OpenVpn "Linux ip link set failed"
Posted: Fri Feb 14, 2020 8:13 pm
Hello wtware-Fans!
We've just tried to set up a OpenVpn connection with wtware for the first time today.
Our openvpn.cfg with embedded certs look like this at the moment
During start up we receive the following error:
If I try to execute manually the "/sbin/ip link set dev tun0 up mtu 1500" I receive
Tipp would be appreciated
Thanks a lot
Mad S
dev tun
resolv-retry infinite
nobind
persist-key
persist-tun
ns-cert-type server
comp-lzo
key-direction 1
verb 1
remote xxxxx 1194
proto udp
client
auth-nocache
script-security 2
daemon
<ca>
-----BEGIN CERTIFICATE-----
MIIF7DCCA9SgAwIBAgIBATANBgkqhkiG9w0BAQsFADBRMQswCQYDVQQGDAJERTEo
MCYGA1UECgwfS09EQS.....Code: Select all
TUN/TAP device tun0 opened
Linux ip link set failed: could not execute external programCode: Select all
/sbin/ip: error while loading shared libraries: libelf.so.1: cannot open shared object file: no such file or directoryThanks a lot
Mad S
