We recently setup two HP Omni terminals for a client and are attempting to get all the devices working that are needed. So far everything passes through with proper config EXCEPT the HP WebCam (builtin USB bus'd).
When we pass this through its like the RDP session never sees it or the Win10Pro host VM.
We passed
usb=mass_storage, 1-7, 3-2, 3-1 with no camera - keyboard and mouse worked as expected.
usb=04f2:b18b with no camera - keyboard and mouse worked as expected.
Sound works, Microphone works, no Camera. Please assist.
WTware v.6.0.6
can't get debug descriptor: Resource temporarily unavailable
gth 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239
bDeviceSubClass 2
bDeviceProtocol 1
bMaxPacketSize0 64
idVendor 0x04f2
idProduct 0xb18b
bcdDevice 84.28
iManufacturer 2 Chicony Electronics Co., Ltd.
iProduct 1 HP WebCam
iSerial 3 SN0001
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x01fd
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 98mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14
bFunctionSubClass 3
bFunctionProtocol 0
iFunction 5 HP WebCam
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14
bInterfaceSubClass 1
bInterfaceProtocol 0
iInterface 5 HP WebCam
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 0x0067
dwClockFrequency 15.000000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 2
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 5
iTerminal 0
bLength 26
bDescriptorType 36
bDescriptorSubtype 6 (EXTENSION_UNIT)
bUnitID 4
guidExtensionCode {28f03370-6311-4a2e-ba2c-6890eb334016}
bNumControl 8
bNrPins 1
baSourceID( 0) 3
bControlSize 1
bmControls( 0) 0x0f
iExtension 0
bLength 26
bDescriptorType 36
bUnitID 5
guidExtensionCode {2812ae3f-bcd7-4e11-a357-6f1edef7d61d}
bNumControl 8
bNrPins 1
baSourceID( 0) 4
bControlSize 1
bmControls( 0) 0xff
iExtension 0
bLength 18
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Camera Sensor
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 3
bmControls 0x00000004
Auto-Exposure Priority
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 3
bSourceID 1
wMaxMultiplier 0
bControlSize 2
bmControls 0x0000157f
Brightness
Contrast
Hue
Saturation
Sharpness
Gamma
White Balance Temperature
Backlight Compensation
Power Line Frequency
White Balance Temperature, Auto
iProcessing 0
bmVideoStandards 0x00
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 6
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 14
bInterfaceSubClass 2
iInterface 0
VideoStreaming Interface Descriptor:
bLength 14
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 1
wTotalLength 0x0107
bEndPointAddress 129
bmInfo 0
bTerminalLink 2
bStillCaptureMethod 2
bTriggerSupport 0
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 0
bLength 27
bDescriptorType 36
bDescriptorSubtype 4 (FORMAT_UNCOMPRESSED)
bFormatIndex 1
bNumFrameDescriptors 5
guidFormat {32595559-0000-0010-8000-00aa00389b71}
bBitsPerPixel 16
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 2 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 38
bDescriptorType 36
bDescriptorSubtype 5 (FRAME_UNCOMPRESSED)
bFrameIndex 1
bmCapabilities 0x00
Still image unsupported
wWidth 640
wHeight 480
dwMinBitRate 6144000
dwMaxBitRate 18432000
dwMaxVideoFrameBufferSize 614400
dwDefaultFrameInterval 333333
bFrameIntervalType 3
dwFrameInterval( 0) 333333
dwFrameInterval( 1) 500000
dwFrameInterval( 2) 1000000
bLength 38
bDescriptorType 36
bFrameIndex 2
bmCapabilities 0x00
wWidth 352
wHeight 288
dwMinBitRate 2027520
dwMaxBitRate 6082560
dwMaxVideoFrameBufferSize 202752
bLength 38
bDescriptorType 36
bFrameIndex 3
bmCapabilities 0x00
wWidth 320
wHeight 240
dwMinBitRate 1536000
dwMaxBitRate 4608000
dwMaxVideoFrameBufferSize 153600
bLength 38
bDescriptorType 36
bFrameIndex 4
bmCapabilities 0x00
wWidth 176
wHeight 144
dwMinBitRate 506880
dwMaxBitRate 1520640
dwMaxVideoFrameBufferSize 50688
bLength 38
bDescriptorType 36
bFrameIndex 5
bmCapabilities 0x00
wWidth 160
wHeight 120
dwMinBitRate 384000
dwMaxBitRate 1152000
dwMaxVideoFrameBufferSize 38400
bLength 26
bDescriptorType 36
bDescriptorSubtype 3 (STILL_IMAGE_FRAME)
bEndpointAddress 0
bNumImageSizePatterns 5
wWidth( 0) 640
wHeight( 0) 480
wWidth( 1) 352
wHeight( 1) 288
wWidth( 2) 320
wHeight( 2) 240
wWidth( 3) 176
wHeight( 3) 144
wWidth( 4) 160
wHeight( 4) 120
bNumCompressionPatterns 0
bLength 6
bDescriptorType 36
bDescriptorSubtype 13 (COLORFORMAT)
bColorPrimaries 1 (BT.709,sRGB)
bTransferCharacteristics 1 (BT.709)
bMatrixCoefficients 4 (SMPTE 170M (BT.601))
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0080 1x 128 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 2
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0100 1x 256 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 3
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0320 1x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 4
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x0b20 2x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 5
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x1320 3x 800 bytes
bInterval 1
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 6
bNumEndpoints 1
bInterfaceClass 14
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 5
Usage Type Data
wMaxPacketSize 0x1400 3x 1024 bytes
bInterval 1
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 239
bDeviceSubClass 2
bDeviceProtocol 1
bMaxPacketSize0 64
Device Status: 0x0002
(Bus Powered)
Remote Wakeup Enabled
HP AIO Terminal built in USB Webcam Redirect issue
Re: HP AIO Terminal built in USB Webcam Redirect issue
Adding info:
[0] USB ID: 04f2:b18b, bus ID: 1-7, serial: SN0001, class: 0xef, subclass: 0x02, Chicony Electronics Co., Ltd
[1] USB ID: 04f2:0833, bus ID: 3-2, class: 0x00, subclass: 0x00, Chicony Electronics Co., Ltd KU-0833 Keyboard
[2] USB ID: 04f2:0939, bus ID: 3-1, class: 0x00, subclass: 0x00, Chicony Electronics Co., Ltd
[ KERNEL] [ 2.571312] usb 1-7: new high-speed USB device number 4 using ehci-pci
[ KERNEL] [ 2.762217] usb 1-7: New USB device found, idVendor=04f2, idProduct=b18b, bcdDevice=84.28
[ KERNEL] [ 2.762220] usb 1-7: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ KERNEL] [ 2.762222] usb 1-7: Product: HP WebCam
[ KERNEL] [ 2.762224] usb 1-7: Manufacturer: Chicony Electronics Co., Ltd.
[ KERNEL] [ 2.762226] usb 1-7: SerialNumber: SN0001
Try this: viewforum.php?f=27
In general, USB cameras are not redirected this time. We'll work on this.
