jiri Kosina
[        KERNEL] [    2.747170] usbcore: registered new interface driver usbhid
[        KERNEL] [    2.747181] usbhid: USB HID core driver
[        KERNEL] [    2.750736] vchiq: vchiq_init_state: slot_zero = 0xbad80000, is_master = 0
[        KERNEL] [    2.762229] [vc_sm_connected_init]: start
[        KERNEL] [    2.771157] [vc_sm_connected_init]: end - returning 0
[        KERNEL] [    2.771537] NET: Registered protocol family 17
[        KERNEL] [    2.771796] Registering SWP/SWPB emulation handler
[        KERNEL] [    2.772767] registered taskstats version 1
[        KERNEL] [    2.779941] sdhost: log_buf @ bad07000 (fad07000)
[        KERNEL] [    2.851966] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[        KERNEL] [    2.854261] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[        KERNEL] [    2.854269] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[        KERNEL] [    2.932062] of_cfs_init
[        KERNEL] [    2.932145] of_cfs_init: OK
[        KERNEL] [    2.952734] Indeed it is in host mode hprt0 = 00021501
[        KERNEL] [    2.953604] Freeing unused kernel memory: 4096K
[        KERNEL] [    3.036840] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[        KERNEL] [    3.038531] mmc0: host does not support reading read-only switch, assuming write-enable
[        KERNEL] [    3.038689] mmc0: new SD card at address 8fe4
[        KERNEL] [    3.039415] mmcblk0: mmc0:8fe4 SU02G 1.84 GiB
[        KERNEL] [    3.040870] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.042464] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[        KERNEL] [    3.044065]  mmcblk0: p1
[        KERNEL] [    3.046064] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[        KERNEL] [    3.048023] random: fast init done
[        initrd] [    3.060734] WTware shell 5.6.20/RPi
[        initrd] [    3.086185] HDD/MMC/SD boot.
[        KERNEL] [    3.160291] mmc1: new high speed SDIO card at address 0001
[        KERNEL] [    3.162017] usb 1-1: new high-speed USB device number 2 using dwc_otg
[        KERNEL] [    3.162229] Indeed it is in host mode hprt0 = 00001101
[       hotplug] [    3.206096] Block device 254:0. No action.
[       hotplug] [    3.345798] Block device 179:0. No action.
[       hotplug] [    3.345928] Block device 179:1. No action.
[        KERNEL] [    3.392209] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[        KERNEL] [    3.392221] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    3.392982] hub 1-1:1.0: USB hub found
[        KERNEL] [    3.393097] hub 1-1:1.0: 5 ports detected
[        KERNEL] [    3.711962] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[        KERNEL] [    3.842201] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[        KERNEL] [    3.842211] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[        KERNEL] [    4.421965] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[        KERNEL] [    4.558931] usb 1-1.2: New USB device found, idVendor=062a, idProduct=4101
[        KERNEL] [    4.558942] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[        KERNEL] [    4.558949] usb 1-1.2: Product: 2.4G Keyboard Mouse
[        KERNEL] [    4.558956] usb 1-1.2: Manufacturer: MOSART Semi.
[        KERNEL] [    4.564141] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:062A:4101.0001/input/input0
[        KERNEL] [    4.634831] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-3f980000.usb-1.2/input0
[        KERNEL] [    4.644603] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:062A:4101.0002/input/input1
[        KERNEL] [    4.722745] hid-generic 0003:062A:4101.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-3f980000.usb-1.2/input1
[        initrd] [    4.996845] Success: media /dev/mmcblk0p1 mounted to /bootmedia.
| # http://www.raspberrypi.org/documentation/configuration/config-txt.md
| #hdmi_safe=1
| disable_overscan=1
| #hdmi_force_hotplug=1
| #hdmi_group=1
| #hdmi_mode=1
| #hdmi_drive=2
| # no display.
| #config_hdmi_boost=4
| #arm_freq=800
| disable_splash=1
| #hdmi_group=2
| # 800x600:   hdmi_mode=9
| # 1024x768:  hdmi_mode=16
| # 1280x1024: hdmi_mode=35
| # 1360x768:  hdmi_mode=39
| # 1400x1050: hdmi_mode=42
| # 1440x900:  hdmi_mode=47
| # 1600x1200: hdmi_mode=51
| # 1680x1050: hdmi_mode=58
| # 1366x768:  hdmi_mode=81
| # 1920x1080: hdmi_mode=82
| # 1920x1200: hdmi_mode=69
| framebuffer_depth=32
| #framebuffer_depth=16
| dtparam=audio=on
| #avoid_warnings=1
| #avoid_warnings=2
[        initrd] [    5.004647] WTpassword present: cc72aad3323582f495f9cce9c18dded0.
| clientIP = *
| config = local
| setupPassword = cc72aad3323582f495f9cce9c18dded0
[        initrd] [    6.999587] Load ethernet drivers.
