Boot Network Card Errors
Robb_Robson
Post by Robb_Robson »
I am having a problem booting WTWare Lite using a CD on a HP DC7700
I can boot using the CD on a HP DX2000 computer fine.
I have also now tried both versions 4.21 and 4.3.60 so see if there was a difference but I got the same error message.
When the Computer boots off the CD, it comes up with the WTWare loading Terminal Screen and then errors with:
Error Network Card Not Found. If Intel EtherExpress or ISA NE 2000-Compatible card is used, then it should be configured to work with port 300.
NIC1 PCIID 8086:104a
NIC2 PCIID 0000:0000
Please correct the error to continue.
Any ideas??
Thank you for your help
James
Robb_Robson
I have downloaded this version and it works fine for my HP DC7700 but now won't work for my older P.C the HP DX2000.
When I boot it does the following:
Loading BZIMAGE...................................
Loading WTSHELL....................................
Ready.
and the computer does nothing but sit at this screen.
after a while it errors with,
Schedule_task():keventd has not started.
Also the older version of PRO works fine for DX2000 but not for the new DC7700.
Also the USB drives don't work when the DC7700 is loaded.
When you click on connect for the USB drives all it does is make an error noise.
James
1. Try to disable USB controller in DX2000 BIOS. Will 4.3.61 version work then on DX2000?
2. Send to aka@wtware.com terminal log when DC7700 makes an error noise. For more details about log read: http://wtware.com/docs/config.html#syslog
Robb_Robson
1. I have disabled the USB Controller and it still does the same. also If I disable the usb controller then won't that stop me from using my USB flash drives, which i will need to use?!?!
2. I have sent over an email of the error message twice now and not had a response. please find attached the errors in the log
Cheers
James
