Questions to move from Ubuntu/Raspberry to WTWare
Posted: Tue Apr 28, 2020 8:25 pm
Hello, we have been testing WTware as a substitute to our current platform with Ubuntu and xfreerdp
We have some issues and questions that would be nice to get oriented
Note: sorry to chat about many topics in same thread, a moderator could split the message if thinks is necessary.
1- It's possible to connect more than 1 sip account with the command SIP = user:password@sip.linphone.org ?
Tried adding another SIP but just does not work
2-How to select between a 2.4 or 5 Ghz network in the wifi set-up ? (is common this days to have the same ESSID for both).
2.1- We have noticed ping delays through WiFi:
This is WTware v.6.0.2/RPi
This is the same Raspberry, in the exact same location and to same WiFi network but with Ubuntu 20.04 for ARM
There is any known issue on wifi driver that can cause this ? The issue is consistent, after reboot, working on remote desktop, without remote desktop, the behavior is the same.
3-It is possible to change the name of certain machine in WTWarecenter ? (mac address is not to friendly if you have this deployed along the country with VPN)
4- Main pipe close errors: we are having this issue when the lines sound = on, hw:1:0 microphone = on, hw:1:0 AND the linphone is configured with a SIP account
According to this thread viewtopic.php?t=50468 is related with sound problems. It seems like linphone is "kidnapping" the USB headset and when the remote session tries to reproduce a sound, it chrash.
This does not happen in Ubuntu with xfreerdp
freerdp2-x11/focal,now 2.0.0~git20190204.1.2693389a+dfsg1-2build2 armhf [installed]
In where we can use the SIP phone and the remote sound / mic without issues.
Reply from 192.168.101.122: bytes=32 time=80ms TTL=64
Reply from 192.168.101.122: bytes=32 time=37ms TTL=64
Reply from 192.168.101.122: bytes=32 time=129ms TTL=64
Reply from 192.168.101.122: bytes=32 time=23ms TTL=64
Reply from 192.168.101.122: bytes=32 time=950ms TTL=64
Reply from 192.168.101.122: bytes=32 time=14ms TTL=64
Reply from 192.168.101.122: bytes=32 time=67ms TTL=64
Reply from 192.168.101.122: bytes=32 time=53ms TTL=64
Reply from 192.168.101.122: bytes=32 time=48ms TTL=64
Reply from 192.168.101.122: bytes=32 time=25ms TTL=64
Reply from 192.168.101.122: bytes=32 time=62ms TTL=64
Reply from 192.168.101.122: bytes=32 time=5ms TTL=64
Reply from 192.168.101.122: bytes=32 time=64ms TTL=64
Reply from 192.168.101.122: bytes=32 time=523ms TTL=64
Reply from 192.168.101.122: bytes=32 time=8ms TTL=64
Reply from 192.168.101.122: bytes=32 time=31ms TTL=64
Reply from 192.168.101.122: bytes=32 time=22ms TTL=64
Reply from 192.168.101.122: bytes=32 time=144ms TTL=64
Reply from 192.168.101.122: bytes=32 time=16ms TTL=64Code: Select all
Reply from 192.168.101.95: bytes=32 time=3ms TTL=64
Reply from 192.168.101.95: bytes=32 time=2ms TTL=64
Reply from 192.168.101.95: bytes=32 time=4ms TTL=64
Reply from 192.168.101.95: bytes=32 time=5ms TTL=64
Reply from 192.168.101.95: bytes=32 time=2ms TTL=643-It is possible to change the name of certain machine in WTWarecenter ? (mac address is not to friendly if you have this deployed along the country with VPN)
