No Bluetooth on RaspberryPi 3B
Posted: Wed Jun 19, 2024 2:48 pm
I'm trying out WTWare (Eval) on a RaspberryPi 3B. I have added the "Bluetooth=Scan" option (I Also tried adding "BlueTooth=on" both here and in the config.txt) in the WTWare config file. But I don't see the terminal scanning for Bluetooth devices on startup. It just goes straight to the server selection screen. I see the module being detected in the start log. I also don't see a Bluetooth menu on the config web page either. Am I missing something? I'm booting from the internal MicroSD card.
# Take a look at graphic configurator on Windows.
# You will find there full list of options with possible values.
# http://wtware.com/docs5/config.html
# Uncomment to enable USB flash redirection.
disk=usb
# Uncomment to enable sound on HDMI.
sound=on
# Read manual for more sound options:
# https://wtware.com/docs5/sound.html
# Remote control without password isn't secure.
wtrc=on
wtrc_password=mode:none
#bluetooth=on
bluetooth=scan
[ gm] [ 21.458866] modprobe uas.
[ KERNEL] [ 21.465409] usbcore: registered new interface driver usb-storage
[ gm] [ 21.468195] modprobe sd_mod.
[ KERNEL] [ 21.474990] usbcore: registered new interface driver uas
[ gm] [ 21.478616] Load bluetooth driver.
[ gm] [ 21.478786] modprobe hci_uart.
[ KERNEL] [ 21.543989] Bluetooth: Core ver 2.22
[ KERNEL] [ 21.544104] NET: Registered PF_BLUETOOTH protocol family
[ KERNEL] [ 21.544114] Bluetooth: HCI device and connection manager initialized
[ KERNEL] [ 21.544289] Bluetooth: HCI socket layer initialized
[ KERNEL] [ 21.544303] Bluetooth: L2CAP socket layer initialized
[ KERNEL] [ 21.544314] Bluetooth: SCO socket layer initialized
[ KERNEL] [ 21.548649] Bluetooth: HCI UART driver ver 2.3
[ KERNEL] [ 21.548683] Bluetooth: HCI UART protocol H4 registered
[ KERNEL] [ 21.548794] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ KERNEL] [ 21.548999] Bluetooth: HCI UART protocol Broadcom registered
[ KERNEL] [ 21.550988] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[ KERNEL] [ 21.551281] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[ KERNEL] [ 21.667810] uart-pl011 3f201000.serial: no DMA platform data
[ gm] [ 21.782109] modprobe hidp.
[ gm] [ 21.791582] Load fuse for NTFS filesystem driver.
[ KERNEL] [ 21.798282] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ KERNEL] [ 21.798332] Bluetooth: HIDP socket layer initialized
[ gm] [ 21.792003] modprobe fuse.
[ gm] [ 21.804359] +--- Executing "/usr/bin/btuart"
[ KERNEL] [ 21.810599] fuse: init (API version 7.39)
[ gm] [ 21.890335] +- Errorlevel: 1, output:
| Can't open serial port: No such file or directory
| Can't initialize device: Invalid argument
[ gm] [ 21.890802] +------------------------
[ gm] [ 21.890889] globalConfig.cpp ( 1861): -- ERROR -- INTERNAL ERROR. Please, contact WTware tech support.
[ gm] [ 21.891097] modprobe snd-hrtimer.
[ KERNEL] [ 21.908681] Bluetooth: hci0: BCM: chip id 94
[ KERNEL] [ 21.909227] Bluetooth: hci0: BCM: features 0x2e
[ KERNEL] [ 21.912952] Bluetooth: hci0: BCM43430A1
[ KERNEL] [ 21.913000] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0000
[ KERNEL] [ 21.913317] Bluetooth: hci0: BCM43430A1 'brcm/BCM43430A1.raspberrypi,3-model-b.hcd' Patch
[ gm] [ 21.907203] modprobe snd-bcm2835.
[ KERNEL] [ 21.926591] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ KERNEL] [ 21.952038] bcm2835_audio bcm2835_audio: card created with 4 channels
[ KERNEL] [ 21.956767] bcm2835_audio bcm2835_audio: card created with 4 channels
[ gm] [ 21.952558] modprobe snd-usb-audio.
[ KERNEL] [ 21.981600] usbcore: registered new interface driver snd-usb-audio
[ KERNEL] [ 22.758641] Bluetooth: hci0: BCM: features 0x2e
[ KERNEL] [ 22.761834] Bluetooth: hci0: BCM43438A1 37.4MHz Raspberry Pi 3-0141
[ KERNEL] [ 22.761848] Bluetooth: hci0: BCM43430A1 (001.002.009) build 0508
disk=usb
sound=on
wtrc=on
#bluetooth=on
bluetooth=scan