[        initrd] [    7.002697] modprobe smsc95xx.
[        KERNEL] [    7.011836] smsc95xx v1.0.5
[        KERNEL] [    7.106301] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:6f:c0:a4
[        KERNEL] [    7.106677] usbcore: registered new interface driver smsc95xx
[        KERNEL] [    7.213764] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[        KERNEL] [    8.633245] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E1
[        initrd] [    8.714880] WTpassword present:
[        initrd] [   11.010150] dhcp: 576 bytes from 192.168.188.1.
[        initrd] [   11.010273] 00000000:0000022C0000000000110000C0A8BC01C0A8BC2100430044022C000002010600  ...,..............!.C.D.,......
[        initrd] [   11.010346] 00000020:67458B6B0000000000000000C0A8BC21C0A8BC0100000000B827EB6FC0A40000  gE.k...........!.........'.o....
[        initrd] [   11.010417] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.010486] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.010554] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.010623] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.010691] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   11.010759] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.260165] dhcp: 576 bytes from 192.168.188.1.
[        initrd] [   13.260288] 00000000:0000022C0000000000110000C0A8BC01C0A8BC2100430044022C000002010600  ...,..............!.C.D.,......
[        initrd] [   13.260362] 00000020:67458B6B0000000000000000C0A8BC21C0A8BC0100000000B827EB6FC0A40000  gE.k...........!.........'.o....
[        initrd] [   13.260431] 00000040:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.260501] 00000060:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.260568] 00000080:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.260638] 000000a0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.260706] 000000c0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.260774] 000000e0:0000000000000000000000000000000000000000000000000000000000000000  ................................
[        initrd] [   13.320088] dhcp: server address 192.168.188.1.
[        initrd] [   13.320163] dhcp: 192.168.188.33/255.255.255.0.
[        initrd] [   13.320253] dhcp: default gateway 192.168.188.1.
[        initrd] [   13.320321] dhcp: DNS 192.168.188.1.
[        initrd] [   13.320388] dhcp: domain fritz.box.
[        initrd] [   13.320453] dhcp: TFTP from siaddr 192.168.188.1.
[        initrd] [   13.320520] dhcp: TFTP 192.168.188.1.
[        initrd] [   13.320586] No boot file from DHCP.
[        initrd] [   13.320652] TFTP binary "", configs prefix "", using "/" slash.
[        initrd] [   13.322255] Run OpenVPN with user config configs/openvpn.cfg.
[        initrd] [   13.326689] Unpack /bootmedia/packages/pi2-dbus.
[        initrd] [   13.601065] +--- Executing "/usr/bin/dbus-daemon --system"
[        initrd] [   13.633536] +- Errorlevel: 0, output:
File is empty.
[        initrd] [   13.635245] +------------------------
[        initrd] [   13.635306] Unpack /bootmedia/packages/pi2-xnet.
[        initrd] [   14.208389] +--- Executing "/sbin/modprobe tun"
[        KERNEL] [   14.213210] tun: Universal TUN/TAP device driver, 1.6
[        KERNEL] [   14.213216] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[        initrd] [   14.212835] +- Errorlevel: 0, output:
File is empty.
[        initrd] [   14.212980] +------------------------
[        initrd] [   14.213019] +--- Executing "/usr/sbin/openvpn /etc/client.conf"
[SYSLOG] <29>Nov 17 00:00:11 openvpn[650]: OpenVPN 2.4.0 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jun 22 2017
[SYSLOG] <29>Nov 17 00:00:11 openvpn[650]: library versions: OpenSSL 1.0.2g  1 Mar 2016, LZO 2.08
[        initrd] [   14.230340] +- Errorlevel: 0, output:
[SYSLOG] <28>Nov 17 00:00:11 openvpn[651]: WARNING: normally if you use --mssfix and/or --fragment, you should also set --tun-mtu 1500 (currently it is 1400)
File is empty.
