Token support request (Watchdata)
Carlos
Post by Carlos »
I sent email to support@wtware.com on 29/01/2016, and no response received.
We are users of WTware in our Thin Clients.
I need to redirect a USB Key (USB SmartCard) for the RDP server.
The smartcard tab not found an option that looks like the device I'm using, its manufacturer is "Watchdata." idVendor = 163C and idProduct = 0407.
I'm using WTware v.5.4.14
I await a return.
thank you
Re: Token support request (Watchdata)
Here is the manual about new tokens and smartcards in WTware: http://wtware.com/docs5/smartcard.html
Carlos
Post by Carlos »
I sent the requested data to wtware@support.ru, and the mail can not be delivered. I sent support@wtware.com
I wait for a return.
Send you the answer. (Correct e-mail is support@wtware.ru, not wtware@support.ru)
Carlos
Post by Carlos »
Ok, please correct on page http://wtware.com/docs5/smartcard.html
Thanks. Fixed.
