Network connector on - pi5
Posted: Tue Jan 07, 2025 3:32 pm
by Jecat
Is it possible to make the pi5 with wtware keep the network connector on while the pi5 is sleeping? I updated the pi5 eeprom.
Re: Network connector on - pi5
Posted: Wed Jan 08, 2025 11:00 am
Sorry, don't understand what are you talking about. Pi5 can sleep?
Posted: Wed Jan 08, 2025 11:34 am
by Jecat
I use the turnoffmenu=poweroff function, I need the internet connector to not turn off when turning it off.
Posted: Wed Jan 08, 2025 3:10 pm
I have no ideas. Why do you think it is possible in hardware? With Raspberry OS, you can turn Raspberry off but leave network on?
Posted: Wed Jan 08, 2025 3:17 pm
by Jecat
It would probably be possible to run wake on lan, because the wake-up software will find it and can identify both the mac address and IP, and it also records the device being turned on and off. If the device could keep the lan on, it should be possible to wake it up via wol.zip
Posted: Thu Jan 09, 2025 5:33 am
Jecat wrote: Wed Jan 08, 2025 3:17 pm
It would probably be possible to run wake on lan, because the wake-up software...
Software can not wake device up if wake on lan is not implemented in hardware.
On Raspberry forum people write wake on lan is not supported in Pi5 hardware:
https://forums.raspberrypi.com/viewtopic.php?t=361644
Posted: Thu Jan 09, 2025 1:05 pm
by Jecat
Is it not possible to define this in the eeprom config?
Posted: Thu Jan 09, 2025 1:19 pm
No.
Posted: Thu Jan 09, 2025 3:14 pm
by Jecat
It has to work somehow, other clients built on ARM processors know this
https://github.com/home-assistant/core/issues/48139