[SYSLOG] <29>Nov 17 00:00:11 openvpn[651]: TCP/UDP: Preserving recently used remote address: [AF_INET]84.201.35.24:1194
[SYSLOG] <29>Nov 17 00:00:11 openvpn[651]: Socket Buffers: R=[163840->163840] S=[163840->163840]
[        initrd] [   14.230554] +------------------------
[SYSLOG] <29>Nov 17 00:00:12 openvpn[651]: Initialization Sequence Completed
[        initrd] [   15.918285] OpenVPN tun0: my IP 10.65.58.22.
[        initrd] [   15.918550] Run '/sbin/httpd', log '/tmp/httpd.out', env '', pid ''.
[          pfac] [   15.918981] Run /sbin/httpd.
[          pfac] [   15.919080] Ok, PID 722.
[         httpd] [   15.923877] HTTP Server, WTware 5.6.20/RPi
[        initrd] [   16.041449] USB: 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter.
[        initrd] [   16.041592] USB: 0424:9514 Standard Microsystems Corp. SMC9514 Hub.
[        initrd] [   16.041667] USB: 062a:4101 Creative Labs Wireless Keyboard/Mouse.
[        initrd] [   16.041749] Copy /bootmedia/configs/config.wtc to /tmp/config.wtc.
[        initrd] [   16.042664] Common local disk config:
| keyboard = de
| language = de, default
| clipboard = on
| infobox=lshift
| turnoffmenu=on
| keyboard=de
| language=de, default
| clipboard=on
| infobox=lshift
| video=auto
| turnoffmenu=on
| sound=on
| next screen
| displayName=anderer Server
| server=--new--
[        initrd] [   16.045827] Hostname: "wtwB827EB6FC0A4".
[         httpd] [   16.314081] Reread settings.
[         httpd] [   16.314368] Everyone can control terminal by HTTP.
[            gm] [   16.318509] WTware session manager 5.6.20/RPi.
[            gm] [   16.320841] Add keyboard event1: MOSART Semi. 2.4G Keyboard Mouse.
[            gm] [   16.320930] Add keyboard event0: MOSART Semi. 2.4G Keyboard Mouse.
[            gm] [   16.321074] Display mode: 1024x768, 32 bit, landscape, 0 Hz, modeline "", DDC enabled, connector 0.
[            gm] [   16.336476] Framebuffer device found.
[            gm] [   16.336556] LINELENBYTES 4096
[            gm] [   16.336650] VLEN 3145728
[            gm] [   16.352831] Use /lib/ui32.so.
[            gm] [   16.370274] Unpack /bootmedia/packages/pi2-alsa.
[            gm] [   16.581354] modprobe snd-bcm2835.
[            gm] [   16.591227] modprobe snd-usb-audio.
|   0: [ 0]   : control
|  33:        : timer
[        KERNEL] [   16.603082] usbcore: registered new interface driver snd-usb-audio
[            gm] [   16.602413] /dev/snd/pcmC0D1p character device.
[            gm] [   16.602471] /dev/snd/pcmC0D0p character device.
[            gm] [   16.602509] /dev/snd/controlC0 character device.
[            gm] [   16.602556] /dev/snd/timer character device.
[            gm] [   16.602594] Preconfigure ALSA.
[            gm] [   16.602632] Run '/sbin/rdpsnd sndvol 100 100 50', log '', env '', pid ''.
[            gm] [   16.602669] Run sound daemon.
[            gm] [   16.602706] Run '/sbin/rdpsnd 1 0 100 0 -1', log '', env '', pid ''.
[            gm] [   16.602743] Only one RDP session can use sound redirection.
[            gm] [   16.602780] Turn it off for at display 0 screen 1.
[            gm] [   16.602817] Only one RDP session can use sound redirection.
[            gm] [   16.602854] Turn it off for at display 0 screen 2.
[            gm] [   16.602891] Load usb storage driver.
[            gm] [   16.602928] modprobe scsi_mod.
[          pfac] [   16.603307] Run /sbin/rdpsnd sndvol 100 100 50.
[          pfac] [   16.603372] Ok, PID 751.
[          pfac] [   16.603419] Run /sbin/rdpsnd 1 0 100 0 -1.
