Wireless WPA2 Enterprise Authentication
vincny
Post by vincny »
Hi Support,
Any chance to support Wireless WPA2 Enterprise authentication in the near future?
Thanks,
Ken
Re: Wireless WPA2 Enterprise Authentication
There are a lot of buzzwords about WPA2 Enterprise. What exactly do you need?
vincny
Post by vincny »
Hi Aka,
Basically, I am looking forward if you and your team could add the following WPA-EAP authentication for rpi :
# EAP-PEAP/MSCHAPv2 configuration for RADIUS servers that use the new peaplabel
# (e.g., Radiator)
network={
ssid="example"
key_mgmt=WPA-EAP
eap=PEAP
identity="user@example.com"
password="foobar"
ca_cert="/etc/cert/ca.pem"
phase1="peaplabel=1"
phase2="auth=MSCHAPV2"
priority=10
Your help is very much appreciated.
Many thanks,
Ken
vincny
Post by vincny »
Hi Aka,
To be exact:
Wireless LAN interface config:
nano /etc/network/interfaces
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
WPA Supplication config:
nano /etc/wpa_supplicant/wpa_supplicant.conf
# (e.g., Radiator)
network={
ssid="example"
key_mgmt=WPA-EAP
eap=PEAP
password="foobar"
priority=10
Thanks,
Ken
I'll try to add custom wpa_supplicant.conf support a bit later. Sorry, too busy now.
vincny
Post by vincny »
Hi Aka,
Great to hear that you are on it!
Hope to see the feature soon.
Thanks,
Ken
Please, try wtware 5.4.54.
Install it on SD.
Create wpa_supplicant.conf (lower case!) file in configs folder on SD. Start from wtware default to make sure, that everything goes right:
network={
   ssid="put-wifi-ssid-here"
   psk="put-password-here"
Run wtware. It should connect. If it does, add your settings instead of wtware default.
vincny
Post by vincny »
Hi Aka,
First of all, thank you very much for your effort, but I have to bring you some bad news.
1. After reinstall the new version, I get a message File not found "SourceCodePro-Regular.ttf"
2. After Re-image the WTware SD card, I created wpa_supplicant.conf in the config folder:
network={
ssid="My SSID"
key_mgmt=WPA-EAP
eap=PEAP
identity="myusername"
password="password"
priority=1
3. When running on the WTware on Raspberry PI 3 Wireless is not connecting and it is asking for WIFI configuration.
The default configure only accept No Encryption or WPA/WPA2 PSK.
I have added some photo, if it help.
Did I do anything wrongly?
Appreciate if you can relook into it.
Thanks,
Ken
File not found.png (1.94 KiB) Viewed 65832 times
Please, try 5.4.56.
vincny
Post by vincny »
Hi Aka,
Good job! We are almost there, I am now able to authenticate using the config file but I have problem getting DHCP IP address.
The DHCP work fine on other devices, could it be that the following wlan0 DHCP configuration?
auto wlan0
allow-hotplug wlan0
Update:
In additional, I cannot get wireless IP address even non encrypted/no password WIFI SSID which worked on version 5.4.52.
Thanks a million,
Ken
Does it works with static IP? You connected to terminal server and got windows desktop?
vincny
Post by vincny »
Hi Aka,
Nope not working with static ip.
I tried to set the static IP during initial SD card install but not working.
Thanks,
Ken
If static IP does not work, why you think WiFi works?
vincny
Post by vincny »
Hi Aka,
I have a radius server for wireless authentication.
I check the log it is authenticating the wireless session from rpi 3, further more the status is successful.
Additional info:
I can also see that rpi 3 is connected to the Wireless LAN control just that it cannot get an IP address
and the connect will drop off after a few minute fail to get IP address.
Maybe the new version static IP only apply to LAN network and not Wireless?
Just my guess.
Thanks,
Ken
Let us now dig deeper.
Download, install, write on SD: http://pxe.ru/files/testing/201611132210.zip
Write wpa_supplicant.conf in /confgs/ on SD.
Boot.
Configure static IP (by the way, does your radius server work with static ip? why does connection drop after it failed to get IP address?)
Configure local config. Write "server=1.2.3.4" in config.
Reboot. Do not enter setup anymore, let it boot.
It will open command prompt. Type:
ifconfig
Make screen photo.
Type:
iwconfig
Photo again. Type:
ping -c 1 12.34.56.78
replace 12.34.56.78 with real pingable ip in wifi subnet. Photo.
Type:
cat /tmp/all.log
Photo.
Press Shift-PageUp.
Photo.
Repeat "Press Shift-PageUp. Photo." three times.
Do you still need wtware and wpa2 enterprise?
