Problem Booting with Gigabit NIC
Posted: Tue Aug 26, 2008 2:43 pm
I am having a problem booting WTWare Lite with my notebook PC using Marvel Yukon Gigabit chipset.
My company is now doing trial to use your product with our system. My IT staff said that he encountered the same problem with desktop PCs with gigabit NIC as well. However, the older PC with 100 Mbps works fine.
I have also now tried versions 4.4.5 and but I got the same error message. It comes up with the WTWare loading Terminal Screen and then errors with:
Error Network Card Not Found. If Intel EtherExpress or ISA NE 2000-Compatible card is used, then it should be configured to work with port 300.
NIC1 PCIID 8086:104a
NIC2 PCIID 0000:0000
Please correct the error to continue.
Please help me to solve this problem because your product is very useful and we plan to use it if successful.
Thank you for your kind attention