[          pfac] [   16.603476] Ok, PID 752.
[        sndvol] [   16.609105] Card 'ALSA'/'bcm2835 ALSA'.
[        sndvol] [   16.609172] Mixer name: 'Broadcom Mixer'.
[        sndvol] [   16.609213] Components: ''.
[        sndvol] [   16.609252] Controls: 6.
[        sndvol] [   16.609291] ALSA: control 'PCM Playback Volume'.
[        sndvol] [   16.609330] ALSA: control 'PCM Playback Switch'.
[        sndvol] [   16.609369] ALSA: control 'PCM Playback Route'.
[        sndvol] [   16.609408] ALSA: control 'IEC958 Playback Default'.
[        sndvol] [   16.609447] ALSA: control 'IEC958 Playback Con Mask'.
[        sndvol] [   16.609486] ALSA: control 'IEC958 Playback PCM Stream'.
[        sndvol] [   16.609525] Inactive control IEC958 Playback PCM Stream'.
[          pfac] [   16.615160] Process pid 751 terminated, status 00000000.
[        rdpsnd] [   16.615250] RDP Sound Redirector, WTware 5.6.20/RPi.
[        rdpsnd] [   16.618282] Card 'ALSA'/'bcm2835 ALSA'.
[        rdpsnd] [   16.618361] Mixer name: 'Broadcom Mixer'.
[        rdpsnd] [   16.618401] Components: ''.
[        rdpsnd] [   16.618450] Controls: 6.
[        rdpsnd] [   16.618488] ALSA: control 'PCM Playback Volume'.
[        rdpsnd] [   16.618528] ALSA: control 'PCM Playback Switch'.
[        rdpsnd] [   16.618566] ALSA: control 'PCM Playback Route'.
[        rdpsnd] [   16.618605] ALSA: control 'IEC958 Playback Default'.
[        rdpsnd] [   16.618644] ALSA: control 'IEC958 Playback Con Mask'.
[        rdpsnd] [   16.618682] ALSA: control 'IEC958 Playback PCM Stream'.
[        rdpsnd] [   16.618720] Inactive control IEC958 Playback PCM Stream'.
[        KERNEL] [   16.621392] SCSI subsystem initialized
[            gm] [   16.620219] modprobe usb-storage.
[            gm] [   16.626712] modprobe sd_mod.
[        KERNEL] [   16.628007] usbcore: registered new interface driver usb-storage
[            gm] [   16.631868] Load EXFAT filesystem driver.
[            gm] [   16.631981] modprobe fuse.
[            gm] [   16.638690] modprobe exfat.
[        KERNEL] [   16.639454] fuse init (API version 7.26)
[        KERNEL] [   16.645478] exFAT: Version 1.2.9
[            gm] [   16.645094] Run '/sbin/rdpdr[usb] 0bda:8153 debug', log '/tmp/rdpdr[usb].out', env '', pid ''.
[          pfac] [   16.645163] Run /sbin/rdpdr[usb] 0bda:8153 debug.
[          pfac] [   16.645471] Ok, PID 777.
[rdpdr-usb 0bda:8153] [   16.647114] RDP USB Redirector, WTware 5.6.20/RPi
[rdpdr-usb 0bda:8153] [   16.647167] [DEBUG] Open listener at /tmp/rdpdr[usb]_0bda:8153. Main thread 0x76f5d000.
[rdpdr-usb 0bda:8153] [   16.647209] [DEBUG] Init libusb.
[rdpdr-usb 0bda:8153] [   16.648388] [DEBUG] Ignore 062a:4101.
[rdpdr-usb 0bda:8153] [   16.648435] [DEBUG] Ignore 0424:ec00.
[rdpdr-usb 0bda:8153] [   16.648474] [DEBUG] Ignore 0424:9514.
[rdpdr-usb 0bda:8153] [   16.648513] [DEBUG] Ignore 1d6b:0002.
[            gm] [   16.697519] Run '/sbin/resolver 0x18e6cb0 dns [192.168.188.70]', log '', env '', pid ''.
[          pfac] [   16.697632] Run /sbin/resolver 0x18e6cb0 dns [192.168.188.70].
[            gm] [   16.697656] Nobody can control terminal by VNC.
[          pfac] [   16.697962] Ok, PID 779.
