keyboard language Problem (Swiss German)
Re: keyboard language Problem (Swiss German)
Does it work with mstsc.exe on the same server with the same user account?
skynet
Post by skynet »
If i connect rpitc2 or rpitc3 account this server then not working hungarian keyboard layout. I tryed with raspberry pi3. If i connect other desktop client on this server then hun keyboard layout is ok.
skynet
Post by skynet »
I joined another Windows 2012 R2 HUN server with raspberry PI3.
The following letters work:
z y ö ü ó ú é
The following letters do not work:
ő á í ű
What might be the problem?
lmarkus
Post by lmarkus »
This problem isn't solved yet: hungarian keyboard layout
öüó works
í is \
0 is `
á is '
It is on login screen when I type in the user name / password
Especially critical because of 0 is not where the user knows.
Thank you!
Please find correct layout here: http://kbdlayout.info/
And write me all keys that work incorrectly.
lmarkus
Post by lmarkus »
This is the layout:
http://kbdlayout.info/0000040e/
The reds are not working:
https://imgur.com/a/eXV5rnX
Specifically:
0 -> `
á -> '
ű -> í
í -> \
Thank you!
lmarkus
Post by lmarkus »
It works great. Thanks for the quick response!
