Choosing remote server?
Posted: Wed Feb 03, 2021 8:12 am
Two Shark NV360 Alternatives You Should Consider
Shark Navigator Lift-Away Deluxe NV360 upright vacuum is a great affordable vacuum to have. But if you need to shop around before buying, there are two other similar models that you can have a look at.
Important Site: Shark NV360
1. Shark Navigator Lift-Away NV352
As another popular model in the Navigator series, the NV352 requires little maintenance and virtually no recurring costs. This is possible partly thanks to the high-quality parts Shark has used to build this vacuum. That will save you from money, effort, and frustration compared to many other lower-quality models on the market.
Most of them can last the lifetime of the NV352, and in case something breaks, you can enjoy the generous 5-year warranty policy. It's not common to see an affordable vacuum with such a great guarantee, which can tell us something about its longevity. Shark's customer service is responsive and willing to honor this warranty, according to feedback from many people.
In real-life tests, the Shark NV352 delivers a well-rounded cleaning performance on most kinds of surfaces, including hardwood floors and carpeted surfaces, with typical debris types, such as pet hair, crumbs, and dust. Handling this vacuum is light and smooth, while the extra attachments prove to be useful in many situations. You can conveniently store them on the board as well.
As the geared belt of this vacuum doesn't stretch out, users won't see any drop in carpet-cleaning performance even after many years of use. This is a huge improvement from the traditional flat rubber belt we find on most vacuums.
Many vacuum cleaners require users to replace filters after a specific period, or the cleaning performance of the machine will be severely affected. The Shark NV352, however, comes with lifetime filters, which don't need any replacement. You only need to wash the pre-motor filter and shake out the post-motor filter from time to time to get rid of the dirt.
2. Dyson Ball Animal 2
Shark navigator NV360 doesn't always perform well with pet hair. When you need to deal with a huge amount of dander and shedding on a daily basis, you should get a machine designed specifically for that kind of vacuuming like the Dyson Ball Animal 2.
This Dyson machine is a standard upright vacuum. You may need a fair bit of storage space in your closet, but it is any bigger than other uprights. Thanks to the onboard storage for accessories, you don't need to find separate spots for them either.
The Dyson Ball Animal 2 weighs around 17.5 pounds, which is significantly heavier than a lot of other upright models. But as the whole machine is well-balanced, you won't see any trouble moving it around your house.
This vacuum can automatically adjust the brushroll to make a tight seal between it and the surface. It also comes with a turbine tool that can suck up and extract pet hair using counter-rotating brush heads. This move away from a regular brush bar, which gets tangled easily with long hair, makes sure that the Dyson Ball Animal can pick up a lot of pet hair without getting clogged.
Conclusion
Two alternative choices above, one from Shark itself and one from its rival, are both great upright vacuums that can serve you well when the shark navigator lift-away deluxe NV360 is simply not available or if you need a specialized model for pet hair.
Conclusion