[          pfac] [   16.699963] Process pid 779 terminated, status 00000000.
[            gm] [   16.703338] Run '/sbin/resolver 0x18e8348 dns [192.168.124.2]', log '', env '', pid ''.
[          pfac] [   16.703428] Run /sbin/resolver 0x18e8348 dns [192.168.124.2].
[          pfac] [   16.703606] Ok, PID 780.
[          pfac] [   16.705721] Process pid 780 terminated, status 00000000.
[            gm] [   16.709277] Run '/sbin/resolver 0x18e9898 dns [192.168.188.30]', log '', env '', pid ''.
[          pfac] [   16.709397] Run /sbin/resolver 0x18e9898 dns [192.168.188.30].
[            gm] [   16.709546] Ask server address.
[          pfac] [   16.709609] Ok, PID 781.
[          pfac] [   16.711876] Process pid 781 terminated, status 00000000.
[            gm] [   16.716318] 192.168.188.70 => 192.168.188.70.
[            gm] [   16.718311] Free ram before fork terminal client /sbin/rdpclient (session 1): 911808 Kb.
[            gm] [   16.718354] Run '/sbin/rdpclient 1', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   16.718394] Run /sbin/rdpclient 1.
[          pfac] [   16.718562] Ok, PID 782.
[ rdpclient 782] [   16.722458] RDP Terminal Client, WTware 5.6.20/RPi, pipe 1, pid 782.
[ rdpclient 782] [   16.723154] Use /lib/ui32.so.
[ rdpclient 782] [   16.723851] Redirect sound.
[ rdpclient 782] [   16.723996] Make RDP session with 192.168.188.70, port 3389.
[ rdpclient 782] [   16.724047]  Username: "christianhanshans".
[ rdpclient 782] [   16.724089]  No password.
[ rdpclient 782] [   16.724129]  No PIN.
[ rdpclient 782] [   16.724168]  No domain.
[ rdpclient 782] [   16.724239]  No shell.
[            gm] [   16.724294] 192.168.124.2 => 192.168.124.2.
[ rdpclient 782] [   16.724316]  No directory.
[ rdpclient 782] [   16.724357]  Window: 1024x768@24.
[ rdpclient 782] [   16.724398]  PFlags 0x0000002F.
[ rdpclient 782] [   16.724441]  Keyboard 00000407:00000000.
[ rdpclient 782] [   16.724484]  My hostname "wtwB827EB6FC0A4".
[ rdpclient 782] [   16.724526] TCP: connecting to 192.168.188.70:3389.
[ rdpclient 782] [   16.725522] TCP: connection with 192.168.188.70:3389 established.
[ rdpclient 782] [   16.725567] Turn keepalive on.
[ rdpclient 782] [   16.726059] Free ram after buffers allocation: 910728 KB.
[            gm] [   16.727007] Free ram before fork terminal client /sbin/rdpclient (session 2): 910728 Kb.
[            gm] [   16.727050] Run '/sbin/rdpclient 2', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   16.727090] Run /sbin/rdpclient 2.
[          pfac] [   16.727240] Ok, PID 783.
[ rdpclient 783] [   16.731276] RDP Terminal Client, WTware 5.6.20/RPi, pipe 2, pid 783.
[            gm] [   16.732648] 192.168.188.30 => 192.168.188.30.
[ rdpclient 783] [   16.732719] Use /lib/ui32.so.
[ rdpclient 783] [   16.732792] Make RDP session with 192.168.124.2, port 3389.
[ rdpclient 783] [   16.732846]  Username: "lobustho".
[ rdpclient 783] [   16.732903]  Password: present.
[ rdpclient 783] [   16.732957]  No PIN.
[ rdpclient 783] [   16.733021]  No domain.
[ rdpclient 783] [   16.733065]  No shell.
[ rdpclient 783] [   16.733110]  No directory.
[ rdpclient 783] [   16.733152]  Window: 1024x768@24.
[ rdpclient 783] [   16.733194]  PFlags 0x0000002F.
[ rdpclient 783] [   16.733237]  Keyboard 00000407:00000000.
[ rdpclient 783] [   16.733279]  My hostname "wtwB827EB6FC0A4".
[ rdpclient 783] [   16.733322] TCP: connecting to 192.168.124.2:3389.
[            gm] [   16.734004] Free ram before fork terminal client /sbin/rdpclient (session 3): 910524 Kb.
[            gm] [   16.734045] Run '/sbin/rdpclient 3', log '/tmp/rdpclient.out', env '', pid ''.
[          pfac] [   16.734085] Run /sbin/rdpclient 3.
[          pfac] [   16.734219] Ok, PID 784.
[ rdpclient 784] [   16.738068] RDP Terminal Client, WTware 5.6.20/RPi, pipe 3, pid 784.
[ rdpclient 784] [   16.738517] Use /lib/ui32.so.
[ rdpclient 784] [   16.739195] Make RDP session with 192.168.188.30, port 3389.
[ rdpclient 784] [   16.739307]  Username: "internet".
[ rdpclient 784] [   16.739352]  Password: present.
[ rdpclient 784] [   16.739395]  No PIN.
[ rdpclient 784] [   16.739438]  No domain.
[ rdpclient 784] [   16.739481]  No shell.
[ rdpclient 784] [   16.739523]  No directory.
[ rdpclient 784] [   16.739566]  Window: 1024x768@24.
[ rdpclient 784] [   16.739608]  PFlags 0x0000002F.
[ rdpclient 784] [   16.739651]  Keyboard 00000407:00000000.
[ rdpclient 784] [   16.739694]  My hostname "wtwB827EB6FC0A4".
[ rdpclient 784] [   16.739737] TCP: connecting to 192.168.188.30:3389.
[ rdpclient 784] [   16.740987] TCP: connection with 192.168.188.30:3389 established.
[ rdpclient 784] [   16.741187] Turn keepalive on.
[ rdpclient 784] [   16.741926] Free ram after buffers allocation: 909608 KB.
[ rdpclient 784] [   16.742730] No negotiation response.
[        KERNEL] [   16.744249] random: crng init done
[ rdpclient 784] [   16.743530] Process RDP server certificate.
[ rdpclient 784] [   16.743586] RDP4 encryption.
[ rdpclient 783] [   16.754587] TCP: connection with 192.168.124.2:3389 established.
[ rdpclient 783] [   16.754683] Turn keepalive on.
[ rdpclient 783] [   16.755047] Free ram after buffers allocation: 909324 KB.
[ rdpclient 783] [   16.777490] Reconnect with CredSSP enabled.
[ rdpclient 783] [   16.777580] TCP: reconnecting to 192.168.124.2:3389.
[ rdpclient 784] [   16.789787] Enable font smoothing.
[ rdpclient 783] [   16.799199] TCP: connection with 192.168.124.2:3389 established.
[ rdpclient 783] [   16.799250] Turn keepalive on.
[ rdpclient 783] [   16.817710] Server supports GFX Pipeline.
[ rdpclient 783] [   16.817779] CredSSP.
[ rdpclient 783] [   16.817822] SSL/TLS.
[ rdpclient 784] [   16.833772] RDP4 encryption.
[ rdpclient 783] [   17.212953] Enable font smoothing and Desktop Composition.
[        KERNEL] [   44.101961] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
[rdpdr-usb 0bda:8153] [   44.233316] Device connected. USB Id 0bda:8153, bus Id 1-1.4, BUSNUM 1, DEVNUM 5.
[        KERNEL] [   44.233488] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8153
[        KERNEL] [   44.233498] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[        KERNEL] [   44.233506] usb 1-1.4: Product: USB 10/100/1000 LAN
[        KERNEL] [   44.233513] usb 1-1.4: Manufacturer: Realtek
[        KERNEL] [   44.233520] usb 1-1.4: SerialNumber: 000001000000
[ rdpclient 783] [   52.790258] SSL_ERROR_SYSCALL
[ rdpclient 783] [   52.790392] TCP/IP connection lost. Network failure?
[          pfac] [   52.795164] Process pid 783 terminated, status 00000009.
[            gm] [   52.795239] Final message: TCP/IP connection lost. Network failure?
chris wrote:OK, downloaded latest version. When plugging the USB ethernet in, connection to the RPI won't work
It printed on the screen "connection to the RPI won't work"?
Connect USB Ethernet. Connect Ethernet cable to USB Ethernet. DO NOT UNPLUG ANYMORE! Configure wtware to obtain IP from DHCP. Reboot. If it won't start, read manual https://wtware.com/logs.html "Directly from terminal, when terminal failed to connect to network"
